Removing Factory Sandwich Plate Hardware - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By glb
  • 1 Post By the1tonton
post #1 of 12 (permalink) Old 07-31-2019, 03:22 PM Thread Starter
richthom's Avatar
Changing out the oil filter sandwich plate and decided to change the center hardware with MWR parts. Going OK till I went to remove the last piece with a 30mm 6pt socket. I can not break it loose. Only have about 3-4 mm of engagement with the socket (I ground off all the lead). I'm doing this from under the lying on my back. Any suggestions ?
Richard 2006 Elise
richthom is offline
post #2 of 12 (permalink) Old 07-31-2019, 03:28 PM
Obeisance's Avatar
If i remember correctly, that last inner bolt required what felt like an unreasonable amount of torque to remove. So much so that I had to get help. I recommend an extension bar on the socket wrench, but I'm not sure how much this helps if the head was ground off. I've seen videos of welding a new bolt on to connect a good stud to broken off bolts.
Obeisance is online now
post #3 of 12 (permalink) Old 07-31-2019, 03:48 PM
glb
glb's Avatar
Haven't you always wanted a compressor and air tools??
Now is the time, perhaps.
What do you mean "I ground off all the lead"??
A garage nearby can get it loose, then tighten it enough for you to get home???
3carmonte likes this.
glb is online now
post #4 of 12 (permalink) Old 07-31-2019, 04:00 PM Thread Starter
richthom's Avatar
I ground off the chamfer on the socket to get the most engagement.
Richard 2006 Elise
richthom is offline
post #5 of 12 (permalink) Old 07-31-2019, 04:13 PM
kapps's Avatar
I think I used an extension on a 1/2" drive wrench so I could get the wrench down by my chest and get a good amount of torque on it. Make sure you're going in the right direction. You could also use a breaker bar for more leverage. The hex on that adapter is pretty thin so grinding down the socket was a good idea.
1970 Europa S2 Carnival Red
2005 Elise Krypton Green
kapps is online now
post #6 of 12 (permalink) Old 07-31-2019, 05:20 PM
`08 Elise-SC-220
3carmonte's Avatar
I'll second glb's take on this. An impact wrench can apply torque in a way that brute breaker bar force cannot.
Shhh...Secret Squirrel
3carmonte is offline
post #7 of 12 (permalink) Old 08-01-2019, 03:04 AM
Make sure your new MWr hardware fits through your new sandwich plate
exigegus is online now
post #8 of 12 (permalink) Old 08-01-2019, 07:36 AM
the1tonton's Avatar
Use an impact. Get this https://www.homedepot.com/p/Milwauke...E&gclsrc=aw.ds
Buy once cry once!
Be careful with the impact...the insert is steel into aluminum. I would heat up before you go breaking things.
I used a celica 2zz filter adapter on mine. $15 at toyota dealer. i removed the oil cooler crap and never looked back. Temps are perfect. May add small setrab later.
darkSol likes this.
2007 Exige S - in the works...
the1tonton is offline
post #9 of 12 (permalink) Old 08-01-2019, 02:13 PM Thread Starter
richthom's Avatar
Success, I forgot I had 1/2 impact air tool (moved 4 or 5 times since using it). It was off in less than 5 seconds. Every thing back together. Thanks for all the advice.
Richard 2006 Elise
richthom is offline
post #10 of 12 (permalink) Old 08-01-2019, 02:15 PM
glb
glb's Avatar
Good for you, but now we're worried about your memory......
glb is online now
post #11 of 12 (permalink) Old 08-01-2019, 03:02 PM Thread Starter
richthom's Avatar
I'm only 69
Richard 2006 Elise
richthom is offline
post #12 of 12 (permalink) Old 08-01-2019, 04:27 PM
glb
glb's Avatar
I'm only 72.
What were we talking about??
glb is online now
