Gated Shifter WIP Mod - LotusTalk - The Lotus Cars Community
 88Likes
post #1 of 104 (permalink) Old 02-15-2019, 01:15 PM Thread Starter
Varun916's Avatar
Hey everyone,
Just wanted to share a pet project I've been working on for a gated shifter. I've always loved the look of those, so I figured I'd give it a shot. Attaching a shot of my V1 3-d printed prototype, I'll be using this thread to update with progress.
I've already found that the symmetric H pattern isn't going to work - it's not possible to get the throws I need for all gears and have all gates be the same length as I don't have enough opening to work with, so I'm moving to a stair-step model, pictures attached. With this pattern, each gate closely fits the actual gear throw, which I think is kind of cool.
The V2 model has angled sidewalls to account for the shifter rod angle in 1,2 & 5,6, and moves the gates a little lower on the plate to get better clearance in neutral.
I was initially concerned about how it'd feel, but the tight gates actually lock the shifter in place & reduce slop. It feels pretty good actually!
The idea is to get this CNC machined in brushed aluminum once I'm happy with it. Will post updates as things move along...I'm using a 3-d print shop so turnaround times are ~1.5 weeks unfortunately.
shay2nak, rb26dett, Kubera and 3 others like this.
Varun916 is offline
post #2 of 104 (permalink) Old 02-15-2019, 01:27 PM
InfernoLotus's Avatar
Wow, what a cool project. Now just add some LED lighting underneath!
Central Florida
InfernoLotus is offline
post #3 of 104 (permalink) Old 02-15-2019, 02:38 PM Thread Starter
Varun916's Avatar
Thanks! LEDs would certainly be interesting if done right. The area under there isn't exactly all that appealing to look at, it'd need some thought. :-)
Varun916 is offline
post #4 of 104 (permalink) Old 02-15-2019, 03:01 PM
Looks great. Im in for 1 if you produce these in brushed aluminum!
shay2nak and Varun916 like this.
Beemerb0y is offline
post #5 of 104 (permalink) Old 02-15-2019, 03:59 PM Thread Starter
Varun916's Avatar
If this works out well, I'd definitely consider selling it, though may work with an established elige parts provider to get the cost down. No idea how much the CNC's going to cost, but I imagine it's not going to be cheap! First step is to get it working well & polished
Varun916 is offline
post #6 of 104 (permalink) Old 02-15-2019, 06:22 PM
Less is Better
me73's Avatar
I REALLY like the appearance of that and it will be great in Al. Nice job. It looks like you're planning to use a really thick plate. Any particular reason for that? Unfortunately for me it looks like my ShiftR111 wouldn't work with something like that.
me73 is offline
post #7 of 104 (permalink) Old 02-15-2019, 06:41 PM
Brandonm84's Avatar
Can you post a video going through the gears? Looks cool!
Brandonm84 is offline
post #8 of 104 (permalink) Old 02-15-2019, 09:42 PM Thread Starter
Varun916's Avatar
Thanks guys!
@me73 - my inspiration has been Lamborghini gated shifters, which have pretty thick plates: https://i.pinimg.com/originals/ab/53...d69109e311.jpg
I didn't want this mod to look aftermarket, and some thinner plated shift gates I've seen look a little cheap/plasticky: https://uniqperformance.ca/wp-conten...3-768x1365.png.
@Brandonm84 - definitely, I'll shoot a video once my V2 print comes in. I misjudged the throw positions with the V1, so it wouldn't be very indicative.
Varun916 is offline
post #9 of 104 (permalink) Old 02-16-2019, 02:35 AM Thread Starter
Varun916's Avatar
Playing around with raising the plate up a bit. There's a practical purpose to doing so, as the shifter linkage can collide with the plate if it's too low when shifting into reverse (this is an argument for making it not as thick...this shot has the height decreased by .1 inch)
Varun916 is offline
post #10 of 104 (permalink) Old 02-16-2019, 10:27 AM Thread Starter
Varun916's Avatar
@me73 - Do you know what specifically about the ShiftR111 kit wouldn't work with this? I just took a look at some photos, seems like unless you have the short throw shifter(which might also work if it's really just shorter in the y-axis), the gear pattern & separation should be the same?
