Grill Removal - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 09-01-2016, 04:24 PM Thread Starter
Grill Removal
I want to remove the front left intake grill from my 2005 Elise. From an expanded diagram of the body trim pieces, it appears that it is attached to the clam by a (vertical) screw, from above. I haven't removed any adjacent panels (center grill, wheel liner or front undertray) to locate this fastener. Does anyone know if I can gain access or does the clam need to come off (which sounds unreasonable)?
<12parsecs is offline
post #2 of 3 (permalink) Old 09-01-2016, 04:27 PM
glb
glb's Avatar
IIRC, the signal light is removed for access.
If you break tabs on the light, just (clear) silicone it back in place.
glb is offline
post #3 of 3 (permalink) Old 09-01-2016, 04:35 PM
Roundabout's Avatar
The signal light works for access. I also think that I removed the front grill and reached my long arm all the way in there and removed the screw. I use a small bungee cord to hold the signal lens in the clam. IMO, it's better than factory. It will stay in over bumps and it's easy to remove to replace the bulb. The plastic retention hook for the signal lens will break if it makes contact with the top of the crash structure, which most of them do. If your plastic base is till whole, you can grind a little bit off the top of the crash structure and probably prevent it from breaking in the short-term.
Roundabout is offline
