Elige upright upgrade questions - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 02-20-2019, 08:59 AM Thread Starter
Addict
LostPawn's Avatar
I知 wrapping up some suspension upgrades on the car and am planning some for the next year or two.
I知 sure I値l need new hubs soon enough and am curious about new uprights at the same time. I know Elsie Parts now has a few versions that fit the S2 Elige and they all seem to have slightly different designs. Some raise the hub more than others, some incorporate mounting for both rear brakes and other slight differences. Are there other options on uprights offered by different suppliers (I haven稚 seen any but that doesn稚 mean there are not some offered and not advertised). I also have the BOE toe link solution and am not sure if this changes what uprights work with that as they all seem to have placed the outer joint into double shear. Will that fit the toe link from BOE or are there modifications I壇 have to make to the upright or toe link to make them work together? Somewhere Elise Parts mentions using a tapered toe link ball joint, does this completely change the links I知 using? Are there other considerations I need to make when changing the upright? I run 15 rear rims, does the change in hub location make me move up a size in rim?
LostPawn is offline
post #2 of 7 (permalink) Old 02-20-2019, 11:28 AM
Less is Better
me73's Avatar
There are a surprising number of options.
https://www.eliseparts.com/products/...-s2-rear-pair/
https://www.palatov.com/shop/suspens...lise-uprights/
https://www.brypar.com/shop/prime-r/...front-upright/
https://www.fransisco.nl/lightweight-upright/
and then there's the folks who will machine the existing upright for increased camber adjustment...
me73 is online now
post #3 of 7 (permalink) Old 02-20-2019, 12:04 PM
He's on fire!
jds62f's Avatar
I see a lot of questions about "what" and "how", but I don't see much on "why"
Surely there is a problem you're interested in solving with new uprights. Do you require more camber? Perhaps you're interested in some of the brake caliper options afforded by aftermarket uprights? got money burning a hole in your pocket and need to turn a $XXX project into a $X,XXX project?
jds62f is offline
post #4 of 7 (permalink) Old 02-20-2019, 12:22 PM Thread Starter
Addict
LostPawn's Avatar
Why do I want different uprights? I'm not sure I do at this point and want some more information on the actual install before I start on something. The reason's I'm considering it are:
1) Lower ride height without changing angles of A-Arms, more camber and all that fun stuff.
2) Save some weight.
3) Currently running a 2-pot caliper in the rear with a bracket and would prefer one upright instead.
4) I'm not sure the stock upright is a wear item but mine are 10 years old now and look it (it is also going to see continued track use).
5) I'll be needing new hubs in the next year or two I'm sure and if I'm already taking it that far apart I might as well see what else needs to be replaced.
6) I'm really trying not to spend more on this project this year but planning for the future and the uprights seem affordable enough but if that means new toe links and/or other items to make them actually fit I might cross this off the upgrade list.
Edit: Do I ask a lot of questions about "what" and "how"?
LostPawn is offline
post #5 of 7 (permalink) Old 02-20-2019, 01:04 PM
I have Elise Parts uprights installed on my car front and rear. The main reason was to improve (correct) roll centers after lowering my car. The second reason was that it was right after the UK had voted for Brexit and the GBP had crashed making UK parts very nicely priced!! If you are not concerned about your roll centers then while your existing uprights probably look rusty, I am sure they have a lot of life left in them. I have the uprights that position the hubs 20mm higher, which means I can lower the car 20mm minimum without negatively affecting geometry. I run approximately 110mm front with a 10mm rake. Negative camber will also increase quite a bit, I can get about 3 degrees in the front and more in the rear. I don't see why your BOE toe links would not fit the rear uprights.
In your situation, I would call Geary or Ian at Eliseparts and talk over your expectations, they were very helpful to me. They are very nicely made parts and I'm happy with the way the car drives.
Zink is offline
post #6 of 7 (permalink) Old 02-20-2019, 02:43 PM Thread Starter
Addict
LostPawn's Avatar
Thanks for the contact reference. I am planning on a ride height change and want it to be a good as I can get it.
I ask about the toe links as the BOE links change the size of the bolts on each end and the mounting hardware is different, I'm assuming the uprights use the stock size bolt. Not sure I want to drill the uprights to fit and also not sure if I can simply change the toe link end to fit. I'm sure it can all line up in the end but I'd like to avoid several different shipments from vendors or bolt suppliers part way through the install.
LostPawn is offline
post #7 of 7 (permalink) Old 02-20-2019, 03:33 PM
Give BOE a call, they are familiar with the eliseparts uprights and should know whether you would, I assume at the worst, have to change the heim joint at the upright. I would not drill the eliseparts uprights as they are aluminum.
Zink is offline
Similar Threads
Hand Brake Stuck Upright. Help Needed (pics) Transonic Suspension (including wheels, tires, brakes) 21 04-29-2014 11:42 AM
Rear upright caliper to radial conversion... Apex_in_sno Suspension (including wheels, tires, brakes) 1 07-19-2010 11:20 AM
I want to sit more upright - any ideas? mike325ci Interior/Exterior 13 08-27-2007 09:42 PM
Machine work on front upright for added - camber Ken Wright Suspension (including wheels, tires, brakes) 16 07-13-2007 07:39 AM
Extruded front upright velocityengineer Suspension (including wheels, tires, brakes) 5 11-20-2005 09:57 PM
