Dead dash post supercharger install - LotusTalk - The Lotus Cars Community
post #1 of 14 (permalink) Old 09-18-2017, 11:09 PM Thread Starter
Alright, let's try the Lotustalk hive mind for this one.
I installed a BOE REV300 (it's fast) a couple of weeks ago in my 2007 Elise and while my dash worked before the install, I lost speedo, tacho, odo, and gas gauge post install. Warning lights are still functional. I've been worked with Andrew and Phil to try and resolve, so far it looks like the next step will be to ship my ECU back to test to see if they have full functionality using my ECU in one of their cars.
Steps I've taken:
Opened the clam back up and rechecked every plug ensure a good connection
Attempted to do a speedo reset, but the dash didn't respond at all. No firmware shown on screen.
Checked the 7.5 amp fuses under the dash (all seem fine)
Disconnect battery for 10 minutes.
I have not removed the dash cowl, but given that this area wasn't touched I can't see being as issue.
From what I've read in the forums, the fuse block under the dash has something to do with this. I've checked these fuses and they seem to be fine, but I noticed on my last drive that the tap-a-circuit I have connected here isn't charging my phone, so I'm thinking this entire block doesn't have power. Is that possible? What is the source of power for this block? Is it like a sub-panel that connects to the main fuse panel under the access panel? If so, which circuit should I check?
Pic is not of my install. Just what I could find online.
Thanks,
Chris
addliteness is online now
post #2 of 14 (permalink) Old 09-19-2017, 07:08 AM
Sold my Exige S
+TSRAGR's Avatar
Likely a CAN signal fault. Proceed with BOE's testing. The missing odo, tach, fuel are all fed via CAN from the ECU.
The fact your dash warning lights still function says power is making it to the dash.
The cabin fuse issue appears unrelated. Does your wiper function? Double check all fuses and the tap connection you made for the phone charger.
+TSRAGR is offline
post #3 of 14 (permalink) Old 09-19-2017, 07:28 AM
Giantmcm's Avatar
Also just redouble check your plugs, make sure they are in all the way. Had this issue once because my cable was not plugged in fully.
Maverick ML8 - Other daily
Giantmcm is offline
post #4 of 14 (permalink) Old 09-19-2017, 08:51 AM Thread Starter
Thanks for your reply.
I'd read somewhere that there are two plugs going into the dash module, one feeds the warning lights and the other speedo, odo, tach, etc, so that's why I thought it might just a power issue.
I'll double check all the fuses and the tap to see if anything is amiss there.
Your image indicates all the info that's on the CAN is what I'm, so it seems like you're saying makes sense. I just have no idea how I'm going to isolate where the issue is happening.
Chris
post #5 of 14 (permalink) Old 09-19-2017, 08:51 AM Thread Starter
@Giantmcm
Are you talking about spark plugs or something else?
Chris
post #6 of 14 (permalink) Old 09-20-2017, 08:40 AM
I see the kit involves a reflash of the Ecu
The can speed pre 2008 is 1Mbit and 500Kbit after that , also the data is slightly different ,
Maybe you had the wrong reflash
garw is offline
post #7 of 14 (permalink) Old 09-20-2017, 07:08 PM Thread Starter
I'll bring this up to the BOE guys. They've been helpful thought the trouble shooting process, but looks like the next step is sending the ECU back to be tested/reflashed. Theoretically, I could test the ECU in another Elise to narrow the problem to ECU or gauge cluster, but I don't know any owners locally that might be willing to try this.
If the ECU testing/reflash doesn't work, the next step is gauge cluster replacement, so it's ironic that you responded @garw . I've been following your dash updates all along and added my name to the list today. May as well order yours if I need a new one. I also sent a note over to @GregsRaceParts to ask about a binnacle. Seems like a good fit to have you guys do something together for the 8" screen.
Chris
post #8 of 14 (permalink) Old 09-21-2017, 06:40 PM
Giantmcm's Avatar
Originally Posted by Voicekiller View Post
@Giantmcm
Chris
Sorry Chris,
No I meant the plugs that go into the back of your display cluster.
Giantmcm is offline
post #9 of 14 (permalink) Old 09-26-2017, 08:52 AM Thread Starter
@Giantmcm @garw @+TSRAGR Thanks for all you input. Looks like BOE and I may have found a solution. I'll let you know shortly whether the fix works.
By the way, new username to match my Instagram handle. Bye Voicekiller, long live addliteness.
Chris
post #10 of 14 (permalink) Old 10-19-2017, 07:26 PM Thread Starter
BOE's fix work. Dash now fully functional.
post #11 of 14 (permalink) Old 11-21-2017, 11:49 PM
what is the solution?
zakria is offline
post #12 of 14 (permalink) Old 11-22-2017, 04:29 AM Thread Starter
Turned out there was an issue with the ECU flash. BOE reflashed and it worked.
post #13 of 14 (permalink) Old 11-22-2017, 11:21 AM
did you send the ECU or did they send you the files to do it? can you explain more
zakria is offline
post #14 of 14 (permalink) Old 11-22-2017, 11:23 AM Thread Starter
ECU had to go back to BOE.
