Fuel Tank Removal - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 12-23-2009, 01:02 AM Thread Starter
jbs
jbs's Avatar
Fuel Tank Removal
Original thread located here- https://www.lotustalk.com/forums/f101...el-tank-82071/
I am looking for instructions on how to remove the fuel tank.
Is there a tutorial on the net?
If someone could share the knowledge, I would appreciate it.
jbs is offline
post #2 of 3 (permalink) Old 12-23-2009, 04:28 AM
Not the admin anymore
RacyTracy's Avatar
Does this help??
http://www.bell-colvill.co.uk/admin/.../PDFS/4496.pdf
Go to page 8.
2008 Toyota FJ Cruiser
2009 Audi R8
I am no longer the admin. If you need help, please contact a moderator or send a PM to 'Administrator'.
RacyTracy is offline
post #3 of 3 (permalink) Old 12-23-2009, 07:57 AM
OTB
OTB's Avatar
Some more tips
You will most likely want the seats out, and definetely the rear interior panel. the fuel pump's connections for fuel pipe and electric are under that rear interior panel.
The fuel filler neck hose clamp is accessible after you remove the rear right fender liner.
Once you have the shear panel off (and brake/shift cables out of the way) you can unbolt the brackets that support the fuel tank. Even with the brackets removed, my tank was wedged in there so hard, it had to be tugged on to lower it.
When re-installing, the fuel filler neck hose clamp is a bitch to start because it just wants to spin. I duct tape it to the fuel hose to get the screw started on the clamp. Be sure not to drop the tool you are using to tighten this clamp, because it will drop onto the top of the tank and is not recoverable unless you drop the tank again. How do I know?....because a 10mm socket lives on top of my tank.
cheers
Eli
Don't rub the lamp unless you want the genie to come out!
OTB is offline
Closed Thread
  LotusTalk - The Lotus Cars Community > Lotus Resource Center > Lotus Resource Center(LRC) > -Engine-(LRC) > ---Fuel System(LRC)
« Fuel Pump Removal | - »
