Elise security system - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Roundabout
post #1 of 4 (permalink) Old 12-01-2017, 05:35 PM Thread Starter
My 2005 Elise is in transport presently so no hands on....I've read snippits of comments talking about the negatives of the system.
What issues does it have and is it worth enabling? Will the thing lock you out/act up or whatever?
Reiver is offline
post #2 of 4 (permalink) Old 12-01-2017, 08:10 PM
glb
glb's Avatar
Some disable alarm completely, some remove it. Some lock doors manually, so they can always open them. NOTE: Manual door locks and auto alarm/door lock are 2 unconnected systems!
See #11, below:
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with mis-aimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
12. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
13. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. are wildly expense when purchased thru Lotus.
Plus:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #3 of 4 (permalink) Old 12-01-2017, 08:28 PM Thread Starter
Got it thanks...sorry I missed that section as I've seen that thread....I will use that info and remove the system from the auto mode to my key/fob selection.
Reiver is offline
post #4 of 4 (permalink) Old 12-04-2017, 10:29 AM
Roundabout's Avatar
I like the immobilizer, but don't use the alarm or central locks. I use *gasp* the key to lock and unlock the door. Most of the time the doors are left unlocked, since anyone could step over the door anyway.
darkSol likes this.
Roundabout is offline
