Was going to purchase a boe rear clam hinge questions before purchasing - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By indifferent
  • 1 Post By Nickshu
  • 1 Post By glb
post #1 of 19 (permalink) Old 11-03-2016, 11:55 AM Thread Starter
Brownzitto's Avatar
Hey I've had my 05 lotus Elise for 6 years now and I'm just starting to do work on it. i don't know what got into me . Had a couple questions before I buy the boe kit
1 will my aftermarket exhaust work with it (pictured I have no idea what brand it is) I guess the stock one doesn't work but I have no idea why
2 will I have to pull my hard top off every time I want to hinge my clam ?if so do they make quick release mounts for the hard top
3 is the boe the best on the market?
Thanks in advance mike
Brownzitto is offline
post #2 of 19 (permalink) Old 11-03-2016, 12:31 PM
indifferent's Avatar
1.) yes, but if the can is very large, like 7" in diameter or more it won't work perfectly. The reason for this is that the rear panel delete that comes with the kit will not clear the exhaust and thus you have to use the original panel, which just means you will have to remove the panel before hinging. However, I am pretty sure the one you have should work if it is not a stock.]
2.) Yes you will. The hard top is really easy to remove though! The reason it has to be removed is that it bolts to the roll bar cover which is that odd piece at the top of the rear clam. With a soft top, you will then have to remove two more bolts that hold the little rubber pieces the top slides into.
3.) Only one on the market, except for this: Modular Rear Clamshell Kit for Lotus Elise which is not a hinge, but still pretty easy and cost effective.
indifferent is offline
post #3 of 19 (permalink) Old 11-03-2016, 12:33 PM
rb26dett's Avatar
Hey Mike
1. You need an exhaust that exits above the diffuser
2. Yes you will need to take off the hard top each time. I'm not sure if the make quick release ones. I have an Exige and a carbon fiber roof. It only takes 4 bolts to remove my roof.
3. I'm not sure if BOE is the best. It is functional that's for sure. I've heard of a member making a kit in Australia but I don't think he makes them anymore.
rb26dett is offline
post #4 of 19 (permalink) Old 11-03-2016, 12:46 PM
1.) below the diffuser does work...99% sure...however, I think you have the 'top speed' exhaust which sticks out pretty far, so you may have clearance issues when fully opened. Talk to phil at BOE....he answers pretty quick usually
post #5 of 19 (permalink) Old 11-03-2016, 12:50 PM Thread Starter
Brownzitto's Avatar
Thankyou so much you saved me such a hassle. Love the accessibility and looks of it but I'm not about to buy a different exhaust
Thanks again
post #6 of 19 (permalink) Old 11-03-2016, 12:50 PM
post #7 of 19 (permalink) Old 11-03-2016, 12:55 PM Thread Starter
Brownzitto's Avatar
Sorry indifferent just saw your post I'll have to reach out to him. If I can keep my exhaust and it still work properly I'm back in the game lol
post #8 of 19 (permalink) Old 11-03-2016, 01:05 PM
Again, if the rear panel delete will work, then 99% sure the whole setup will work. Otherwise another 5 minutes of work each time...if you are not building a show car where you want to show off the engine, then do it. I like mine (didn't like the price), but overall it is has saved me a hundred hours by now.
Brownzitto likes this.
post #9 of 19 (permalink) Old 11-03-2016, 03:08 PM
Recreational Mechanic
Nickshu's Avatar
I bought the rear panel delete diffuser brace from BOE alone. (Not with the Clam hinge). I decided not to install it because I did not like the esthetics of how far inwards it mounts, basically right against the back surface of the muffler (Silent touch). It's a VERY nice piece, very well made and solid and I liked how it spreads out wide to the sides of the diffuser compared to the other braces out there but it's designed to work with the clam hinge which to me makes it's positioning a bit of a compromise. Just my opinion, YMMV.
