Rear clam hinge lift struts - LotusTalk - The Lotus Cars Community
 5Likes
post #1 of 25 (permalink) Old 06-13-2019, 05:47 AM Thread Starter
Jetblast's Avatar
Finally, I installed gas lift struts to augment my BOE Fab rear clam hinge, I should have done this years ago when I installed the hinges. I used a strut with just enough force to hold the clam mid-way open, it really makes the hinge feel like a factory piece. Much less force is needed to move the clam; I can open and close it with one hand from either the left or right side of the car; you don't have to open from the rear like you had to do with the stock BOE hinge.
To anchor the chassis side of the struct I fabricated a couple of simple mounts and used an existing hole in the subframe to secure them, I drilled an 8mm hole in the BOE hinge for the clam side mount. The lift struts I added were from Bansbach easylift P/N D3D3-42-150-385--006-220N 6" (150mm) Stroke 15" (385mm) Extended Length Force: 49.40 lbs (220N) (link below)
https://store.easylift.com/clearance...qmoCKUpcsacmp0
Remember, it's a Lotus, each one is different, your mileage may vary...
Jetblast is offline
post #2 of 25 (permalink) Old 06-13-2019, 05:50 AM
kfennell's Avatar
Thanks for sharing the drawings and everything, that looks very useful!
kfennell is offline
post #3 of 25 (permalink) Old 06-13-2019, 06:08 AM
David Craig's Avatar
Nice!
I'd love to be able to get at the engine so easily.
2009 Saffron Elise
David Craig is offline
post #4 of 25 (permalink) Old 06-13-2019, 06:21 AM
eldonz's Avatar
Fantastic!
Two questions. First, why did you only use one strut and not put a strut on both sides? Two, how close are they getting to the exhaust? These struts do not like heat and I'm wondering that track use may get them too warm.
Great Job,
Eldon
eldonz is offline
post #5 of 25 (permalink) Old 06-13-2019, 07:47 AM Thread Starter
Jetblast's Avatar
Originally Posted by eldonz View Post
Fantastic!
Great Job,
Eldon
Eldon, I did use two struts (one on each side), I only posted pictures of one of them, sorry about the confusion. The lift struts are rated to 80C (176F) so they're fairly robust, to address the heat I'm using a heat shield on the left side lift strut to shield it from the 180 degree bend in the exhaust, I think the right side is far enough away to stay cool. I'm fabricating the heat shield today so I'll post pictures later. I've removed most of the factory heat shield from around the exhaust and I'm using a custom rear valance panel that allows more airflow; things stay pretty cool back there as it is.
Jetblast is offline
post #6 of 25 (permalink) Old 06-13-2019, 09:06 AM
eldonz's Avatar
Some pictures would be great. On my Exige, I do not have that hole unless you drilled yours out. Also, the Exige clam weights a little more than the Elise clam so I'm wondering how close the strength of the rods are.
Also, where in Iowa do you live? I grew up in Cedar Rapids and went to school at ISU even though I'm a Hawkeye fan!
Later,
Eldon
eldonz is offline
post #7 of 25 (permalink) Old 06-13-2019, 09:38 AM
evansp60's Avatar
THIS!!
My vote for MOD of the year!!
Could you post a couple of closeups of the install mounts for the strut?
Thx
Stay Tuned.....
evansp60 is offline
post #8 of 25 (permalink) Old 06-13-2019, 11:36 AM
Rasmutant's Avatar
Very nice! Good to see you back at it Jetblast.
Rasmutant is online now
post #9 of 25 (permalink) Old 06-13-2019, 12:11 PM
purveyor of lightness
darkSol's Avatar
Love to see video of it opening/closing. Kudos!
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1736lbs.
darkSol is offline
post #10 of 25 (permalink) Old 06-13-2019, 04:49 PM Thread Starter
Jetblast's Avatar
Thanks man, it's great to have time to work on it again. I'm hoping to have it driving again soon as time and budget allow.
Jetblast is offline
post #11 of 25 (permalink) Old 06-13-2019, 04:52 PM Thread Starter
Jetblast's Avatar
Later,
Eldon
I'm not sure about the weight of the Exige clam, these would still provide quite a boost over not having anything, but they also have plenty of other lift struts with higher force ratings. I"m in central Iowa in the Des Moines metro area, and I'm an ISU grad too!
Jetblast is offline
post #12 of 25 (permalink) Old 06-14-2019, 05:40 AM
eldonz's Avatar
I ordered a set of what you used. I looked at some others but the force level goes up quite a bit. I'll try these and if I feel I need more, I'll find some.
I use to autocross with DMVR when I was in college and while I was still in the MidWest area. In fact my current region of record is still DMVR.
Take care,
Eldon
Jetblast likes this.
eldonz is offline
post #13 of 25 (permalink) Old 06-16-2019, 06:11 AM Thread Starter
Jetblast's Avatar
Take care,
Eldon
I'm working on a revised strut mount bracket design to provide a little better clearance to some components and a cleaner aesthetic. when I'm done I'll send you the new bracket design if you want.
Jetblast is offline
post #14 of 25 (permalink) Old 06-16-2019, 07:03 AM
eldonz's Avatar
Yes, please do that.
Thanks,
Eldon
eldonz is offline
post #15 of 25 (permalink) Old 08-02-2019, 10:05 AM
Bumping this....came up when lookign for pics of the clam hinge. This looks like a great modification!
Any updates as noted or additional pics?
CRG53 likes this.
2010 Lotus Exige S240
2001 BMW M5
2017 Ford Raptor
2018 Jeep Grand Cherokee Trackhawk (wife-mobile)
REKIII is offline
post #16 of 25 (permalink) Old 08-02-2019, 10:09 AM
CRG53's Avatar
That will definitely be one of my winter projects.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is offline
post #17 of 25 (permalink) Old 08-02-2019, 10:44 AM
darkSol's Avatar
Need video of it opening and closing!
d.a..v...i....d
darkSol is offline
post #18 of 25 (permalink) Old 08-02-2019, 01:12 PM
Falsey's Avatar
Definitely adding this to my hinge, very rarely do I get an extra set of hands to help tilt.
Falsey is offline
post #19 of 25 (permalink) Old 08-02-2019, 02:03 PM
Butters's Avatar
This is fantastic! Must make it so much more pleasant to operate.
2007 SUZUKI SV650 Track bike.
Butters is offline
post #20 of 25 (permalink) Old 08-02-2019, 02:51 PM
CQI = Continuous Quality Improvement at its finest. Nicely done!
ID2F is offline
