How do you remove speaker cover in an 08 Exige? - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 02-10-2019, 07:13 PM Thread Starter
I'm trying to remove the rear clam and have arrived at the point the speaker surround needs to be removed. Unfortunately the harness bar runs right through it. I know this has to be simple, but not simple enough for me.
Troublemaker is offline
post #2 of 7 (permalink) Old 02-10-2019, 07:23 PM
Addict
LostPawn's Avatar
Remove the harness bar. There is not much room for the socket and ratchet so use a low profile one if you have it.
LostPawn is offline
post #3 of 7 (permalink) Old 02-10-2019, 07:36 PM Thread Starter
Iíll bring one down if I have to, to get this done. Thanks
post #4 of 7 (permalink) Old 02-11-2019, 06:37 PM
You donít have to remove the harness bar. For the difficult screws I used a short Phillips head ďbitĒ (with a hex end), but instead of putting it in a drill or socket handle, I used a small closed end wrench to turn the bit (SAE, but I forget what size). Make sense? Itís like a very short, right angled screwdriver. If you put a little tape on the hex end of the Phillips bit you can jam it into the wrench so it doesnít fall out.
HTH, -Ed
-Ed
'08 Arctic Silver Exige S240
AustinP is offline
post #5 of 7 (permalink) Old 02-11-2019, 07:03 PM
I believe it should be a 5/16Ē wrench size for those bits
Falsey is offline
post #6 of 7 (permalink) Old 02-11-2019, 07:46 PM
Addict
LostPawn's Avatar
Originally Posted by AustinP View Post
You don’t have to remove the harness bar. For the difficult screws I used a short Phillips head “bit” (with a hex end), but instead of putting it in a drill or socket handle, I used a small closed end wrench to turn the bit (SAE, but I forget what size). Make sense? It’s like a very short, right angled screwdriver. If you put a little tape on the hex end of the Phillips bit you can jam it into the wrench so it doesn’t fall out.
HTH, -Ed
Maybe I miss understood but I think the OP needs to remove the whole pannel to access the bolts holding the rear clam on and not just a speaker cover. I am not sure that pannel comes out with the harness bar in place.
Edit: I see some threads saying you can remove those bolts through the speaker hole, I thouht removing the harness bar was easy enough.
LostPawn is offline
post #7 of 7 (permalink) Old 02-12-2019, 02:55 AM
Itís a bit of a blind reach, but yes you can remove those bolts through the speaker holes, thatís how I did it. Faster, but maybe not easier than removing the harness bar and rear panel.
-Ed
-Ed
AustinP is offline
Similar Threads
Do you void the warranty when you remove the dash? jbs Maintenance and Repairs. 3 04-08-2009 04:07 AM
How do you remove the stock Alpine speaker grills? BatmobileS240 Audio, Video, GPS, Radar Detectors & Other Accessories 6 06-29-2008 02:06 PM
Speaker upgrade with OEM harness bar / speaker pod Lotusmotion Audio, Video, GPS, Radar Detectors & Other Accessories 8 03-28-2007 09:17 AM
how do you remove the sill cover? carl Maintenance and Repairs. 2 12-26-2005 09:35 AM
