Elise seat angle - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 05-09-2019, 07:02 AM Thread Starter
Elise seat angle
When I purchased my Elise, the seat had been dropped down perhaps an inch. I did not mind that, but the seat no longer could be adjusted front-to-back, so I reverted to stock. This caused the seat to rotate a bit forward, so that I am sitting more upright, which I do not like. So, I expect that I will shim the front of the seat a bit. I wonder if the shims should be wedge shaped instead of flat, and whether a wedge should be placed in the rear, also. Not sure what angle I'm talking about: it will be small.
Anyone else experiment with this?
jon_bondy is offline
post #2 of 6 (permalink) Old 05-09-2019, 07:48 AM
CALtd's Avatar
I raised my seat .75" at the 4 corners for better visibility. I originally used open steel bar stock but they eventually deformed. I replaced it with solid aluminum 1" diameter .75" thick spacers. Others have used stacked washers to accomplish the same effect.
CALtd is offline
post #3 of 6 (permalink) Old 05-09-2019, 08:47 AM
Less is Better
me73's Avatar
I just stacked a couple of thick washers under the front end of the rails. 11:42 - 12:07 in my ShiftR video
me73 is offline
post #4 of 6 (permalink) Old 05-09-2019, 09:34 AM
lt1_fd3s's Avatar
@OP - Sounds like you had the TALLrails on your car when you got them... I love the angle they allow for the seat so I modified a set of the tall rails I had to keep the angle when I mounted the seat on a factory slider (since i'm short...)
WNC Tour Guide - WNC Drives (click me!)
'93 Vintage Red RX-7 - NA 20B
'06 Chili Red Exige - RIP 2017.12.01
'06 Ardent Red Exige Katana2 - try this again
lt1_fd3s is offline
post #5 of 6 (permalink) Old 05-10-2019, 08:02 PM Thread Starter
So some of you have raised the front of the rails by about 1/4 inch or so?
post #6 of 6 (permalink) Old 05-24-2019, 09:02 AM
www.theapexinn.com
kestrel74's Avatar
Yes, those are the "Down Low" seat rails ( Sector 111) and the stock rails were included with the sale of the car when it went to Long Island.....hopefully you got them...(?)
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
Similar Threads
Max ramp angle for Elise Exige jskrebs New Member Introductions 4 08-19-2014 05:40 PM
Elise Drive shaft angle??? gregV Lotus "Track" and Racing Cars 2 12-16-2012 04:19 AM
shoulder harness correct angle for safety? fishguy General Discussion (Lotus related) 8 09-01-2006 03:35 PM
!! Be careful unscrewing the window angle adjustment screws !! mackinaugh Maintenance and Repairs. 5 05-25-2005 03:30 PM
New driveway: What angle to road works? Ancient Wedgie Lotus Elise 4 08-11-2004 09:50 AM
