quoted $6000 - $7000 for Elise clutch ? - LotusTalk - The Lotus Cars Community
 17Likes
post #1 of 36 (permalink) Old 05-30-2019, 12:02 PM Thread Starter
Hi all,
I'm new here because I've never owned a Lotus but always wanted one. I'm focused on finding a '05-'07-ish Elise.
Still shopping, but I called the local dealer and an independent shop that advertises they work on Lotus cars to ask if they could do a PPI when I locate a car. (They both can)
Then a surprise- the guy at the independent shop (which also does all the Italian exotics) mentioned in passing that a clutch replacement on the Elise was $7500 (ouch). I called the local Lotus dealer and he quoted $6500.
I wasn't expecting Lamborghini repair prices. Are these numbers what I should expect ?
thanks in advance
Jeff
Duetto-69 is offline
post #2 of 36 (permalink) Old 05-31-2019, 07:47 PM
Robocop305's Avatar
You can get a new clutch for less than $2,000 installed!. Look for an independent indy.
marcinr likes this.
Robocop305 is offline
post #3 of 36 (permalink) Old 05-31-2019, 09:13 PM
Mobius97's Avatar
The clutch job on an Elise/Exige is nowhere near that much. Expect from a reputable dealer or an indy shop to charge you normal figures....say in the ballpark of a grand or below.
Your mechanic may be thinking of the Evora that requires extensive labor to do the repair job. $4-6k is common since you have to pull the engine to replace the clutch in an Evora.
Even with that said...I'm 50k miles in and haven't had to do it on my Evora. With my Elise and aftermarket supercharger, still rocking the stock clutch with over 70k.
PNWRider and Chemgee like this.
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
post #4 of 36 (permalink) Old 06-01-2019, 05:15 AM Thread Starter
Thanks for the answers, guys...I was beginning to wonder if I had to re-think Lotus ownership.
Both the dealer and the indy shop told me the rear clamshell has to be pulled to do the clutch on an Elise, and it was 50+ hrs. of labor total. Does that sound right ?
Surely they aren't mixing up an Elise with an Evora (the Evora never came up in our conversations). The indy shop even mentioned and Elise clutch job was slightly more than a Lambo clutch.
That leaves me wondering who to look to in the Houston area for Lotus service however.
Cheers
Jeff
post #5 of 36 (permalink) Old 06-01-2019, 08:43 AM Thread Starter
Thanks for responding. That eases my mind some, although I'm not sure where to go for Lotus service in the Houston area now.
Both the indy shop and the dealer said the rear clamshell had to be removed for an Elise clutch job which was 50+ hrs. labor.
Surely they aren't mixing it up with the Evora, which never came up in our discussions.
Jeff
post #6 of 36 (permalink) Old 06-04-2019, 07:15 AM Thread Starter
Hmm..my quick replies aren't getting posted. I may not know some rule, so I'll try "regular" reply
First, thanks much for the info in your replies.
both the indy shop and the dealer said the rear clamshell had to come off and the total labor was > 50 hrs. The Evora never entered the conversation so I'm assuming they weren't confusing the two cars.
Since then, I've also contacted half a dozen Lotus dealers across the U.S. asking for a ballpark estimate to do an Elise clutch replacement. A couple would not return my calls, and a couple others said they hadn't worked on an Elise for some years and didn't remember what it would cost. I'm in a seemingly endless text exchange with a couple more still trying to get an estimate.
Am I going about this all wrong some way ?
Cheers
Jeff
post #7 of 36 (permalink) Old 06-09-2019, 10:29 AM
Shirp's Avatar
The rear clam does not need to be removed. You can jack the rear up and remove an engine mount or something to drop the motor some. I've read how to DIY, but it's been a while.
My Prelude rebuild.
http://www.preludepower.com/forums/s...d.php?t=256458
2008 Lotus Elise | Storm TI | Touring Pack | A/C Insulation Mod | Aluminum Carpet Buttons | JBL GTO Series Speakers | Alpine iDA_X100 | GRP Trunk Strut | darthHOLDER | re-ENFORCER | BOE TOC Oil Pan | Pro Alloy Rad | BOE Toe Links
Shirp is offline
post #8 of 36 (permalink) Old 06-09-2019, 11:49 AM
lotus72Eur's Avatar
For DIY:
A. You can change the clutch out without removing the clam, but it a real knuckle busting job. Have to remove motor mount and tilt the engine to slide the transmission off. Really a bear trying to slide back in.
B. Removing the clam is really not a big deal. Can even be done by one person if careful. Makes changing the clutch much easier. Also a good time to think about installing clam hinge.
C. In my opinion, it’s easier to completely remove the drivetrain to change the clutch then fuss with it in the car. Can also get to the dreaded u-tube in the coolant system. NOTE: for DIY you need the proper tools; ramps, jacks, jack stands, engine hoist to name a few.
D. The repair quotes seem extremely high, the parts aren’t that expensive even for upgrade clutch and flywheel.
E. Doing it yourself is a great way to learn about your car. Get a manual, go slow, double check each step and get a great sense of accomplishment.
"It always seems to be something!"
lotus72Eur is offline
post #9 of 36 (permalink) Old 06-09-2019, 12:47 PM
kfennell's Avatar
Having now done both, the elige many times.
Elige takes 12 hours your first time if you're not big on working on cars a lot, and about 3 hours your 6th time.
