How to fix - Hawk HP Plus Pads that are too Thick - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By dustinsterk
  • 1 Post By JFHughes08088
  • 1 Post By Jack
post #1 of 9 (permalink) Old 07-03-2019, 06:51 AM Thread Starter
Since I spend over 2 hours trying to figure out why my front pads were too thick, or why I was unable to depress the caliper piston 'far enough', I figured I would leave this here for others:
I ordered the following pads for the Elise:
Front:
Rear:
Finally after struggling to figure out why they did not fit, I noticed the black tab on the rear of the pad was sticking out further than the OEM pads. A little metal file work and they fit perfectly (pictures borrowed from another thread)! Hopefully this saves others hours of frustration and headache.
ReDRuM likes this.
dustinsterk is offline
post #2 of 9 (permalink) Old 07-03-2019, 12:09 PM
mcaden's Avatar
Good idea to post this... this is a common problem on more than one brand of pad.
mcaden is offline
post #3 of 9 (permalink) Old 07-03-2019, 02:02 PM Thread Starter
Thanks, I just hope is helps others.....I spent hours banging my head against the wall wondering why the caliper piston was no depressed far enough. Having worked on cars for years, I am a bit embarrassed it took me so long to figure this out.
post #4 of 9 (permalink) Old 07-03-2019, 03:15 PM
Plural of Lotus is Lotus
Dremel grinding disk makes short work of that little tab.........
dustinsterk likes this.
"If I've passed you on the RIGHT, you are in the WRONG lane!"
JFHughes08088 is offline
post #5 of 9 (permalink) Old 07-03-2019, 08:57 PM
This will help me out soon
jhentr is offline
post #6 of 9 (permalink) Old 07-03-2019, 09:24 PM
not-a-number's Avatar
I wouldnt remove that! Pads are going to fall out now!
not-a-number is offline
post #7 of 9 (permalink) Old 07-03-2019, 09:26 PM
A1 Automotive & Smog
Harix's Avatar
Nah.. The pins will hold them in place.
Harix is offline
post #8 of 9 (permalink) Old 07-03-2019, 09:41 PM
Think you put the pads in place on thee calliper
Then calliper gets mounted
h20ham is offline
post #9 of 9 (permalink) Old 07-04-2019, 08:31 AM
Jack's Avatar
With Hawk front pads, you have to grind the "nubs" flush with pad backing plate....been doing it for the last 10+ years.
Jack
2008 2-Eleven
2015 Exige CupR
Jack is offline
