My lotus has gone hay wire - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 33 (permalink) Old 06-11-2015, 09:30 AM Thread Starter
Lotus Driving Academy
102ndcar's Avatar
Originally Posted by swic0008 View Post
Given the accident and the panel smashing into the car, I think you might have pinched a harness somewhere. If you have wires touching, shorting, or severed, pretty much ANYTHING could happen, and your symptoms are pretty all over the place
the lip on the front of the panel wasn't in all the way and it sucked it down, it didn't actually come all the way off, just the front part of it dragged on the ground, I inspected the car visually underneath and everything looked fine. I didn't have any problems except the immobilizer but I think that was due to the a/c comp pulley burning up on me. Im about to go down and mess with the battery and test voltage. Will report back later
102ndcar is offline
post #22 of 33 (permalink) Old 06-11-2015, 12:23 PM Thread Starter
102ndcar's Avatar
After pulling the battery and inspecting, the positive terminal had a crack in it, went to autozone bought new ones, came back cleaned battery and put all new goodies back on and everything is fine so far, no more flickering lights or anything. Battery is also reading 12.6v. about to go for test run, push to start will still act up if I had to guess but that is probably the switch as said before. Hopefully this was it
102ndcar is offline
post #23 of 33 (permalink) Old 06-11-2015, 01:14 PM
sturgeongeneral's Avatar
Congratulations! Let us know if you still have switch problems.
05 Elise
56 VW Dune Buggy
[email protected]
sturgeongeneral is offline
post #24 of 33 (permalink) Old 06-11-2015, 01:39 PM
glb
glb's Avatar
It's surprising how often people miss that entire slot (male/female?) thing.
Good for you that you found the battery clamp issue.
glb is offline
post #25 of 33 (permalink) Old 06-12-2015, 03:13 PM Thread Starter
102ndcar's Avatar
I am still having switch issues with the push to start :/ Is it pretty likely that the switch has gone bad? I feel like you have to push it just right
102ndcar is offline
post #26 of 33 (permalink) Old 06-14-2015, 05:08 PM Thread Starter
102ndcar's Avatar
Where do you recommend I order a replacement switch?
102ndcar is offline
post #27 of 33 (permalink) Old 06-14-2015, 07:10 PM
Walk through on troubleshoooting:
Lotus Exige Start Button Failure and Diagnosis
New starter harness and button:
http://www.mylotusgarage.com/index.p...num=A121M0027S
http://www.mylotusgarage.com/parts/A121M0026S
Buying the harness might just be a convenience factor and to rule out that as a problem as well.
Fermi is offline
post #28 of 33 (permalink) Old 06-14-2015, 07:31 PM
Mylotusgarage.com
05 Elise
56 VW Dune Buggy
[email protected]
post #29 of 33 (permalink) Old 06-15-2015, 07:15 AM
So some things got better but still problems. Before you resign yourself to replacing the start switch, consider this. A crash could have jarred loose a plate or 2 in the battery, which could cause these symptoms. I would put a volt meter on the battery while driving, or when intermittent symptoms occur to see if battery voltage is fluctuating. In fact, put a meter on it while trying to crank using the start button. This will show either 1) no voltage drop while pushing button indicating a bad switch, or huge drop indicating a bad battery.
wdonovan is offline
post #30 of 33 (permalink) Old 06-15-2015, 06:28 PM Thread Starter
102ndcar's Avatar
The push to start issue has been going on for quite some time, but I will try this anyways, thanks for the advice
102ndcar is offline
post #31 of 33 (permalink) Old 06-15-2015, 06:32 PM Thread Starter
102ndcar's Avatar
My Lotus Garage
My Lotus Garage
Thanks joe
102ndcar is offline
post #32 of 33 (permalink) Old 07-31-2015, 08:29 AM Thread Starter
102ndcar's Avatar
Bought a new start switch, think its the harness so now i'm going to wait on that from Lotus Garage. Start switch didn't do anything, but my light in old one didn't work so its a nice touch to looks with the new one at least
102ndcar is offline
post #33 of 33 (permalink) Old 08-25-2015, 10:02 AM
How did the new harness work? Having a few electrical issues of my own, thinking about replacing the harness.
bakerbettendorf is offline
