Elise intake camshaft - LotusTalk - The Lotus Cars Community
 3Likes
post #1 of 27 (permalink) Old 04-11-2019, 05:57 PM Thread Starter
Cnm2205's Avatar
My ‘05 Elise has check engine light on so couldn’t get it inspected. Had it sent to lotus dealer and they said the intake camshaft has excessive wear on the lobes. Has anyone run into this? And does a cost to fix of $4k sound right???????
Cnm2205 is offline
post #2 of 27 (permalink) Old 04-11-2019, 06:12 PM
kfennell's Avatar
Did you maybe google elise camshaft? Jesus.... And 4k is on the very high end.
kfennell is offline
post #3 of 27 (permalink) Old 04-11-2019, 07:15 PM
Less is Better
me73's Avatar
It's like saying, has anyone heard about this Facebook thing?
I'd say more than on the high end. More like in the stratosphere. Must be a dealer price.
me73 is offline
post #4 of 27 (permalink) Old 04-11-2019, 08:28 PM
You can replace it for less than $300. Not hard at all.
Nessal is offline
post #5 of 27 (permalink) Old 04-11-2019, 09:12 PM
glb
glb's Avatar
See last entry.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #6 of 27 (permalink) Old 04-12-2019, 06:23 AM
Atomic Swede's Avatar
Just to bring this full circle for the OP, yes, this is a very well documented and known issue. Many users of this community have done hours of research, posted theories on causes and logged their fix/installation experiences here. We would suggest you go to google, search the issue and you'll quick find a ton of information, including cost information (likely). Sorry you had to discover the issue this way - good luck getting it fixed.
Atomic Swede is offline
post #7 of 27 (permalink) Old 04-12-2019, 06:27 AM
Maybe not quite as diplomatic as I might have tried to be (note 'tried'), but a valid point. @Cnm2205 , these cars have been in the US for 14 years now. Some have 100,000+ miles on them. This board has been active (initially as EliseTalk) for longer than that. All of the behaviors of a US market Elise are pretty well documented here at this late date.
If your car is doing something, chances are beyond excellent that there are at least two threads about whatever it is, whether it's normal or not, and alternatives for what to do about it.
A weakness of this forum is that we have stickied posts, but no real organization for them. I'd like to see something like the "Book of Knowledge" at CrownVic.net, where really good informational and how-to posts are in one place organized by functional area of the car.
In the meantime, Google is your friend. My standard technique when I need to find out about something is to do a site specific search in Google. Example: "oil cooler" site:lotustalk.com. The top return on this is the very active "what do I do about the fact that my Elise over cools its oil" thread. This behavior is widely believed to be related to the frequency of intake cam wipes on Eliges, as a similar issue has not been observed on 2ZZ-GE engines in other vehicles.
steelypip is offline
post #8 of 27 (permalink) Old 04-12-2019, 06:52 AM
I've replaced 2. One with OEM that lasted 7K miles. Went with MonkeyWrench racing intake cam here https://www.monkeywrenchracing.com/p...0-intake-only/. Labor cost was 6 hours time. If someone is telling you it takes more time than that, move on to someone else.
In addition, I installed an oil temp and pressure sensor as I believe the issue is caused by oil being too cool when the engine allows you to jump on the high cam. I can confirm that when the water temp gets to 160 (the point at which the engine allows cam 2 engagement), the oil is way too cool.
My water temp/oil temp numbers are as follows:
Cold start and go - ambient temp mid 50s F.
Time----------- Oil Temp
4 Min 14 Sec , 120 degrees F
5 min 27 Sec = 140 degrees F
7 Min 33 Sec = 160 degrees F
9 Min 48 Sec = 180 degrees F This is when I would get on 2nd cam
At 4 minutes 14 seconds, water temp hits 160, which is when the car will LET you engage 2nd cam, however it takes another 5 minutes before the oil is warm enough, in my opinion as I wait for 180 degree oil temp.
iana likes this.
"If I've passed you on the RIGHT, you are in the WRONG lane!"
JFHughes08088 is offline
post #9 of 27 (permalink) Old 04-12-2019, 08:42 AM
Lotus Technician
$4k!!! holy crap, that is ridiculous. Where are you located? that job is a 5-6 hour job, plus, cam, rocker arm set, and maybe a valve cover gasket.
