Check my math? Max driveway angles - LotusTalk - The Lotus Cars Community
 3Likes
post #1 of 37 (permalink) Old 05-30-2008, 03:51 PM Thread Starter
dana's Avatar
Hey guys,
I put in an offer on a house yesterday. The garage is slightly below street level and the driveway is has a pretty sharp, greater than 180 degree angle off the street, ramps down, and then angles less than 180 degrees to flatten into the actual garage. So, something like this:
street____
*********------ garage
Just eyeballing the driveway we knew getting the Lotus in was going to be dubious, so I drove it over and tested it out. No way. I'm going to try to find out if the driveway can be altered in order for the Elise to get in and out sufficiently but needed numbers.
Given a standard (no sport pack) Elise with clearance of 6" (did not account for the car sitting down with a passenger or two... significant?) and a wheelbase of 90.6", I came up with a maximum angle for the top slope of 181.5583 in order for the car not to bottom out in the center.
At the bottom of the driveway, again with 6" clearance and a 32" nose length, I came up with a minimum angle of 168.8514 degrees for the nose not to scrape.
I thought this might be of interest to others, and hopefully someone here can check my math, as it's been a while since geometry in Junior High. That top angle seems too small.
TIA!
dana is offline
post #2 of 37 (permalink) Old 05-30-2008, 04:25 PM
EdHahn's Avatar
street____
I have no effin' clue what the heck you're trying to say. Greater than 180 degrees? Do you mean that there's a vertical drop off between the street level and the driveway?
ed
Magnetic Blue/LSS Delivered: 1/13/05
EdHahn is offline
post #3 of 37 (permalink) Old 05-30-2008, 04:48 PM Thread Starter
dana's Avatar
Hmm, I guess I'm not explaining clearly enough.
The driveway slopes down in order for vehicles to get from the street level to the garage level. Flat is 180 degrees, so the angle of the driveway between the street surface and the ramp surface is greater than that. The question is, how large can that angle be before the Elise bottoms out?
The ramp then ends where the flat of the garage begins. The ramp was less than horizontal, so the angle between the ramp's surface and the garage surface is less than 180 degrees. The question is, what is the minimum angle it can be for the Elise not to scrape her little nose?
See this picture here? http://i29.tinypic.com/10cvo0y.jpg
The driveway of the house in question kinda does the opposite -- it goes down instead of up. Hopefully that helps.
dana is offline
post #4 of 37 (permalink) Old 05-30-2008, 05:25 PM
RichS's Avatar
This is going to depend on your car. If you have lowered your car at all it is going to change the angle.
An easy way to measure the needed angle:
Get a yard stick (or maybe a two yard stick) and put it up against the front tire. Lift the yard stick up until it touches the front clam. Use another ruler to measure how high the end of the stick is off the ground. You now know the max angle that will almost work (or will with some simple algebra). I'd probably reduce the height by about half and go with that. This assumes you are going UP the driveway to the street. If you are going DOWN the driveway from the street then you will have to take into account the weight of the car pressing down on the front suspension as you go down the 'hill'.
"Against logic there is no armor like ignorance."
-- Laurence J. Peter
RichS is offline
post #5 of 37 (permalink) Old 05-30-2008, 05:27 PM
RichS's Avatar
And yes, you can have your driveway modified to make it work.
And yes, with driver and passenger in the car you are going to change the angles.
RichS is offline
post #6 of 37 (permalink) Old 05-30-2008, 05:37 PM
ItsThaMonsta's Avatar
Well I hope yours isnt as steep as that. All the adjustments in the world wouldnt get an elise up that hill.
ItsThaMonsta is offline
post #7 of 37 (permalink) Old 05-30-2008, 06:52 PM
cdn_alien's Avatar
[QUOTE=dana;1018389]Hmm, I guess I'm not explaining clearly enough.
The driveway of the house in question kinda does the opposite -- it goes down instead of up. Hopefully that helps.[/QUOTE
If your driveway looks anything like the picture, then you need a Hummer, not an Elise.
p.s. The ground clearance on an Elise is 5", not 6".
'10 Solar Yellow Evora
'06 Chili Red Elise (sold)
cdn_alien is offline
post #8 of 37 (permalink) Old 05-30-2008, 09:15 PM
djo715's Avatar
2 sharp angles:
1) street to ramp angle, where you'd be concerned about the breakover angle:
and
2) the ramp to garage angle, where you need to be concerned about the angle of approach & angle of departure:
I thought these terms may be useful, although I'm of no help in actually solving this issue. But I do hope your driveway isn't anywhere as steep as that picture!!!
