How to attach and aftermarket roof to an elige window frame - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 02-27-2019, 01:06 PM Thread Starter
kfennell's Avatar
I know that the correct answer is to get a cage, but that is a later this year project. For now, how can I attach the roof to the front window frame the most securely. It appears that most of the frame is just foam? Is there a part on top, or near the channel that is solid? Does anyone have a picture of one cut in half for some reason?
Thanks!
kfennell is online now
post #2 of 7 (permalink) Old 02-27-2019, 01:24 PM
cyow5's Avatar
There has to be solid in there for rollover protection, but drilling into that will surely weaken it. How much? Who knows, but I would rather focus on utilizing the factory points for the roof at the corners.
cyow5 is offline
post #3 of 7 (permalink) Old 02-27-2019, 01:27 PM Thread Starter
kfennell's Avatar
Wont work, the roof is not nearly stiff enough for that. Has to be closer to the center.
There is no way that the factory window provides ANY rollover protection. Have you leaned on it? And the whole operation is just glued to the car.
post #4 of 7 (permalink) Old 02-27-2019, 02:15 PM
Addict
LostPawn's Avatar
You could just put a brace down the middle of the windshield. I've seen a couple of these on race cars with the Lexan windshields, maybe that would work until you have a cage.
LostPawn is offline
post #5 of 7 (permalink) Old 02-28-2019, 07:34 AM
TedR's Avatar
How would you attach the roof to the cage? I would think there is a little bit of flex between the windshield frame and the forward roll hoop.
It sounds like you need a series of threaded nut inserts in the windshield frame. Fasten the top down with countersunk allen screws and aluminum conical washers (used on racing karts).
TedR is offline
post #6 of 7 (permalink) Old 02-28-2019, 08:08 AM
cyow5's Avatar
The whole car is glued together, so that's not a very strong argument. That being said, I checked the service manual and the frame is ICSRTM (same as the Elise front and rear clamshells). You can probably sand it down enough to get a lean surface and then epoxy hardware on to attach the roof with. Maybe something like four or five threaded inserts.
cyow5 is offline
post #7 of 7 (permalink) Old 02-28-2019, 08:16 AM
If you are going to put a cage in, figure out where the mounts will be for the cage. Make bars that run front to rear and put clamps that clamp the windshield frame and rear roll over structure . Think of the rear center roof bracket times 4
exigegus is online now
Similar Threads
Left side ( drivers) frame section , cut frame rail and door mount MP51098 Parts For Sale 0 02-22-2015 11:10 AM
How does the Sector111 shower cap attach in the rear? kabinski General Discussion (Lotus related) 1 01-27-2010 07:10 PM
Will the Lanari Sport Cat attach ok to an Arqray single tip? Shawn C Intake and Exhausts 0 08-15-2007 11:13 AM
How to attach something to the carpeting? Shiftlock General Discussion (Lotus related) 17 01-18-2007 09:57 AM
