Chassis lube? - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 05-19-2010, 12:23 AM Thread Starter
Chassis lube?
Does our chassis need any type of maint lubrication? Suspension components? If so, how, where, and what type of lube?
///MD is offline
post #2 of 7 (permalink) Old 05-19-2010, 09:59 PM Thread Starter
bump
///MD is offline
post #3 of 7 (permalink) Old 05-20-2010, 07:30 AM
Moderator Extraordinaire!
tesprit's Avatar
If you are referring to the lubrication of ball joints, tie rod ends, or other components with zerk (grease) fittings, the answer is no. Like most other modern cars, the Elise and Exige do not have chassis/suspension components that can be greased rather they are sealed and lubricated for the life of the component. The wheel bearings are also sealed units and can not be lubricated and there are no king pins or trunnions needing lubrication like the old British cars on a modern Lotus.
tesprit is offline
post #4 of 7 (permalink) Old 05-21-2010, 01:21 AM Thread Starter
that's what I thought, just needed confirmation. Was hoping I could eliminate some rattles and creaks with a little grease here and there...
Thanks!!!
///MD is offline
post #5 of 7 (permalink) Old 05-30-2010, 03:48 AM
exitium's Avatar
Thanks!!!
Creaks? Rattles? "Sounds" like you should look here: https://www.lotustalk.com/forums/f115...31/#post530877
Lotus Europa S 225, Nightfall Black + AP's + Larini + LSS Wheels
History -
Honda CRX Del Sol, Mazda RX-7 FD3S, Toyota MR-S +turbo
exitium is offline
post #6 of 7 (permalink) Old 06-02-2010, 01:10 AM Thread Starter
Yup, did find a lot of those and fixed them already. Got new ones popping up all the time!
///MD is offline
post #7 of 7 (permalink) Old 06-02-2010, 07:00 AM
Ryephile's Avatar
Sounds like you could use some gasketing foam with interior panel rub-points and perhaps with the diffuser/rear-panel area too.
'07 Exige S270 :: Aspen White ::
"This is like O. Henry and Alanis Morissette had a baby and named it "this exact situation"."
Sterling Mallory Archer
Ryephile is offline
