Fitting a boost gauge - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By thebuzzard
  • 1 Post By thebuzzard
post #1 of 20 (permalink) Old 08-29-2013, 12:56 PM Thread Starter
Sa_Exige's Avatar
Please could someone give me some guidance as to where the best place is to 'T' in a boost gauge on a S240
Seen various posts on the forum but really looking to know where the best results have been achieved
Sa_Exige is offline
post #2 of 20 (permalink) Old 08-29-2013, 09:39 PM
shay2nak
shay2nak's Avatar
tap into the outlet pipe from the intercooler.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #3 of 20 (permalink) Old 05-25-2019, 08:13 AM
Conechaser's Avatar
Any new thoughts on where to locate sender for boost gauge? If outlet pipe is the answer, where on the outlet pipe is best?
Conechaser is offline
post #4 of 20 (permalink) Old 05-25-2019, 08:27 AM
thebuzzard's Avatar
I had the folks at Advanced Welding in Mountain View CA put a bung in this RLS pipe. The OEM is likely meaty enough to tap.
shay2nak and forkmeupscotty like this.
2007 Exige S
Stripped down and turned into a track animal
thebuzzard is offline
post #5 of 20 (permalink) Old 05-25-2019, 09:04 AM
rb26dett's Avatar
You can also get a silicone coupler with built in bung. Easier than welding one in. Plus itís reversible.
rb26dett is offline
post #6 of 20 (permalink) Old 05-25-2019, 10:20 AM
Conechaser's Avatar
Where to purchase?
post #7 of 20 (permalink) Old 05-25-2019, 01:02 PM
Conechaser's Avatar
Anyone know where you can source a silicon IC coupler with built-in bung?
post #8 of 20 (permalink) Old 05-25-2019, 02:34 PM
kfennell's Avatar
They are available at lots of places including amazon. Measure the coupler you need then search silicone coupler bung *size*
kfennell is offline
post #9 of 20 (permalink) Old 05-25-2019, 03:30 PM
The Enforcer
oldmansan's Avatar
Good information here. I wasn't aware of silicone couplers with built-in bungs. Thanks.
San
oldmansan is offline
post #10 of 20 (permalink) Old 05-25-2019, 03:49 PM
Just a word of advice, be careful buying silicon hoses/couplers on Amazon. A LOT of the options are complete sh*t from China. They look nice, but have next to no structural lining. Even the name brand ones made in China are still far better than the really cheap options from companies you've never heard of where they all have the exact same part for sale (one factory, 100 brands selling same part).
mwehnes is offline
post #11 of 20 (permalink) Old 05-25-2019, 04:19 PM
thebuzzard's Avatar
Well... I got some interesting data at Sears Point this weekend with my new boost pressure sensor. I get the expected 6psi boost when I have my foot on the floor. The embarrassing fact is that even a teeny bit of a lift kills the boost. And I do that more than I'd like to admit. Those data rule!
forkmeupscotty likes this.
2007 Exige S
post #12 of 20 (permalink) Old 05-26-2019, 08:43 AM
Conechaser's Avatar
So anyone with experience with silicone coupler with a bung for boost sender that is worth buying? I am presently looking at the Mishimoto brand.
Also if anyone has a recommendation for best location for water temp sender install as I cannot read my oem gauge in direct sunlight?
post #13 of 20 (permalink) Old 05-26-2019, 12:05 PM
rb26dett's Avatar
Yes I have the mishimoto brand bung coupler also. Iíve been using it for 3-4 years now with no issues.
rb26dett is offline
post #14 of 20 (permalink) Old 05-26-2019, 01:31 PM
Conechaser's Avatar
Thanks for advice.
post #15 of 20 (permalink) Old 05-26-2019, 01:36 PM
thebuzzard's Avatar
Thanks all for the info. Would have been a cheaper option of I'd known about the silicone coupler
Sent from my Pixel 3 using Tapatalk
2007 Exige S
post #16 of 20 (permalink) Old 05-26-2019, 01:57 PM
kfennell's Avatar
You could use the opposite kind of thing on your coolant hoses?
https://www.ppediesel.com/shop/3-0-b...515900300.html
kfennell is offline
post #17 of 20 (permalink) Old 05-26-2019, 02:01 PM
Conechaser's Avatar
Which coolant hose would work best for ease of install? Picture?
post #18 of 20 (permalink) Old 05-26-2019, 02:28 PM
kfennell's Avatar
There are 3 that come right off the head, any of them would work with one being larger then the other two. My car is too far from stock to be a good reference point and still in the trailer.
kfennell is offline
post #19 of 20 (permalink) Old 06-03-2019, 08:24 AM
Conechaser's Avatar
Is the hose that has the purge valve in it on the left rear side of the engine bay a radiator hose or a heater hose? Any issues with tapping the bunge coupler for water temp sender unit into this hose?
Thanks,
Bryan
post #20 of 20 (permalink) Old 06-03-2019, 08:37 AM
kfennell's Avatar
Thanks,
Bryan
That hose is a heater hose and comes off the pump discharge, so it should be a fair bit cooler then the other lines I expect. Probably not the best.
kfennell is offline
