Elise SC Service interval/recommendations - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By Glen
  • 1 Post By indifferent
post #1 of 11 (permalink) Old 09-05-2016, 07:01 PM Thread Starter
11EliseSC's Avatar
I purchased a 2011 SC with 19,500 miles, and will be picking it up in 2 weeks. It has only been driven 500 miles in the last 2 years. The dealer went through their "pre-delivery inspection" but I'm looking for independent recommendations on what service should be done after so little driving over the past 2 years.
If there is an existing thread covering this, and/or the Elise service intervals, let me know and please point me in the right direction and I'll check it out.
Thanks.
Life's too short to not drive what you want
2011 Elise SC Carbon Gray (1 of 1)
BRG Mini Cooper S RHD
'14 WRX WRB
'01 Subaru RS Coupe
11EliseSC is offline
post #2 of 11 (permalink) Old 11-24-2016, 01:42 PM
amoe's Avatar
Did you find out the service intervals? Is it any different than the S2?
I got the same year and model... and just drove the car 3500 km since the last oil change and filter change...
amoe is offline
post #3 of 11 (permalink) Old 11-24-2016, 04:56 PM
Nein Kinder
Glen's Avatar
@11EliseSC - I have a 2011 Elise SC that I ordered from the factory. If I were in your position, I'd consider the following:
Replace
- oil and filter
- coolant
- brake fluid
- serpentine belt
- washer fluid (to avoid bacteria / algae growth, it could well be the factory fluid)
Inspect
- brake rotors and pads
- shocks (for leaks)
- alignment
- tires (tread depth and date code: if 5 years or older, replace without regard to tread depth)
- air filter
- wiper blade
My recollection is that Lotus recommends replacing the serpentine belt on supercharged variants every 12 months. Contradicting that, the service manual calls out an inspection for supercharged Exiges every 3500 miles / 6 months. The serpentine belt in supercharged engines makes some sharp turns compared to normally aspirated engines, so they're concerned about accelerated wear. With the little use your car has seen recently, I'd be concerned about the belt taking a set and then breaking when stressed.
There are lots of other things I'd be looking at on a new car, but these are the maintenance items I'd start with.
Glen
glb and DonTano like this.
2011 Lotus Elise SC
Glen is offline
post #4 of 11 (permalink) Old 11-24-2016, 05:14 PM
indifferent's Avatar
Oh, and while at it, check the SC oil level. Easy to do and usually not required before say 35k, but I have a brand new MP62 SC that loses oil.....so worth a check. The oil only lubricates the gears in the nose that drive the two SC 'screws' so not the end of world if they go bad, but losing oil is a sign of bearing seal failure or incorrectly installed seals. Again, not a big deal, but worth finding out before funny noises arise.
captain chaos likes this.
indifferent is offline
post #5 of 11 (permalink) Old 11-25-2016, 05:46 AM Thread Starter
11EliseSC's Avatar
@Glen ; @indifferent ;
Thanks! This is exactly what I was looking for. Since I drove the car back home to VA in late Sept, I've driven short distances 2-3 times per week (~15miles) to keep everything operating and lubricated. Drives amazing, but didn't want to do too much too soon until I had this recommendation.
Now I'll start down this list to make sure I'm taking care of it correctly.
Thanks again.
post #6 of 11 (permalink) Old 11-25-2016, 05:59 AM Thread Starter
11EliseSC's Avatar
Based on what @Glen and @indifferent have recommended seems you'd be fine doing 3500km since your last oil change. Also depends on how many months it's been. My car basically sat unused for 2+ years before I bought it, which is often harder on a car than driving it 100 miles every day.
The service maintenance info in my manual doesn't differentiate between S2 and S3. I can post or send you a pic of what the Lotus manual schedule is if you don't have it.
'14 WRX WRB
'01 Subaru RS Coupe
post #7 of 11 (permalink) Old 11-25-2016, 10:13 AM
amoe's Avatar
Thanks guys this is very helpful. I drove the 3500km within these 3 weeks. I drove it down from Berlin to San Sebastian in Spain. The oil and oil filter were changed before I took the trip down, other than other maintenance checks. The car has some mileage on it (98,000 Km as of now). The owner before Daily drove it and so will I. Due to traveling quite often for certain periods I need to figure how to store it. Next trip I'm going away for 3 months. I presume I will have to do an oil service once I come back.
Can you @11EliseSC direct me to the manual please!
amoe is offline
post #8 of 11 (permalink) Old 11-25-2016, 01:47 PM Thread Starter
11EliseSC's Avatar
Sure thing! Sounds like you're enjoying your Elise. The maintenance schedule isn't included in the main owner's manual. Mine came as a separate small booklet tucked beside the main owner's manual. It's maybe 8 cm x 10 cm in size. See pics attached. These are from my maintenance schedule booklet. It's also in miles, so you'll have to convert to metric. Sorry if they posted sideways....can't seem to get the pics to rotate upright. Hope this helps.
'14 WRX WRB
'01 Subaru RS Coupe
post #9 of 11 (permalink) Old 11-25-2016, 04:07 PM
amoe's Avatar
Thanks great! thank you so much! Do you know any OBD2 readers that work for our model?
amoe is offline
post #10 of 11 (permalink) Old 11-26-2016, 06:54 AM
Nein Kinder
Glen's Avatar
@amoe - An excerpt from the factory shop manual showing maintenance intervals for the Elise and Exige is attached (pdf). This is the same info that @11EliseSC posted, just a little easier to read
Glen
File Type: pdf Pages from 17. OI Maintenance & Lubrication.pdf (432.2 KB, 128 views)
2011 Lotus Elise SC
Glen is offline
post #11 of 11 (permalink) Old 11-26-2016, 09:12 AM
amoe's Avatar
Sweet!! Thanks @Glen !
amoe is offline
