Should this part be loose? - LotusTalk - The Lotus Cars Community
 2Likes
  • 2 Post By thebuzzard
post #1 of 15 (permalink) Old 04-13-2019, 01:58 PM Thread Starter
I spotted this handle while my trunk was open today. I never saw it before (my car is only a week old!) so I dont know its normal state. The white handle is dangling there, not really secure at all. It feels broken but I Just dont know. See photo below. Thoughts?
TERIB is offline
post #2 of 15 (permalink) Old 04-13-2019, 02:13 PM
cyow5's Avatar
If you really want to test it, you can unscrew the locking pin down below (attached the trunk wall near the exhasut) then press it into the locked position. Basically, simulate shutting the trunk but my moving the locking pin instead of the trunk lid. Then pull the handle and see if it releases.
All that being said, I strongly recommend a locking aerocatch. It eliminates any chance of locking your keys in the trunk, and it lets you open and close the trunk whenever you want since it doesn't automatically lock (especially helpful when you don't want to turn off the engine just to open the trunk real quick)
https://www.lotustalk.com/forums/f25...isited-398569/
cyow5 is online now
post #3 of 15 (permalink) Old 04-13-2019, 02:34 PM Thread Starter
Should that piece be hanging free as it is in my car? That is what I want to know. Thank you.
TERIB is offline
post #4 of 15 (permalink) Old 04-13-2019, 03:29 PM
KWin's Avatar
That's how it's supposed to be.
KWin is offline
post #5 of 15 (permalink) Old 04-13-2019, 03:39 PM Thread Starter
OK, thank you. All is normal it seems. It just seemed so odd having that piece moving about, rather than secured.
Thank you very much.
TERIB is offline
post #6 of 15 (permalink) Old 04-13-2019, 03:44 PM
KWin's Avatar
It's even worse when you consider that that handle is the safety exit release handle incase someone is locked in the trunk...
KWin is offline
post #7 of 15 (permalink) Old 04-13-2019, 03:49 PM Thread Starter
That's what I thought this handle was for, but my goodness, that trunk is small. Would a toddler know to use that handle??
TERIB is offline
post #8 of 15 (permalink) Old 04-13-2019, 06:10 PM
That's the standard joke, yes.
This is what happens when DOT or NHTSA makes a regulation without thinking all the cases through. It would have been trivial for them to say 'in excess of 5 cu ft' but they didn't.
The stupid little GITD handle (and associated latch) is one of the things Lotus had to do to make the car legal for sale in the USA.
steelypip is offline
post #9 of 15 (permalink) Old 04-13-2019, 06:11 PM
glb
glb's Avatar
I used to know the progression of children's grip development. I no longer do.
But, if a child or adult with limited movement or deftness has to grab something, it is easier if that item is a bit loose. Think about it.
And, have you not noticed these things in almost every car in the country??
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is online now
post #10 of 15 (permalink) Old 04-14-2019, 05:53 AM
cyow5's Avatar
You said it feels broken; it is normally attached like any other handle I've ever seen (just by the tension in the cable which is not much), so if it doesn't feel like that then there may be an issue. I actually did have mine break, so there was no resistance when pulling the release.
cyow5 is online now
post #11 of 15 (permalink) Old 04-14-2019, 06:07 AM
Motard's Avatar
I had mine out from taking rear clam off in the past. I put it back cause it's so silly and fun to point out to people.
L O T U S
Motard is offline
post #12 of 15 (permalink) Old 04-14-2019, 09:48 AM
thebuzzard's Avatar
Can't resist:
Sent from my Pixel 3 XL using Tapatalk
Motard and brytee like this.
2007 Exige S
Stripped down and turned into a track animal
thebuzzard is offline
post #13 of 15 (permalink) Old 04-14-2019, 06:04 PM
Motard's Avatar
I forgot about that video! She is such a fun and game girl!
L O T U S
Motard is offline
post #14 of 15 (permalink) Old 04-15-2019, 07:18 AM
I'd never seen that video. Thanks for sharing it back around...
post #15 of 15 (permalink) Old 04-15-2019, 08:42 AM
David Craig's Avatar
Yours looks normal.
I had a problem once with the handle in my car. I had the trunk very tightly packed for a road trip and that pushed that handle into a position in which it could not move. When you unlock the trunk using the key, that handle needs to move a bit. In my case because it was stuck the trunk would not open.
After many hours of fiddling around, I guess it moved enough for the key to turn the lock.
As a result of all of that, I removed the plastic handle.
David Craig is offline
Similar Threads
Should I pick up this little runner? What should I offer? luxige Other 14 05-12-2014 06:49 PM
What car should I lease as a DD/should I splurge? sizzam Other Cars and Comparisons 7 04-23-2011 02:10 PM
Should I show "even more" patience or should I take action? ItsThaMonsta General Discussion (Lotus related) 54 02-23-2011 04:14 AM
Help identifying loose part? petroboy Interior/Exterior 9 04-11-2009 04:59 PM
Should I buy or should I wait? DMasters General Discussion (Lotus related) 92 08-26-2008 06:28 AM