Nick____________
2005 Elise - Chrome Orange (SOLD)
2004 Porsche 911 GT3
Nickshu is offline
post #10 of 19 (permalink) Old 02-21-2017, 12:59 PM Thread Starter
Brownzitto's Avatar
Just an update bought the boe kit awhile ago but just put it on. Everything worked perfect!!!! The exhaust worked well also the muffler is alittle close but works thanks for the he help guys !!!!!!!!!!
post #11 of 19 (permalink) Old 02-21-2017, 01:10 PM
Spartacus's Avatar
My kits been sitting around since November, just waiting to get a bit warmer! I like the stock rear panel look and I wonder if there's a way to keep that?
Spartacus is offline
post #12 of 19 (permalink) Old 02-21-2017, 03:06 PM
glb
glb's Avatar
My car is at BOE now.
As I understand it from Andrew, the stock panel must be removed to tilt clam.
3 bolts thru bottom of boot, 2 or 3 in sides of panel from clam.
Is "Titled Clam" the name of the bar on "Family Guy"?
(no)
darkSol likes this.
glb is offline
post #13 of 19 (permalink) Old 02-24-2017, 05:55 AM Thread Starter
Brownzitto's Avatar
You would be correct!!! thought I liked the stock better too untill I installed the new boe one then I changed my mind
post #14 of 19 (permalink) Old 05-28-2019, 05:35 PM
Kevin Michael's Avatar
Has anyone with a Larini Group B silencer installed the BOE clam hinge? It exits below the diffuser. In the worst case, I just use the original panel and have to remove that before hinging?
Thanks for any insights!
1974 Europa Twin Cam (gone but not forgotten)
1971 Europa S2 (owned but two months; flipped to raise funds to fill gap in college tuition)
35 years of restraint (including an Odyssey with 13 cupholders)
2005 Elise (magnetic blue), starshield, chin guards, Penske nonajustable shocks (BWR), Mishimoto sandwich plate, AEM oil temp and pressure gauges, third brake light flasher, Larini Group B silencer, Sector 111 DSBrace
Kevin Michael is offline
post #15 of 19 (permalink) Old 05-29-2019, 06:36 AM
CRG53's Avatar
I have the Larini Group B and Boe clam hinge. You HAVE to use the stock rear panel, there is not enough clearance between the Boe panel delete and the Group B.
The clam hinge work just fine, but you need to remove defuser and rear panel before you open up the clam.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is online now
post #16 of 19 (permalink) Old 05-29-2019, 08:09 AM
Thank you sir! Anything that allows me to not have to remove the seats is an immense improvement.
post #17 of 19 (permalink) Old 05-29-2019, 08:28 AM
Addict
LostPawn's Avatar
You can make some adjustments and not have to remove the seats going forward even without the BOE hinge, though the hinge is better than completely removing the clam all the time.
LostPawn is offline
post #18 of 19 (permalink) Old 05-30-2019, 02:44 AM
Thank you LostPawn. I am looking as well at the Radium kit. Seems a lot less fussy and only marginally more time to gain access to the engine bay. No wow factor, but that's not important to me. Pulling clam completely poses risks I am sure in terms of possible damage to it, but I expect my kids (twins) would be on board to help with the actual lifting, and it will be maybe a twice-a-year event. Only concern I have on the Radium is how well the body lines will line up. Glen ("Nein Kinder!") chose the Radium, which I put a lot of stock in. Have you chosen one of those options?
post #19 of 19 (permalink) Old 05-30-2019, 05:47 AM
Addict
LostPawn's Avatar
I have the Radium kit and it does make removal easy, still a two person job though. I chose that kit because I have yet to relocate the battery and have GRP's frame mounted wing that comes out behind the clam instead of through it. At some point I do plan to change to a more normal mounted wing and going with the clam hinge as it would make things that much easier and I wouldn't always have to find a place for the clam to sit while I work on the car.
LostPawn is offline
