Constant rattling noise only stops when step on brake, ideas? - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Habious
post #1 of 16 (permalink) Old 07-23-2017, 05:55 AM Thread Starter
RGB
RGB's Avatar
As the title says, the car develops a rattle noise from somewhere internal the front console. It has been about 6 months now. The rattle only appears at low speed, and it is not significant but enough to annoy the heck out of me and the passenger. It will go away as soon as I lay my foot on the brake pedal. I've checked everywhere underneath the console and the pedals, all wires are secured and nothing loosen. Anyone shares the same rattle?
Thanks,
Sam
RGB is offline
post #2 of 16 (permalink) Old 07-23-2017, 07:20 AM
Such moderate
Doge's Avatar
What year elise? Is the noise inside or outside the car?
Doge is offline
post #3 of 16 (permalink) Old 07-23-2017, 07:24 AM
brake pedal return spring?
missing the little rubber bump stop for the pedal?
exigegus is offline
post #4 of 16 (permalink) Old 07-23-2017, 07:45 PM
winter's Avatar
I have the same issue with my 06 Elise
winter is offline
post #5 of 16 (permalink) Old 07-23-2017, 08:09 PM
kfennell's Avatar
One time I had this and my lug nuts were loose. Sounded so much like it was in the dash
kfennell is offline
post #6 of 16 (permalink) Old 07-23-2017, 08:13 PM
Sounds like loose brake pads. Pads like pagids etc are smaller to allow for heat expansion and they rattle like anything. Try some 3m stick on brake shims on the back of the pads and on either side of the caliper to make it go away.
breeze91 is offline
post #7 of 16 (permalink) Old 07-23-2017, 11:28 PM
shay2nak
shay2nak's Avatar
Is it pretty noticeable? I have a noise at low speed similar area, like loose change or loose hardware. Not noticed if it goes away with braking. It is pretty faint. If I had the stock exhaust it would be easier to hear it.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #8 of 16 (permalink) Old 07-24-2017, 04:24 AM
Such moderate
Doge's Avatar
Probably not your issue, but this caused a very loud rattle until I would hit the brake pedal:
Doge is offline
post #9 of 16 (permalink) Old 07-24-2017, 08:46 AM Thread Starter
RGB
RGB's Avatar
I will try to take it to a check up asap. Thanks!
Thanks guys, I guess I'm not alone on this issue. The car is a 2011 Elise SC. As for the noise, I can't tell if it's from outside or inside, but definitely from the front. The noise doesn't happen until driving for a while, ie, the noise happens after 15 mins or so. All the lug nuts should be tightened and the car drives and stops fine.
Sam
RGB is offline
post #10 of 16 (permalink) Old 07-24-2017, 10:03 AM
Habious's Avatar
Sure sounds like front brake pads to me.
I've had success with using the CRC Brake Quiet (orange goop) on my pads. I've used them both on the Lotus and the Tesla...and have no issues with pad squeaks, squeals, or rattles.
Mobius97 likes this.
2011 Lotus Elise REV300 - Starlight Black Metallic
2014 Jeep Grand Cherokee SRT
2011 Tesla Roadster 2.5 - Midnight Blue (sold)
2004 Chevy SSR Convertible Pickup - Ultra Violet (sold)
My CarPC YouTube Video - - - - - - - - - - - - - NY Times Article
Habious is offline
post #11 of 16 (permalink) Old 07-24-2017, 10:24 AM
Mobius97's Avatar
Not sure if it will be a cure for the OP's issue but I have a bottle of that stuff and have used it for years. Works well and a bottle will last you a lifetime!
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
post #12 of 16 (permalink) Old 07-25-2017, 05:36 AM Thread Starter
RGB
RGB's Avatar
Thanks guys! Really appreciate the help! I went to do a quick check up on the brake myself this morning, and found out that the front brake pad can be moved by a tiny bit with a push from using a pen, whereas the rear pads are firm and can't be moved by outside force; however, I'm still not 100% sure the noise are from the front pads, because the noise are quite loud, and I'm not sure that it can be made by the tiny movement from the pads.
I will further look into this, keep this issue updated.
Sam
RGB is offline
post #13 of 16 (permalink) Old 07-25-2017, 07:21 AM
dcat151's Avatar
Yep, this is great stuff. I use it on every brake job I do.
2006 Lotus Elise
2006 330i 6MT ZSP/ZPP/ZCW
dcat151 is offline
post #14 of 16 (permalink) Old 10-19-2017, 07:38 AM Thread Starter
RGB
RGB's Avatar
Updates: Prior to my another track day coming up, I took my car to another inspection, especially focused at front suspension.
Surprisingly, the mechanics found that the bolts for the upper control a-arms are slightly loosened. Although without a torque wrench, the mechanics were able to tighten the bolts a bit more with a short wrench by hand measure (I guess could be around approximate 50 lbs). I didn't look into the service manual, but to my little knowledge, these bolts should be torqued some where over 50lbs.
The front suspension upper control a-arms are now tightened (by hand measure). After the repair, the rattle was disappeared at first, but after 30 mins testing, it still appears at low speed (30 km/hr) with clutch in or out, and the noise is especially profound at 2-3rpm; however, the noise is significantly lowered. I will keep on finding if any bolts are loosened and later try the "disc brake quiet".
Sam
RGB is offline
post #15 of 16 (permalink) Old 10-19-2017, 08:44 AM
Wingless Wonder
carbuff's Avatar
I've experienced 'loose pad rattle' on any number of cars over the years.
And yes, my bottle of Disc Brake Quiet has lasted me about 30 years, so far. (Purchased in the 1980s)
Nice to know that my life is not about to end, any time soon! The lifetime bottle is more than half-full.
In the post above, do you mean 2000 - 3000 RPM? Are you implying that an engine speed vibration makes the noise more noticeable independent of actual vehicle speed? If so I'd broaden my investigation. Perhaps a retainer for a metal brake line? Fender inner liner? <---Just a couple W.A.G.s
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #16 of 16 (permalink) Old 10-19-2017, 09:31 AM
kfennell's Avatar
The upper control arm bolts to the chassis? Or to the upright.
The inner are 33 ft lbs and the outer are 60? I think if you have upgraded to 10.9 bolts
That being said you MUST replace the bolts that were loose before you track it. They arent meant to carry load while loose.
kfennell is offline
