Clutch Master Upgrade Options for Elise/Exige? - LotusTalk - The Lotus Cars Community
post #1 of 32 (permalink) Old 07-04-2016, 05:47 AM Thread Starter
wek120's Avatar
Are there any good upgrades/options for clutch masters other than OEM? Ive been reading through the forums and it seems to be quite an issue, so Id like to avoid putting in a new one that may likely ultimately fail again if there are better options… I see there is what looks like one on elise parts, does anyone know if its any good?
Thanks!
Formerly Wes (RIP : ( ) -- Now Brendon
wek120 is offline
post #2 of 32 (permalink) Old 07-04-2016, 07:17 AM
Less is Better
me73's Avatar
I've never heard of the master cylinder being a problem.
me73 is online now
post #3 of 32 (permalink) Old 03-14-2017, 09:53 AM
glagola1's Avatar
I have a 2008 and mine just sprang a leak from the side of it. Why it was made from plastic is beyond me. It would be cool if there was a metal replacement.
glagola1 is offline
post #4 of 32 (permalink) Old 03-14-2017, 09:57 AM
kfennell's Avatar
Mine just failed too (I think) anyways I replaced it and damn it's hard to bleed, suggestions welcome... No air is coming out either end for a while now, but still won't release the clutch all the way.
kfennell is online now
post #5 of 32 (permalink) Old 03-14-2017, 10:09 AM
The Evora people have a replacement, so I would think with a suitable adapter it could be done
exigegus is online now
post #6 of 32 (permalink) Old 08-03-2017, 05:43 PM
Ryno's Avatar
Finally found my Clutch issue was a hairline crack in the Master.
Can anyone help with some tips for installing the new one?
The service manual mentions 2 bolts inside the foot well that I don't see.
It appears it would be just the two bolts on the outside.
Mainly I'm not sure how you get the pedal separated from the Master.
Ryno is offline
post #7 of 32 (permalink) Old 08-03-2017, 05:59 PM
kfennell's Avatar
There is a clevice on the back of the pedal isn't there?
post #8 of 32 (permalink) Old 08-03-2017, 07:01 PM
Ryno's Avatar
I can see the one on the Brakes but not the clutch.
Probably just need to contort more.
Ryno is offline
post #9 of 32 (permalink) Old 08-03-2017, 07:24 PM
kfennell's Avatar
https://howtune.com/articles/252-rep...lise-and-exige
Step 12
FYI everyone as a followup to my issue, the end result is that the master failed because the clutch had bound up on the input shaft, apparently a common occurance with our cars and clutchmaster clutches. This is why it wouldn't release
post #10 of 32 (permalink) Old 08-03-2017, 09:35 PM
Ryno's Avatar
That was a spectacular write up.
Thanks for the link.
Ryno is offline
post #11 of 32 (permalink) Old 08-04-2017, 06:17 AM
Ryno's Avatar
Step 12
Did you have an external leak on your Master Cylinder?
Ryno is offline
post #12 of 32 (permalink) Old 08-04-2017, 06:19 AM
kfennell's Avatar
There was a leak somewhere, but i never could be sure if it was the hose, or the MC, or something else? Maybe the quick connect or the O-Ring. Just one day I hit the clutch in the paddock and fluid went everywhere out the drivers wheel well.
post #13 of 32 (permalink) Old 08-12-2017, 04:12 AM Thread Starter
wek120's Avatar
Sorry to revive an old thread, but for the second time in only 3k miles of driving Ive now blown a SECOND brake master. Exact same thing happened; Hairline crack/pinhole in the plastic of the brake master's housing.
Does anyone know of ANY kind of upgrade/metal/ alternative versions?
wek120 is offline
post #14 of 32 (permalink) Old 08-12-2017, 07:00 AM
Ryno's Avatar
Tilton Makes one but I'm not sure sure how much work it will be to install or if it will fit for sure.
Do you have a hydraulic throw out bearing?
Our clutches are supposed to be self adjusting according to the service manual. That's the only thing I could see is if your pedal stop wasn't properly adjusted putting too much pressure back on the MC.
Ryno is offline
post #15 of 32 (permalink) Old 03-18-2019, 05:39 AM
glagola1's Avatar
Bumpy bump: I just had my 2nd Elige clutch master cylinder go out. For the record, I'm running and E153 transmission with an ACT HDSS clutch and I think the loads are just too high for the OE plastic master cylinder.
I have heard from a reputable source that the 1996-2000 Honda Civic master cylinder will work with some slight modifications. I'll be trying this out.
glagola1 is offline
post #16 of 32 (permalink) Old 03-18-2019, 07:33 AM
kfennell's Avatar
I shift 100x more then you do and I am not having trouble with an HDSS. Are you sure you aren't getting binding on the input shaft/clutch hub? That is what failed mine.
post #17 of 32 (permalink) Old 03-18-2019, 07:39 AM
glagola1's Avatar
Do you have an E153 transmission? It's much larger than the C61 and is built for much more engine load, ie clamping force. My pedal is quite stiff.
Also, I spend a lot of time navigating grid and on the start line. My clutch is often fully depressed.
I just rebuilt my whole set up and everything looked great except I had to relube the TO bearing surface since it was getting a little gummy.
glagola1 is offline
post #18 of 32 (permalink) Old 03-18-2019, 08:35 AM
kfennell's Avatar
Ah, no, but the difference is not in the transmission, is the pressure plate you use stiffer, and is the clutch slave bigger/smaller?
post #19 of 32 (permalink) Old 03-18-2019, 12:53 PM
eldonz's Avatar
Kevin,
Doesn't BOE's pedal box replace the clutch master?
Later,
Eldon
eldonz is online now
post #20 of 32 (permalink) Old 03-18-2019, 01:01 PM
kfennell's Avatar
Originally Posted by eldonz View Post
Kevin,
Later,
Eldon
No, it's not a pedal box at all. It just replaces the booster with a bracket that holds a balance bar. It also replaces the bar from the pedal to the booster. That is it.