I had to remove the reverse lockout, which is something you'd need to do as well but apart from that, is there another issue that'd prevent you from using something like this?
Varun916 is offline
post #11 of 104 (permalink) Old 02-16-2019, 11:03 AM
rb26dett's Avatar
The only issue that prevents me from using this is I use my ShiftR111 naked. That thing is a work of art. I canít hide the beauty of it.
SS Lotus Elise likes this.
rb26dett is offline
post #12 of 104 (permalink) Old 02-16-2019, 11:42 AM
Less is Better
me73's Avatar
Going from memory I thought the beam/shaft transition was high up the shifter on the ShiftR. There's an interference between the reverse cable stop and the console/boot seam so I thought that meant the reverse stop would be too high up. But on second look, I think it might be low enough for a gate to work. It looks like the reverse stop on the ShiftR is nearly the same height as the shift cable bracket on the stock unit.
me73 is offline
post #13 of 104 (permalink) Old 02-16-2019, 12:36 PM Thread Starter
Varun916's Avatar
Thanks for the photos! That is super helpful. Yeah it does look like it'd be workable, though of course would need some testing to ensure it.
Edit: Though from those photos it seems as if the rod portion itself starts higher up on the ShiftR. That might be an issue, as the linkage/bracket is right below the plate (in fact I had to move the plate up a bit to accomodate it)
Varun916 is offline
post #14 of 104 (permalink) Old 02-17-2019, 06:27 PM
shay2nak
shay2nak's Avatar
I’ve been wanting this for years. I’d take one without a logo and brushed Al. Maybe even powder coated satin black.
Varun916 likes this.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #15 of 104 (permalink) Old 02-17-2019, 09:00 PM
NoRawkus305's Avatar
This is a great idea!!! Definitely in for a group buy. Seeing I have quite a few CF pieces including console, the Al might be a great contrast to it and go well with the rest of the stock Al. Subscribing!
Gabe
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is offline
post #16 of 104 (permalink) Old 02-17-2019, 10:43 PM
DrHeLpErZx's Avatar
Same, subscribed!
DrHeLpErZx is offline
post #17 of 104 (permalink) Old 02-18-2019, 09:19 AM
Supporting Vendor
shinoo's Avatar
This is a product that people will like. Getting the gated plate to line up with the top of the console may be the hardest part. The shift boot provides alot of flexibility for gear lever position variation. Wide slots may be the solution but will obviously need to be different when a short-shift kit is installed vs stock throws.
shinoo is offline
post #18 of 104 (permalink) Old 02-18-2019, 09:47 AM Thread Starter
Varun916's Avatar
Thanks for the tips Shinoo! Throw variability between cars is something I've been wondering about - I'd have imagined them to be relatively close, but I need to confirm that.
Varun916 is offline
post #19 of 104 (permalink) Old 02-18-2019, 09:51 AM Thread Starter
Varun916's Avatar
Good news everyone! I've partnered with Greg at @GregsRaceParts to bring this to market. There's a lot of testing we need to do first to make sure it'll actually be viable, but I'm optimistic that it'll all work out :-) Greg has laser engraving & anodization capabilities too, so that opens up possibilities.
Varun916 is offline
post #20 of 104 (permalink) Old 02-18-2019, 10:01 AM
richthom's Avatar
If done on a CNC mill,engraving could be done there.
Varun916 and Ryan... like this.
Richard 2006 Elise
richthom is offline
« Got Vanity Plate? | - »
Similar Threads
First mod: Stan's shifter mod hotspoons Lotus Elise 30 05-15-2014 02:41 PM
Another shifter stiffening mod. (Sector111 + Stan mod + this...) newman General Discussion (Lotus related) 3 01-12-2009 08:20 AM
Pass Airbag Mod / ABS Mod stinkoe General Discussion (Lotus related) 1 05-27-2008 06:09 AM
To Mod or not to Mod...that is the question sjkblack1 General Discussion (Lotus related) 20 01-20-2007 07:23 PM
Possible Shifter Cable Mod... Stan Interior/Exterior 6 07-31-2006 09:00 AM
