Strange engine noise - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 07-11-2019, 08:38 PM Thread Starter
So as many of you know my engine was destroyed by some idiots that stole my car before. As part of the repair they put in a new (rebuilt) engine which has been running great for about 500 miles.
Yesterday my car started to make an odd grinding/rattling noise. It started in the morning and was gone by the time I got to work. It happened again on the way home and again this morning.
It seems to be worst when the car is cold and goes away after a while. It appears when I left off the gas, not when I press it and is worst when turning.
At first I thought it was the transmission, a joint or bearing but it happens with the clutch in and in neutral and I can partially recreate it when parked in neutral though it is much worse when driving. Here's a quick video I made. It was warm already so not as bad as when cold.
Any ideas on what it is? Timing chain?
Thanks!
Chris
Sent from my SM-G965U using Tapatalk
Watchnerd123 is online now
post #2 of 5 (permalink) Old 07-11-2019, 09:13 PM
Jetblast's Avatar
You're right, that's a strange engine noise. I've never torn open a 2ZZ except for the valve cover and oil pan, but if it were mine I'd be suspicious of the timing chain. There is a chain vibration dampener just opposite from the chain tension slipper, I wonder if that might be the source of the noise? Was the noise louder on the timing chain side of the engine? I've attached a page from the Toyota engine manual showing the component locations.
File Type: pdf Celica Repair Manual Vol.2-Condensed 23.pdf (267.4 KB, 32 views)
Jetblast is offline
post #3 of 5 (permalink) Old 07-11-2019, 09:55 PM Thread Starter
I was able to record it while driving and it sounds a lot more accurate to what I am hearing.
https://drive.google.com/file/d/1-4m...w?usp=drivesdk
https://drive.google.com/file/d/1-5i...w?usp=drivesdk
post #4 of 5 (permalink) Old 07-11-2019, 09:58 PM Thread Starter
It's hard to pinpoint the exact location but I was thinking the same thing.
post #5 of 5 (permalink) Old 07-13-2019, 05:28 AM Thread Starter
Bump. Has anyone else experienced this?
