Replace radiator step by step without disconnecting oil/refrig lines - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 03-28-2011, 05:37 PM Thread Starter
bman6074's Avatar
Step by step of radiator removal. Hope this helps the next person in search for help on replacing there radiator.
radiator replaced with proRAD from sector111
PDF format
bman6074 is offline
post #2 of 10 (permalink) Old 03-28-2011, 06:12 PM
Mickster's Avatar
Smile Great timing on your post
Incredible timing! - just sat down 10 min after your post looking for info on replacing the radiator (also a proRAD from Sector 111). Just got the clam off about 30 min ago. It's a '07 Exige. I will follow your instructions and let you know!!
"Well, that just goes to show you Andy..."
-- "What's that Floyd?"
"If you want good Lotus service, you gotta go to Mount Pilot"
2007 Exige S Chrome Orange
Mickster is offline
post #3 of 10 (permalink) Old 03-28-2011, 06:52 PM Thread Starter
bman6074's Avatar
Cool glad it will help someone so soon. I could never find anything with much detail to how to do it but seen many ask. So figured while I was in the process would snap some pics and do a quick write up.
Mine too is an 07 Exige
bman6074 is offline
post #4 of 10 (permalink) Old 03-28-2011, 07:06 PM
hifiandmtb's Avatar
Awesome work - I hope to swap my radiator this weekend! :-)
ex- 2010 Lotus Evora Starlight Black 6-speed manual
hifiandmtb is offline
post #5 of 10 (permalink) Old 03-28-2011, 07:35 PM
Mickster's Avatar
Great write up! - Did the 12 bolts topside and calling it a night. Need to pick up a 45 deg (or 30 deg) 10 mm tomorrow. Just wondering what the 8mm bolts are for? - They're not attached to anything...
Mickster is offline
post #6 of 10 (permalink) Old 03-28-2011, 07:43 PM Thread Starter
bman6074's Avatar
Thanks
The 8mm bolts on topside are attached to the condenser by bolt with a locknut. You have to push the foam down to get to the nut. Might need 2 - 8mm wrenches to get it loose.
bman6074 is offline
post #7 of 10 (permalink) Old 03-29-2011, 05:15 AM
Mickster's Avatar
Thanks
That's what I used, one 8mm to hold the nut and another ratcheting one on top. At the time it appeared nothing was attached when I removed them, because the condenser tab below it is very thin...
Mickster is offline
post #8 of 10 (permalink) Old 03-29-2011, 05:34 AM Thread Starter
bman6074's Avatar
Yea its like you think you got everything and then the radiator won't budge. I actually did the opposite removed the bolts below and missed the 4 8mm on top. Then after that it was the foam holding it in. It seemed futile at times.
bman6074 is offline
post #9 of 10 (permalink) Old 03-30-2011, 05:05 AM
Mickster's Avatar
Speaking of the foam, the radiator is out and the strip of foam at the bottom (that covers the two bolts) did not fair well in the removal process. It's in four or five pieces. Wondering if I should just tuck the pieces back in the best I can with the new radiator or do they need to be more secure, like use some type of spray adhesive? Don't know how critical the bottom piece is to have in place.
Just going through a dry run with the proRAD, looks like I might just make it over the rear bottom studs without having to slot it, but thats without the foam in place
Mickster is offline
post #10 of 10 (permalink) Old 03-30-2011, 05:09 AM Thread Starter
bman6074's Avatar
Interesting, my bottom piece wasn't really stuck like the sides just free floating. It didn't' even come out. I just left it in there and slide the new radiator in place. Maybe you can stop at your local hardware or auto store and get a new piece. I would think you want it just for vibration purposes.
bman6074 is offline
  LotusTalk - The Lotus Cars Community > Lotus Resource Center > Lotus Resource Center(LRC) > -Engine-(LRC) > ---Engine Cooling(LRC)
