Damn battery hold downs - terrible design - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 23 (permalink) Old 10-31-2011, 09:20 PM
Vantage's Avatar
Originally Posted by dissention View Post
The Sector 111 bracket installation requires that you expand the factory cable openings. You can use a drill, but I ended up getting a file set ($3) from Lowe's and had the opening enlarged and fit onto the switch in <15 minutes. It took <30 minutes to replace the old battery, install & inspect everything.
You have to do this with many battery cutoffs switches, including the one that RLS sells (believe it's the same marine quality switch). It took me much longer to drill through though. Weak cordless drill.
Vantage is offline
post #22 of 23 (permalink) Old 10-31-2011, 10:27 PM
spf4000's Avatar
NCI/RLS battery hold down is fantastic. Really simple and elegant solution. I don't know how Lotus thinks the stock setup is appropriate for a car that sees 1G cornering.
spf4000 is offline
post #23 of 23 (permalink) Old 11-01-2011, 07:39 AM
MotoGeek's Avatar
In all fairness, they only needed to design it to be slightly stronger than the rear toe links.
MotoGeek is offline