Cheers,
-Darryl
2007 Lotus Exige S | Aspen White | Track Pack, LSD, Starshield, Cup Suspension.
djo715 is offline
post #9 of 37 (permalink) Old 05-30-2008, 09:29 PM
Mr. Know's Avatar
I really hope that garage has good drainage...that's horrible design (Darn SF hills)
07 Magnetic Blue Exige S
"Mostly though, it's just a triumph of British engineering." -Jeremy Clarkson
Mr. Know is offline
post #10 of 37 (permalink) Old 05-31-2008, 05:13 AM
insert clever title here
MattG's Avatar
Your math is assuming your car approaches parallel to the driveway...is it wide enough to approach at an angle instead?
'05 Elise, Magnetic Blue / Biscuit / Hardtop
MattG is offline
post #11 of 37 (permalink) Old 05-31-2008, 09:07 AM Thread Starter
dana's Avatar
No, unfortunately it's a single car width driveway, with obstructions on either side.
djo: thanks for finding the terminology, that's very helpful.
All: the pic I included is not actually the driveway in question. I was just using it as an example to illustrate the nature of the problem we're facing. I'm about to take my (lowered) Bimmer over there to see if it will make it down the driveway also.
Any ideas on how much it might cost to break up and re-lay about 25 ft^2 of concrete?
dana is offline
post #12 of 37 (permalink) Old 05-31-2008, 09:51 AM
Bavarian Motorist's Avatar
Another thing you MUST consider is the speed you are going over at. If going >1.5mph (estimation), the suspension will compress causing the car to bottom out. Many things the Elise CAN clear if driven very slowly, but I guess we're just too impatient or under-estimate the steepness. Guilty as charged.
So to be safe, you should probably alter the driveway to be even lower than you calculated.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
Bavarian Motorist is offline
post #13 of 37 (permalink) Old 05-31-2008, 10:37 AM
PhoneBoy's Avatar
+1 I'd hate to have a flooded garage/car/house because the grade around the property slopes TWARDS the house.
'10 Chevy Tahoe
'10 Dodge Grand Caravan (2 of 'em!)
'07 Yamaha WR250F
'06 Lotus Elise - Solar Yellow, Touring, Hard Top, Star Shield, microMIRROR, Bootie, and ChaseCam Sold
PhoneBoy is offline
post #14 of 37 (permalink) Old 05-31-2008, 01:16 PM
xtn
xtn's Avatar
To make your discussion clear, do not set "flat" to 180 degrees. Set "flat" to 0 degrees, then reference the angles away from zero, as in "20 degrees down, then 20 degrees back to flat again.
xtn
SS Lotus Elise likes this.
2006 McLareghini Bugatterrari, Storm Titanium... installed: air horn, Scroth 4-point ASM harnesses, Sector111 halon extinguisher and mounting bracket, Von Hep exhaust and rear panel delete, Pagid brake pads, red Volks CE28n wheels, Toyo RA-1 tires, Nitron SA coilovers, Sector111 (WorksBell) quick-disconnect steering wheel kit. awaiting installation: Scroth "pull-up" lap belts, Sector111 RTD Brace, Tony's heater bypass mod, and dropped steering rack mounting plates.
xtn is offline
post #15 of 37 (permalink) Old 05-31-2008, 02:23 PM Thread Starter
dana's Avatar
Yep, there's a drain at the seam where the driveway meets the garage; it's pretty standard around here.
Well, we tried more cars this afternoon, and the bimmer can't make it over the top lip, and neither can either of the real estate agents' cars (mini cooper, another bimmer). So it looks like this is something that we're going to have to negotiate to have fixed. Not what I wanted to deal with, but hey, it's not rocket science.
dana is offline
post #16 of 37 (permalink) Old 06-03-2008, 11:59 AM
A quick graphical analysis (AutoCAD), using your dimensions, indicates 195.36 deg. and 168.99 deg. respectively.
Bill Bowser
webowser is offline
post #17 of 37 (permalink) Old 06-03-2008, 12:04 PM
EdHahn's Avatar
African or European? Laden or unladen?
ed
EdHahn is offline
post #18 of 37 (permalink) Old 06-03-2008, 12:59 PM
necro's Avatar
Car lift???
07 SY ExigeS
necro is offline
post #19 of 37 (permalink) Old 06-04-2008, 09:04 AM Thread Starter
dana's Avatar
Bill Bowser
Awesome! Thank you. What I calculated as the top angle just didn't feel right. I had a contractor come out and quote me $8-900 for a not pretty but workable job, or $2500 + 3 months' permit time and fees for a pretty job. This, I can take.
dana is offline
post #20 of 37 (permalink) Old 06-04-2008, 09:12 AM
Are you going to account for suspension compression?
