Help diagnose my high/pulsing idle - LotusTalk - The Lotus Cars Community
post #1 of 14 (permalink) Old 01-04-2013, 03:22 PM Thread Starter
06EliseTurbo's Avatar
I will start by saying I have searched the forum many times and only find links to esprit high idle, or new people worried about the normal rough idle.
Now the problem. At start up the car idles normally, but when I begin to drive any time I push in the clutch rpms go up to 2000 then pulse between 1500 and 2000. It seems to do this for varying lengths of time but will eventually return to normal.
It seems similar but more severe to a vacuum leak, but why would it return to normal eventually if there were a leak. This is in an 06 Elise with what looks like most of a Haas turbo kit.
Any help would be great.
06EliseTurbo is offline
post #2 of 14 (permalink) Old 01-04-2013, 03:36 PM
Ked67madison's Avatar
You can blip the throttle next time... See if it works.. 06 is a drive by wire and idle air control.. And dnt think u want to spend ur money on a whole new throttle body which is built into it... Also u can clean the throttle body out with some carb cleaner to help out
Ked67madison is offline
post #3 of 14 (permalink) Old 01-04-2013, 03:40 PM
What ecu do you have?
lotus90 is offline
post #4 of 14 (permalink) Old 01-04-2013, 03:46 PM Thread Starter
Tried giving it a little throttle, cleaned the maf and tb. Looked for vacuum leaks up top, I will try to get underneath tomorrow and inspect.
Sent from my EVO using AutoGuide.Com Free App
post #5 of 14 (permalink) Old 01-04-2013, 03:48 PM Thread Starter
Stock ecu with hks piggyback
post #6 of 14 (permalink) Old 01-04-2013, 09:07 PM
streetthrowback's Avatar
Take a can of air cleaner and spray around the tb and some hoses when the idle raises that's when you know that's the area of the leak. If its a vacuum leak
06 OCM elise r.i.p.
streetthrowback is offline
post #7 of 14 (permalink) Old 01-04-2013, 09:24 PM
cashxdr's Avatar
I cleaned my TB and ended up with the same problem. I found I had to set the trims back to zero to fix it
cashxdr is offline
post #8 of 14 (permalink) Old 01-04-2013, 09:38 PM
Trims?
06 OCM elise r.i.p.
post #9 of 14 (permalink) Old 01-04-2013, 10:13 PM
cashxdr's Avatar
Yes trims, ECU adjusts to a point. Had dealer hook up their diagnostic thingy are reset all my trims so the ECU starts with a clean page
Just like when you install a CAI or header and do not reflash it. The computer will dial it back to stock, aka, adjust its trims
cashxdr is offline
post #10 of 14 (permalink) Old 01-05-2013, 04:39 PM
sturgeongeneral's Avatar
Probably trims, but check to make sure one of your injector orings are not leaking.
05 Elise
56 VW Dune Buggy
[email protected]
sturgeongeneral is offline
post #11 of 14 (permalink) Old 01-05-2013, 06:44 PM Thread Starter
Why would the trims be off all of a sudden.
post #12 of 14 (permalink) Old 01-07-2013, 05:09 PM Thread Starter
fixed it and broke it at the same time
So just for fun I changed the MAF sensor and the idle problem went away as soon as I got on the road. However, when I went back to the auto parts store to return the old one I pulled in and shut off the car and it kept running. I had to stall the car to get it to turn off. My only idea is that the car needs time to get used to the new sensor. Any other Ideas?
post #13 of 14 (permalink) Old 01-11-2013, 02:40 PM
ChrisH's Avatar
The only way for the engine to keep running is for the ignition to still be on. The ECU controls both fuel injection and spark. Even if it was hot enough to "diesel" without spark, there should be no fuel if the ECU was off because the fuel injectors would not open (this isn't a carbureted car). This sounds like you have an electrical problem with the ignition switch or a relay.
ChrisH is offline
post #14 of 14 (permalink) Old 01-11-2013, 03:30 PM Thread Starter
Figured it out. I replaced a couple of blown fuses on the hks ecu that I didn't know about. I did this at the same time I changed the maf, and one of the fuses caused it to keep running after ignition was off. So the maf was the whole problem. As for the hks, its out as soon as hackish is done with his tuning program.
