Soon to be owner . - LotusTalk - The Lotus Cars Community
 3Likes
post #1 of 22 (permalink) Old 10-21-2017, 07:33 PM Thread Starter
A Lo's Avatar
Soon to be owner .
This week l will be purchasing a 2005 Elise. Test drive was great! Minor paint issues, two chips where the boot opens and hits the body. Seller said alarm system is sensitive and it randomly goes off in the middle of the night. Some mystery wires hanging down from the bottom side of the passengers side dash. The under side plates are in great condition no scratches.
Have been looking forward to this day since 2005. Just wanted to see if any one has some "new owner" constructive criticism, suggestions, or possible ideas on how to fix the alarm. I'm familiar with where it is located but is sensitivity really the issue or could it be malfunctioning for another reason? I'll be testing everything Monday so I'm sure I'll have an update then. Thanks
A Lo is offline
post #2 of 22 (permalink) Old 10-22-2017, 04:03 AM
LotusCC's Avatar
Congratulations A Lo!
This is a good place to start:
https://www.lotustalk.com/forums/showthread.php?t=25131
05 Arctic Silver UK:
12 Wrangler JKU
LotusCC is offline
post #3 of 22 (permalink) Old 10-22-2017, 04:22 AM
Habious's Avatar
There's a thread in the Alarm/CDL sub-forum on how to adjust the sensitivity of the microwave sensor.
Here's the link...
https://www.lotustalk.com/forums/f320...-motion-85715/
2011 Lotus Elise REV300 - Starlight Black Metallic
2014 Jeep Grand Cherokee SRT
2011 Tesla Roadster 2.5 - Midnight Blue (sold)
2004 Chevy SSR Convertible Pickup - Ultra Violet (sold)
My CarPC YouTube Video - - - - - - - - - - - - - NY Times Article
Habious is offline
post #4 of 22 (permalink) Old 10-22-2017, 05:58 AM Thread Starter
A Lo's Avatar
Thanks!
A Lo is offline
post #5 of 22 (permalink) Old 10-22-2017, 05:59 AM Thread Starter
A Lo's Avatar
Here's the link...
Great! Thank you
A Lo is offline
post #6 of 22 (permalink) Old 10-22-2017, 07:52 AM
glb
glb's Avatar
These are brilliant cars, loads of fun.
and now, this-
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
12. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
13. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. are wildly expense when purchased thru Lotus.
Plus:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #7 of 22 (permalink) Old 10-22-2017, 08:52 AM
Robocop305's Avatar
I don't think the 2005 comes with the inside motion sensor. I could be wrong. Congrats on the new purchase and get your modification fund ready. Enjoy!!!
Robocop305 is offline
post #8 of 22 (permalink) Old 10-22-2017, 11:09 AM
The RLS multivex mirrors are terrible and a waste a money! i found myself squinting and seeing double vision. at night, i couldn't see anything with all the glare. good luck removing them without cracking them.
I have an 05 and once in a while the alarm goes off at weird moments.
Good luck and enjoy in good health
jaybalin is offline
post #9 of 22 (permalink) Old 10-22-2017, 01:43 PM
Mobius97's Avatar
They do. I have to disable mine if I am cuaght out in the rain. The microwave thinks the rain is movent if it is pouring really hard out.
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
post #10 of 22 (permalink) Old 10-22-2017, 02:28 PM
glb
glb's Avatar
Really? I've never met anyone who didn't like them. I've had mine for 12 yrs and bought a 2nd set to ensure I'd never be w/o them.
Wonder if yours were misformed....
Even have a set of RLS version.
glb is offline
post #11 of 22 (permalink) Old 10-22-2017, 02:29 PM
glb
glb's Avatar
#11 in my list makes Lotus life much better.
glb is offline
post #12 of 22 (permalink) Old 10-22-2017, 08:28 PM
RapidLotus's Avatar
Congradulations on the purchase. Post some photos when you close the deal! I purchased my 05' Elise 3 weeks ago and can't wipe the smile off my face every time I drive it. This is the place for answers and lots of great info. Where are you located? I am in Melbourne, Florida.
Cheers!
Central Florida
RapidLotus is offline
post #13 of 22 (permalink) Old 10-23-2017, 06:38 AM
TachItUp's Avatar
I'm also very pleased with the RLS mirrors. However, they have changed ownership recently and are quite hard to get a hold of.
TachItUp is offline
post #14 of 22 (permalink) Old 10-24-2017, 07:52 PM
rukkie's Avatar
Any good mirror solutions in 2017? Can’t seem to find anyone still making these anymore who’s still in business...
Sent from my iPad using Tapatalk
rukkie is offline
post #15 of 22 (permalink) Old 10-25-2017, 06:05 AM
I went to the local hardware store and bought 2 2" round convex mirrors and stuck them on. They work great and i can still see out of the regular mirrors.
I bought some slightly smaller adjustable ones for another car and i can't see anything out of those. It seems they are not all created equal.
Ken-Farmington Hills, MI
2005 Lotus Elise
2012 Mazda Miata
1957 MGA Coupe
1948 MG TC
1932 Austin 10/4 Sunshine
Kaklemmer is offline
post #16 of 22 (permalink) Old 10-25-2017, 08:00 AM
cyow5's Avatar
I went with these after a guardrail took my multivex:
https://www.inokinetic.com/lotus/rac...egory=Exterior
Well, technically I have the Sector111 ones who are now defunct and this is their replacement company. You lose some of the curvature, but I have mine adjusted just so, and they work great.
cyow5 is offline
post #17 of 22 (permalink) Old 10-25-2017, 09:38 AM
Congratz
CaliforniaElise is offline
post #18 of 22 (permalink) Old 10-25-2017, 09:56 AM
VisualEchos's Avatar
Congrats, and welcome.
Here are my favorite upgrades I've done, which have made my owner experience much improved in the 9 years I've had the car.
- HID headlights <--- see better
- Shift reinforcer <--- shift easier
- Additional shifter mods to make the console not move as much <--- shift easier
- Jim Clayton heavy-ball shift knob <--- shift easier
- Manly motor mounts <--- shift easier
- Steering arms (more negative camber for the front) <--- more telepathic steering
- Larini dual-tip exhaust <--- fantastic sound
- Tune (thanks again BOE!) <--- buttery smooth power delivery with no dips or valleys
- Cup Car air box <--- better sound
- Cup Car Sparco steering wheel <--- better driving feel
- Nitron street series suspension <--- better handling AND comfort (wow!)
Links to success:
https://www.boefab.com/
https://www.gatormotorsport.com/service/parts-inquiry
blackwatchracing.com
Stand and Deliver.
by Andrew Thompson, on Flickr
2006 Exige
VisualEchos is offline
post #19 of 22 (permalink) Old 10-25-2017, 12:09 PM
glb
glb's Avatar
Do these eliminate or just reduce blind spots? Thx.
glb is offline
post #20 of 22 (permalink) Old 10-26-2017, 01:38 AM
cyow5's Avatar
That's very, very sensitive to how you have the mirrors set up (true on any car as I am sure you know), but I can continuously track a passing car from my rearview to sideview to side window. At times it is only a small fraction of said car, but it is there. I found the RLS mirrors gave a taller view but not appreciably wider.
cyow5 is offline
