Shift Cable Damaged? - LotusTalk - The Lotus Cars Community
 1Likes
post #1 of 28 (permalink) Old 08-23-2017, 08:49 PM Thread Starter
Roundabout's Avatar
Is this cable with the inner showing bad?
Roundabout is offline
post #2 of 28 (permalink) Old 08-23-2017, 08:59 PM
silicon's Avatar
Both of mine had the shrink wrap slide off and are rusty. Been that way for probably 60k miles. Looks fine to me.
Blackwatch - Black Emblems, Penske SA|Radium - Catch Cans, Coolant Tank, Intercooler Couplers, Green Ti Lug Bolts, Fuel Hose, Fuel Pressure Gauge|RLS - Green Intercooler Tubes|Mororso Hard Ano Red Baffled Oil Pan|Shift-I|BOE ProAlloy, BOELinks, Diffuser Brace, Quarter Stick|S111 BBHook, Spal Fans, Floormats|Fast Toys Green Carpet Buttons
silicon is offline
post #3 of 28 (permalink) Old 08-23-2017, 10:27 PM
That's bad. On it's way to complete failure and leave you stranded...It happened to me.
https://www.lotustalk.com/forums/f163...-cable-400330/
///MD is offline
post #4 of 28 (permalink) Old 08-24-2017, 04:19 AM
David Craig's Avatar
I am with silicon. Mine are like that and have been for a while. I have 190,000 km on my car.
2009 Saffron Elise
David Craig is offline
post #5 of 28 (permalink) Old 08-24-2017, 08:13 AM
Supporting Vendor
shinoo's Avatar
This is what can happen next...we've seen it many times now.
If your budget allows, cables likes ours are a worthwhile upgrade as the strength and feel will improve.
Plus the peace of mind is another bonus...
shinoo is offline
post #6 of 28 (permalink) Old 08-24-2017, 10:59 AM
Nein Kinder
Glen's Avatar
@Roundabout - See the area on the wire-wound sheath right next to the crimped end which has no rust compared to the the rest of it which is rusted? That may be evidence that the sheath has pulled out of the crimped end by at least the amount not rusted. I'd be replacing the cable.
Glen
2011 Lotus Elise SC
Glen is offline
post #7 of 28 (permalink) Old 08-24-2017, 11:34 AM Thread Starter
Roundabout's Avatar
Glen
That's exactly what I was thinking. The non-rusted area must have pulled out or have some magical substance to prevent rust on just that portion. I setup the image so that you'll get the hi-res version if it's clicked on. The hi-res photo makes the clean section of the cable more obvious.
post #8 of 28 (permalink) Old 08-24-2017, 11:48 AM
Habious's Avatar
This thread makes me want to walk outside and look at my shifter cables!
2011 Lotus Elise REV300 - Starlight Black Metallic
2014 Jeep Grand Cherokee SRT
2011 Tesla Roadster 2.5 - Midnight Blue (sold)
2004 Chevy SSR Convertible Pickup - Ultra Violet (sold)
My CarPC YouTube Video - - - - - - - - - - - - - NY Times Article
Habious is offline
post #9 of 28 (permalink) Old 08-25-2017, 06:06 AM
countryboyshane's Avatar
That is REALLY bad. Replace immediately. You're taking a big gamble driving around with it like that.
2005 Lotus Elise, naturally aspirated and always at redline!
2018 NASA Great Lakes Region TT4 Champion
countryboyshane is offline
post #10 of 28 (permalink) Old 08-25-2017, 06:35 AM
SS Lotus Elise's Avatar
How hard is it to replace the cables?
SS Lotus Elise is online now
post #11 of 28 (permalink) Old 08-25-2017, 07:43 AM
eldonz's Avatar
Depends on a couple of things.
First, do you have a lift? Can be done without one but not as easily.
Second, can you tilt your clam? You are going to have to be able to get the shifter mechanism on the trans. There are a lot of hoses in the way which makes it a pain.
Minimum time would be about two hours but as long as a day and a lot of choice words trying to reach all of the nuts and bolts.
Later,
Eldon
SS Lotus Elise likes this.
eldonz is online now
post #12 of 28 (permalink) Old 08-25-2017, 11:10 AM Thread Starter
Roundabout's Avatar
I don't have a lift, but I have a clam hinge. I bought some used cables from the for sale area, but if this is a pain, I may buy some aftermarket replacements. The car only has 35k miles on it. I guess the shifter cables are just a weak point.
On my other manuals with rod shifters, it's not hard to put the trans in 3rd gear and drive it home like that. This is my only cable-shifted car. Can I manually engage a gear?
post #13 of 28 (permalink) Old 08-25-2017, 11:30 AM
eldonz's Avatar
Yes, you can shift the car by hand if you can get your hand down in there. The other option is to put the car in the air, pull the bottom trays and reach around the front of the trans. Neither is going to be much fun but doable.
Later,
Eldon
post #14 of 28 (permalink) Old 08-25-2017, 06:31 PM
Nein Kinder
Glen's Avatar
I don't have a lift...
I changed out my cables without a lift - no problem. You do need access to the underside and I achieved that by putting the car up on Rhino ramps stacked on 4-1/2" of blocks. I do recommend you tilt your clam back though (or for others reading this who don't have a clam hinge, remove the clam). Access with the clam in place is possible but I'd describe it as extremely difficult and frustrating and likely to take more time than tilting (or even removing and replacing) the clam.
@Roundabout - I definitely recommend aftermarket cables over the OEM cables. I have a set of SSC cables purchased before S111 started marketing theirs. The difference was so apparent I threw away my 1 year old OEM cables - they were junk in comparison. I'd expect the S111 cables - now InoKinetic - to be just as good as the SSC cables.
Glen
2011 Lotus Elise SC
Glen is offline
post #15 of 28 (permalink) Old 09-18-2017, 06:01 AM
Mine at the 8 year, 190,000 km mark. I think they have been this way for many years.
2009 Saffron Elise
post #16 of 28 (permalink) Old 09-18-2017, 04:56 PM
Supporting Vendor
shinoo's Avatar
Give us a call and we can talk you through the installation.
shinoo is offline
post #17 of 28 (permalink) Old 09-18-2017, 05:22 PM
Nein Kinder
Glen's Avatar
I can't tell, is this a cry for help? Or is this like the guy with the lifted truck that drove through mud on the weekend then runs around all week that way?
Glen
2011 Lotus Elise SC
Glen is offline
post #18 of 28 (permalink) Old 09-19-2017, 11:21 AM
I guess I am seeking opinions on the cables, (so possibly a cry for help).
Are they going to fall apart? If the concensus opinion is yes, then I'd have the dealer replace them. My gut feeling though is that only the insulation has pulled free not the cables.
I quoted the high mileage just for context. If they have held up for this long, I suspect they will continue to work (so maybe the weekend mud guy).
post #19 of 28 (permalink) Old 09-19-2017, 11:28 AM
Supporting Vendor
shinoo's Avatar
...I quoted the high mileage just for context. If they have held up for this long, I suspect they will continue to work.
This may be the case, but I've seen several in this condition that were in the process of failing. When the cables start to degrade they tend to get stiff and the shifter requires more effort. Does yours still shift smoothly?
I think installing our cables becomes a preventative measure that may save you from being stranded.
shinoo is offline
post #20 of 28 (permalink) Old 09-19-2017, 11:59 AM
The dealer asked me about the shifter cables a few years ago. They asked if shifting felt poor. It did not at that time. It also continues to feel normal and shift easily.
What I'd like to know is how these cables are attached. Are they simply crimped into position? Is there any way to determine if they have pulled out?
