HELP- locked out - LotusTalk - The Lotus Cars Community
post #1 of 26 (permalink) Old 08-04-2006, 06:22 PM Thread Starter
HELP- locked out
At work and my fob won't work and trying the key manually does nothing either.
The fob's battery seems to be fine as the light is brightly on when I press the button.
Don't know why the key won't work manually.
This sucks....I'm late to pick someone up and stranded!!!!
GregL is offline
post #2 of 26 (permalink) Old 08-04-2006, 06:26 PM
www.theapexinn.com
kestrel74's Avatar
http://www.elisetalk.com/forums/showthread.php?t=16320
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #3 of 26 (permalink) Old 08-04-2006, 06:28 PM
www.theapexinn.com
kestrel74's Avatar
OR: http://www.elisetalk.com/forums/show...ghlight=unlock
www.theapexinn.com
post #4 of 26 (permalink) Old 08-04-2006, 06:29 PM Thread Starter
Can someone do better than that....
seems a bit complicated to do with an alarm screeming in your ear.
Don't really understand it either.
GregL is offline
post #5 of 26 (permalink) Old 08-04-2006, 06:33 PM
chiuman's Avatar
According to the manual "in the event of a flat battery, the CDL will not operate. The doors can be unlocked from the outside only after opening the engine cover and restoring power to the battery..." it also says the doors cannot be unlocked manually if you locked them using the key fob.
chiuman is offline
post #6 of 26 (permalink) Old 08-04-2006, 06:34 PM Thread Starter
so what do I do????
GregL is offline
post #7 of 26 (permalink) Old 08-04-2006, 06:35 PM
OSX Black hat
charliex's Avatar
you have to do the fob 'resync' code with the alarm, which does involve setting the alarm off a couple of times
http://www.elisetalk.com/forums/showthread.php?t=10962
hopefully someone has clearer instructions than mine, qias at south bay told me what it was.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #8 of 26 (permalink) Old 08-04-2006, 06:36 PM
chiuman's Avatar
Try and get a jump start from someone, or call AAA I guess. I'm assuming you can still open the engine cover.
chiuman is offline
post #9 of 26 (permalink) Old 08-04-2006, 06:37 PM
www.theapexinn.com
kestrel74's Avatar
Keep the emergency unlock procedure in your trunk in case you need it. If your fob stops working, the key won't get you into your car. (Note: removing the battery from fob for 10 secs. & replacing may resolve your fob issue, so try that 1st.)
www.theapexinn.com
post #10 of 26 (permalink) Old 08-04-2006, 06:39 PM Thread Starter
Can someone give me the alrm reset procedure so I can try that?
Don't know how/why my battery could be dead?
GregL is offline
post #11 of 26 (permalink) Old 08-04-2006, 06:39 PM
onecall1's Avatar
This happened to me coming out of the winter. Forget A/C issues, forget window regulator issues....this is by far the stupidest design Lotus could have come up with. Why the key is designed not to work in this situation is assnine.
Former Elise and Esprit owner. Currently enjoying my M3 purchased from HRM.
onecall1 is offline
post #12 of 26 (permalink) Old 08-04-2006, 06:40 PM
chiuman's Avatar
Yes, I skipped over this part in the manual.
To resync.
-Stand close to the car and hold both buttons on the fob down until the LED on the fob goes out (~10sec)
-Release both buttons the fob LED should come on constantly
-Press the larger fob button for 1 sec, the LED should flash and your done.
chiuman is offline
post #13 of 26 (permalink) Old 08-04-2006, 06:54 PM
EburgE's Avatar
Get a cab. Do it tomorrow.
'05 Lotus Elise
'07 Caterham Seven www.hals7.com
EburgE is offline
post #14 of 26 (permalink) Old 08-04-2006, 09:40 PM
Tyger's Avatar
Just because his fob doesnt unlock the doors doesnt mean his car battery is dead. And (assuming it's an Elise) the key DOES unlock the engine cover. What kind of car do you have chiuman???
The LAST thing I would do is call AAA. First thing to try is the fob resynch, described in this thread. If the windows are ajar, you can also try getting a coathanger to pull up the locking posts, or maybe to hit the interior unlock button. OR, you can try the inertia switch proceedure described elsewhere on this site. All of these assume the car battery is not dead.
The keys do not operate the door latch mechanism. All they can do is disconnect the outer buttons from said mechanism as an alternative (and separate) way to lock/unlock the car from the electric system.
Tyger is offline
post #15 of 26 (permalink) Old 08-05-2006, 09:03 AM Thread Starter
Just needed to re-sync fob....
Thanks...
glad I didn't try to boost the battery!
GregL is offline
post #16 of 26 (permalink) Old 08-05-2006, 09:04 AM Thread Starter
oh yeah....
how and why did this happen?
GregL is offline
post #17 of 26 (permalink) Old 08-05-2006, 11:08 AM
OSX Black hat
charliex's Avatar
Cosmic rays
It only ever happened to me the one time, i changed the batteries in the fob, whether or not they needed to be.
charliex is offline
post #18 of 26 (permalink) Old 08-06-2006, 07:55 AM
Tyger's Avatar
The fobs seem to get gradually out of sync over time, more so if you are not using the car that often, or if you use one fob a lot and then try to use the other one. If you find that your fob is working but you have to get really close or hold the button down for a while, try doing a resynch. It doesnt take much time or effort and it can really make a big difference.
Tyger is offline
post #19 of 26 (permalink) Old 08-06-2006, 08:09 PM
After reading this thread, it made me realize that lately I have to be very close to the car to have the FOB work. I decided to change out the battery today. Wow, what a difference. Now I can get at least 5 feet away. I swapped out the battery rather quickly hoping to avoid the FOB from doing some sort of reset. It worked fine with no re-syncronizing require. Just my $.02
2005 Ardent Red Elise--Touring--Hard Top
2000 MR2 Spyder....Also Red
2007 Ducati Monster ... Yea, Yea...It's red too
111Dano is offline
post #20 of 26 (permalink) Old 08-06-2006, 08:16 PM
Eclise's Avatar
In regards to the resync procedure, Charlie's thread says to hit the small button on the second step, while Chiuman says to hit the large button in this step. Can anyone clarify?
If Keeper is reading, it may be a good idea to put the resync instructions in the Uberpost.
Eclise is offline
