Stop-and-Go Traffic - LotusTalk - The Lotus Cars Community
post #1 of 9 (permalink) Old 05-20-2013, 08:03 AM Thread Starter
05 Elise Freak's Avatar
Stop-and-Go Traffic
Hey guys,
I have had my Elise for a few years now, and a couple of times it has started getting a little hot in traffic. Fortunately I don't see much traffic in this car because I'm usually out in the back roads but hey, it happens... It's never over-heated because I stopped and turned it off before it got to that point but the fans were on and the temp was slowly climbing still. I know this is common.
Well now my radiator is leaking (only a matter of time) and I'm debating between a single pass or a triple pass radiator. My question is this: Would our cars be getting hot while stuck in traffic be due to lack of flow through the cooling system, or poor heat rejection at the radiator?
If it's low flow, I'll get a single pass. If it's poor heat transfer, I'll get a triple pass.
The car has never even tried to get hot while I was underway before, no matter how much fun I'm having. So I'm not terribly worried about a big honkin' radiator. I'd just like better cooling at idle on those hot days stuck in traffic.
Thank you,
05 Elise Freak is offline
post #2 of 9 (permalink) Old 05-20-2013, 08:25 AM
doug_porsche's Avatar
It seems from the research I have done that the 100% empirical answer is....
there is no 100% correct answer.
I replaced my factory radiator with a Wizard single pass radiator and am running a 170 deg thermostat (according to the gauge it opens about 172 or 173ish).
With the Wizard Rad and normal driving I see temps in the mid to upper 170s. Stop and go it will creep up to the low 190's.
With the factory setup and normal driving I would see temps in the mid to upper 170s. Stop and go would creep up to the low 200's.
I think, (YMMV), that for a well maintained, stock motored car, there is no incorrect answer. Either will work for you.
Apexes are a lot like relationships. So tough to get right, so easy to see where they went wrong.
The secret to a long life is ------- not dying.
doug_porsche is offline
post #3 of 9 (permalink) Old 05-20-2013, 09:35 AM
$3(uR3 u$3r
SCamper's Avatar
Hi.
For the trouble to replace the radiator, does the $75 difference matter? Not sure why the single pass is even offered at this time.
-Alex
2008 Elise SC - Solar Yellow
SCamper is offline
post #4 of 9 (permalink) Old 05-20-2013, 12:12 PM Thread Starter
Because of the nature of a water pump. They are centrifugal pump right? They don't build much pressure so they are sensitive to flow restrictions. A triple pass restricts flow compared to a single pass, so if low flow was the reason for getting hot, a triple pass would only make it worse.
I'm not really worried about it either way, I was just wondering if someone had 2 cents to throw in.
post #5 of 9 (permalink) Old 05-20-2013, 01:38 PM
$3(uR3 u$3r
SCamper's Avatar
Hi.
Just more info...
https://www.lotustalk.com/forums/f311...rad-fp-124424/
Looks like the water pump has a flow rate of 200 ltr/min.
Hope this info helps. Good luck with your research.
-Alex
SCamper is offline
post #6 of 9 (permalink) Old 05-20-2013, 03:50 PM
sturgeongeneral's Avatar
There was a very comprehensive thread describing the plus and minus of each within the last 6 months or so. Very well done. I believe.the single pass won.
05 Elise
56 VW Dune Buggy
[email protected]
sturgeongeneral is offline
post #7 of 9 (permalink) Old 05-20-2013, 03:53 PM
XHILR8N!'s Avatar
Just put in a triple. Would do the single if were to do it again. Don't know why.
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #8 of 9 (permalink) Old 05-20-2013, 04:13 PM
cashxdr's Avatar
Tj explained to me that if the car lived on the track and with a proper water wetter the 3 pass works well
If daily driving and track go with the single pass
The way I understand it that outside the track with all the bugs, road trash, squirrels and dust, that the 3 pass gets plugged much quicker. I believe that was his experiance when he was working out at Autobahn
cashxdr is offline
post #9 of 9 (permalink) Old 05-20-2013, 06:54 PM
Sitting still with zero air flow they will be about the same. My new single pass works great, just needs to be moving air through it.
Either one you get, your thermostat will be dictating the cars temps. And again, both will heat up the same in traffic.
pistolpete is offline