Best of luck to you. if you need any advice or help on this, feel free to shoot me a pm.
T.J.
Twaszak! is offline
post #10 of 27 (permalink) Old 04-12-2019, 11:24 AM
I was told that this was a $1000 repair job. How can it be 4k??
TERIB is offline
post #11 of 27 (permalink) Old 04-12-2019, 12:05 PM
cyow5's Avatar
Even $1k is high - this is a great intro job for anyone just starting to work on a car. You don't have to pull the rear clam, and none of the actual work is hard. It is well-documented, and can give you the confidence to work on more projects.
So $1k isn't bad for paying a shop to do it, but most of us would spend more time driving back and forth to a Lotus shop than this repair actually takes.
cyow5 is offline
post #12 of 27 (permalink) Old 04-12-2019, 01:38 PM
`08 Elise-SC-220
3carmonte's Avatar
@Cnm2205
When I need an intake cam, this is the one I'll get.
https://www.boefab.com/collections/e...am-stock-grind
Shhh...Secret Squirrel
3carmonte is offline
post #13 of 27 (permalink) Old 04-12-2019, 02:03 PM
Folks --
I am sorry if this is hijacking the thread, but it seems relevant . . . Can anyone tell me what the differences are between the BOE hardened stock-grind intake cam and the MWR hardened stock-grind intake cam, other than price? (It looks like BOE is $480 and MWR is $459)
BOE:
MWR:
Thanks!
-- Mike
Mike Edmonds is offline
post #14 of 27 (permalink) Old 04-12-2019, 02:29 PM
The is no difference. It's the same cam
post #15 of 27 (permalink) Old 04-12-2019, 06:55 PM Thread Starter
Cnm2205's Avatar
Hi thanks for replying to my post on the ‘05 Elise camshafts. I am located in Massachusetts....I had to bring the lotus to the lotus dealer bc no one around here was willing to “mess with it” do you think it’s an easy fix for a mechanic now that I know what’s wrong with it? Before it needed a diagnosis run on it
Cnm2205 is offline
post #16 of 27 (permalink) Old 04-12-2019, 10:29 PM
It's a Toyota engine -- so any mechanic that can work on a toyota engine should be able to do it.
TechnoHippie is offline
post #17 of 27 (permalink) Old 04-13-2019, 05:48 AM
cyow5's Avatar
Don't follow that logic too blindly though - had to help a local owner flush his oil after the Toyota dealer insisted that 5w30 was the correct oil. I stand by my previous statement that this is a great DIY project, and I also am convinced that DIY is the only way to make sure the person working on the car knows anything.
cyow5 is offline
post #18 of 27 (permalink) Old 04-13-2019, 05:58 AM
Dealer list on the cam and gasket is over 850 bucks. I could see with a very high rate and generous service time it getting close to 3 grand, but 4 is over the top.
Where in Mass are you?
exigegus is offline
post #19 of 27 (permalink) Old 04-13-2019, 06:01 AM
IT is the right oil for a Toyota.
I doubt that any damage would occur from running 10w-30
Still, point taken.
Care in choosing, and knowing things rather than being led are the best idea
exigegus is offline
post #20 of 27 (permalink) Old 04-13-2019, 06:53 AM
not your dad's puns
Turbopun's Avatar
+1 on yikes @$4k
I am located in Massachusetts....I had to bring the lotus to the lotus dealer bc no one around here was willing to “mess with it”...
Locals may be curious to know what dealership this is.
AM of NE perhaps?
because racecar
Turbopun is online now
Similar Threads
NEW TOYOTA INTAKE CAMSHAFT WITH ROCKER SET 13501-29025 $150 fgthwar Parts For Sale 2 10-19-2016 03:31 AM
Replacing the intake camshaft seight Powertrain (Engine, Transmission, etc) 12 03-16-2012 01:53 PM
FS: New Elise Exige 2ZZ Camshaft Cover Dave Parts For Sale 2 02-20-2012 12:35 PM
Elise S1 New Camshaft fitted - timing adjustment Rod196 Maintenance and Repairs. 11 10-22-2006 11:32 AM
