Elise LCD dash - Page 7 - LotusTalk - The Lotus Cars Community
 534Likes
post #121 of 1617 (permalink) Old 04-18-2016, 10:11 AM
SLKado's Avatar
^ what he said...
2005 LRG Lotus Elise
SLKado is offline
post #122 of 1617 (permalink) Old 04-18-2016, 11:45 AM Thread Starter
Originally Posted by SLKado View Post
^ what he said...
The auxiliary connector is additional to the main connector and does not need to be used .
the main connector is the plug and play connector compatible with the cars existing instrument cluster plug .
lt0302 and Coyne like this.
garw is offline
post #123 of 1617 (permalink) Old 04-26-2016, 12:40 AM Thread Starter
I have introduced a GPS receiver to the cluster
an additional dedicated connector, uses standard serial GPS module.
This will naturally be for lap timer functionality (on top of the current beacon input)
But since GPS has a 3 meter max accuracy im questioning how good it can actually be ,
At high speeds it wont matter a lot , but to compare it with a fixed beacon and receiver it cant be as good.
This is my opinion , but I'm interested in anyone's thoughts and experience with GPS timers .
I've only driven with a beacon timer.
garw is offline
post #124 of 1617 (permalink) Old 04-26-2016, 06:36 AM
SLKado's Avatar
What about embedding something like a sky pro xgps160 or similar? Or even a Bluetooth receiver to connect to it. It's what I use for solo storm and it's very accurate.
SLKado is offline
post #125 of 1617 (permalink) Old 04-26-2016, 06:45 AM
Or you can make it lighter, then simplify it. As light and simple as possible.
Coyne is offline
post #126 of 1617 (permalink) Old 04-26-2016, 08:50 AM
you guys asking a lot of functions..but all these comes at an added price,.
I like the basic configuration you had in the beginning to keep the cost down.
I've seen so many instances where ppl says they want this and that (not pointing at anyone) but because of added costs it came with, ppl ended up not buying at all...
Coyne likes this.
mpower1226 is offline
post #127 of 1617 (permalink) Old 04-26-2016, 10:01 AM Thread Starter
Yes true , the Gps will be usb type so it will be upto the end user to purchase an off the shelf item and plug it into the dash usb connector . Therefore it won't affect the price of the base unit . I did think about embedding the Gps onboard and having an external antenna , but it would up the price for all users .
garw is offline
post #128 of 1617 (permalink) Old 04-26-2016, 10:14 AM
100% this. Original config. Simple. Cheap. More people will buy it.
Corvus13, surferpkt and Kamsden like this.
Coyne is offline
post #129 of 1617 (permalink) Old 04-26-2016, 11:12 AM Thread Starter
I think expandability should be through usb
The latest pcb has 2 USB connectors , these will have the capability to be used for updating software via USB drive, GPS receiver , wifi adapter , extra serial interface , downloading logs etc Any USB device within reason .
So it's prepared for the future .
It will be produced as a basic base unit to ensure the lowest base cost
garw is offline
post #130 of 1617 (permalink) Old 04-27-2016, 08:20 AM
miro's Avatar
Hey Garw, have you fully fleshed out the customization/UI templating system? The only info I found before was asset names including offsets in a specific folder to upload. I'm just curious how much we can customize, aside from just swapping images (ie can you change the start/end point of the needle, or go to a bar-style tach similar to the s2000?) etc.
It would be cool if you could expand upon the specification for custom user templates.
Thanks for the updates BTW. Lots of us here at LT are very motivated for this.
miro is offline
post #131 of 1617 (permalink) Old 04-27-2016, 09:03 AM Thread Starter
It's still in the works ,
Trying to keep it simple and capable of make a good layout .
So far the concept is a collection of files each one an element on the screen .
So the contents of each file would be
Source image : "file name"
X: (coordinates)
Y:
Rotate: true/false
Slide: true/false
Origin : xy point for rotation
Channel:
Scale: (degrees or x y scaling)
This works ok , but the process needs to be sped up , as you can imagine tweaking values will take a long time if it's change-copy to usb stick-upload
every time.
So I'm thinking once the elements are on the screen you could plug in a mouse to the dash to move everything about if needed .
But it's still all conceptual as i don't want to offer anything unless it has a real world use for the end user .
garw is offline
post #132 of 1617 (permalink) Old 04-27-2016, 01:43 PM
miro's Avatar
X: (coordinates)
Y:
Rotate: true/false
Slide: true/false
Channel:
every time.
This is a great start.
Definitely keep the most extensive customization options available. We can always make programs to assist with layout as long as the layout is standardized (and this can be implemented after you ship). I take it "Channel" is the data channel / feed ?
So yes, this is useful for the real world user and a wysiwyg style editor could be made by users in the future (sounds kind of fun to make).
(This is just if your feature ends up taking too much time, I request that you keep the template system in since we can work around the potential inconvenience)
miro is offline
post #133 of 1617 (permalink) Old 04-27-2016, 11:44 PM Thread Starter
Yes channel is the data feed.
The intention is to provide an interface, and as you rightly said software to make it easier to generate the necessary files can be worked on later.
miro likes this.
garw is offline
post #134 of 1617 (permalink) Old 05-01-2016, 10:31 AM
maki's Avatar
Hello,
it's also available for the VX220??
an in km/h??
Greetings from Switzerland
Marcelgar
maki is offline
post #135 of 1617 (permalink) Old 05-01-2016, 07:35 PM
Updoots?
Coyne is offline
post #136 of 1617 (permalink) Old 05-02-2016, 08:22 AM
ulao's Avatar
yeah I have a tablet in my car for the dash player. It has GPS in it, so be nice to somehow tie in to the via BT or whatever.
Also are there plans to use a bootloader for the usb for updates?
darkSol likes this.
Solar Yellow 07 (225 whp)
Katana 2 SC
Sector 111 Pro rad radiator
Larini SE Exhaust and Lotus Euro Grills
alarm mod ( 80 feet )
all recalls complete.
upgraded front speakers to 5.25, back to 6.5 added a 12 inch sub
AikShii's Glove box.
Nexus gen 2 custom made radio Bessel.
Garw.co Dash.
_____________________________________________
Mr2 87 - sold (1997-2004)
Mr2 01 - Wife's toy now (2000-)
Elise 07 - My DD (2014-).
ulao is offline
post #137 of 1617 (permalink) Old 05-02-2016, 09:18 AM Thread Starter
Working hard on GPS Laptimer .
Getting the algorithm right to ensure accurate detection.
Aluminium enclosure is looking too expensive so considering plastic .
Not the same quality but it will be all hidden when mounted so it does not seem worth the extra 100usd
Coyne likes this.
garw is offline
post #138 of 1617 (permalink) Old 05-02-2016, 09:21 AM Thread Starter
There are 2 parts to the system , firmware is updated via rs232
And main software for the graphics is via usb drive
The firmware is only for major updates and less often and can be taken care of with a usb to serial cable.
ulao likes this.
garw is offline
post #139 of 1617 (permalink) Old 05-02-2016, 09:51 AM Thread Starter
Originally Posted by maki View Post
Hello,
an in km/h??
Marcelgar
I have not confirmed compatibility yet , but they are very similar so I would not rule it out.
garw is offline
post #140 of 1617 (permalink) Old 05-09-2016, 11:17 AM Thread Starter
garw is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