Evora takes 30++ hours and it is what it is. What a terrible job.
kfennell is offline
post #10 of 36 (permalink) Old 06-09-2019, 04:28 PM
gray's Avatar
Holy hell. At $7000 a pop, I'd learn to do nothing but clutches.
I'd buy a truck, some tools and a portable lift, and drive back and forth across the country.
Do 25 a year and I'd be clearing $175k for like maybe two months of work total, being diligent about scheduling.
Drives a Prius (clearly knows nothing about cars).
Lots Of Trouble Usually Serious
Leave Out The Unnecessary Stuff
gray is offline
post #11 of 36 (permalink) Old 06-09-2019, 04:36 PM
kfennell's Avatar
It takes a whole week of 8 hour days to do one. I suspect that they also do things like change the water pump while in there. There is also cost for the materials.
kfennell is offline
post #12 of 36 (permalink) Old 06-09-2019, 04:51 PM
tommyc's Avatar
Jeff, You can do this. There are many post with a step by step guide. Clam on no problem. There are some tools you will need such as a low lift transmission jack from harbor freight and a good set of pry bars to remove axle. Yes mine took 2 days but most of that time was waste manhandling the transmission to get it back in. With the jack it was 5 minutes. Also be sure to get new Flywheel bolts and clutch cover bolts from arp. Monkeywrench racing sells them.I will try to find the instruction posts. Do it yourself and be assured everything is done correctly Tommy
05 elise ardent red sport touring VF1 s/c, pro rad, arquay twin, etc etc etc
05 elise GG sport touring BWR s/c Charliex s/p dent in chassis=total loss
17 BMW 428i conv wifes car
03 GMC Yukon
90 eclipse gsx 420 whp sold
04 civic si sold
13 Ford focus ST
tommyc is offline
post #13 of 36 (permalink) Old 06-09-2019, 04:57 PM
gray's Avatar
While my post was kind of a joke, I suspect we're talking about different things since your own post indicated that an Elise/Exige clutch could be done in ~3 hours.
I can understand the Evora clutch being so expensive, given the labor and time required, but for a 3-hour job? Even with the cost of materials, that's still got to be a six-figure salary at $7k each doing just 25 a year.
gray is offline
post #14 of 36 (permalink) Old 06-10-2019, 04:32 AM
Elise Guru
fzust's Avatar
I think I have pulled the transmission in an Elige more times than everyone else combined.(maybe not but it feels like it).
Removing the clam makes life alot easier, but I've done it both ways. Clam hinge is worth every penny.
Clutch takes 20 minutes once trans is off.
I recommend our lightweight flywheel while you are in there. ACT HD-SS is the perfect stock replacement AND upgrade for the Elige.
My record to take the trans out on the XP Elise, starting with wheels on the ground is 42 minutes.
My record to put in is 48 minutes, but then I saw the throw out bearing and fork on the floor! So now I don't time how long it takes to put in!
Jim-C, Mr.C, Kubera and 1 others like this.
Winning Suspension
6UL wheels
fzust is offline
post #15 of 36 (permalink) Old 06-10-2019, 06:33 AM
kfennell's Avatar
You told me that was round trip in 45 minutes before! I thought that would be impossible! Yeah I can get the transmission out in 42 minutes I bet. Not sure if I could get it back in 48, maybe with an experienced helper.
kfennell is offline
post #16 of 36 (permalink) Old 06-10-2019, 08:43 AM
Lotus Technician
For the record....
I have been with 3 different Lotus dealers, and we always charged the same..
- 10 hours labor (at $125/hr) - $1,250
- Parts (varies, depending on what you chose) - roughly $1,000
- Transmission fluid - (3 quarts, i usually use MT90 at $15-$20 -bottle) $60.00
Total - Roughly - $2,310.00
Hope that helps.
T.J.
Harix and dspecgsx like this.
Twaszak! is offline
post #17 of 36 (permalink) Old 06-10-2019, 08:48 AM
Butters's Avatar
As much as it pains me to say it, removing the engine from the car is the easiest way to do it. You CAN slip the trans off the engine in situ but it requires tilting the engine a little bit which can be a bear, not to mention mating the trans back to the engine. It's certainly possible, but halfway through, you'll be wishing you'd just taken the engine out. For those with AC, this makes things a bit more complicated as you'll have to evacuate the refrigerant and then refill --- something that usually only shops are setup for.
2007 SUZUKI SV650 Track bike.
Butters is offline
post #18 of 36 (permalink) Old 06-10-2019, 10:55 AM
purveyor of lightness
darkSol's Avatar
I did this at home in my garage in Feb 2018 - installing the BWR ubertranny (and new clutch/flywheel). Taking my sweet-ole-time with lots of breaks it took me about 17 hours. I did pop my BOE clamhinge to disconnect things up top but it is certainly possible without doing so.
I swear six of those hours was on my back trying to power lift the transmission back up and getting it to align/set properly but that's my fault for not having a transmission jack or a helper.
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1736lbs.
darkSol is offline
post #19 of 36 (permalink) Old 06-10-2019, 10:59 AM
Race & Pamper
Kubera's Avatar
@fzust you are the man!
Kubera is offline
post #20 of 36 (permalink) Old 06-10-2019, 11:39 AM
Supporting Vendor
shinoo's Avatar
Originally Posted by Twaszak! View Post
For the record...Total - Roughly - $2,310.00
TJ quotes the going rate. Some charge less but most charge in this range.
Harix and Twaszak! like this.
shinoo is offline
