I want the Exige, but those clamshell replacement costs... - LotusTalk - The Lotus Cars Community
 11Likes
  • 11 Post By me73
post #1 of 16 (permalink) Old 07-14-2019, 08:10 PM Thread Starter
Ive been extensively researching about the Elise/Exige as I am keen on purchasing one; however reading about the replacement costs of these clamshells are definitely making me rethink. Is the Evora the same way with clamshells? Some of these costs to get these clamshells replaced are outrageously expensive!
Jspecd is offline
post #2 of 16 (permalink) Old 07-14-2019, 08:16 PM
lt1_fd3s's Avatar
it's a very large piece of fiberglass (composite)... so the $3k price for a refurbished one seems pretty reasonable... that if some reason the clam can't be repaired
WNC Tour Guide - WNC Drives (click me!)
'93 Vintage Red RX-7 - NA 20B
'06 Chili Red Exige - RIP 2017.12.01
'06 Ardent Red Exige Katana2 - try this again
lt1_fd3s is offline
post #3 of 16 (permalink) Old 07-14-2019, 08:31 PM Thread Starter
Hmm I wasnt aware that the clam can be repaired. That would be significantly cheaper than having to have the whole clam replaced? Everything else seems reasonable cost wise, its just the clamshell costs that are off putting.
Jspecd is offline
post #4 of 16 (permalink) Old 07-14-2019, 09:02 PM
Less is Better
me73's Avatar
Don't hit things.
smokin orange, Motard, CMP and 8 others like this.
me73 is offline
post #5 of 16 (permalink) Old 07-15-2019, 02:14 AM
keep it insured
All fiberglass parts can be repaired
exigegus is online now
post #6 of 16 (permalink) Old 07-15-2019, 04:38 AM
lt1_fd3s's Avatar
There are several "reconstruction" threads around that show people repairing damaged clams - I'm just not able to find one quickly the moment. I do recall seeing one of a rear clam with a lower right sections just above the exhaust being cut out and a patch from another damaged clam being glassed back in.
Also, if you look up InoKinetic's (Found it!) Spyder build, you can see where they repaired a door - not a clam, but same materials
lt1_fd3s is offline
post #7 of 16 (permalink) Old 07-15-2019, 06:42 AM
Fiberglass repair is a skill. It's a rare skill most places (because complex curves in large fiberglass structures are rare compared to stamped sheet metal, for instance), but not especially hard to learn if you have the right motor skills and some patience.
It's more like lath-and-plaster or drywall repair work than any other more common skill I can name: you start off with something semi-liquid and sculpt it into something solid. In both cases, you do the rough work by forming it in the liquid state, and then sculpt by material removal once it has hardened. It's common to use temporary molds made of paperboard, corrugated cardboard, thin plywood, etc to hold the floppy fiberglass and resin in the desired shape while it cures.
The good news is that it's as permanent as you want it to be - if you make a mistake, you can cut/grind it out and start over. Better quality fiberglass work is lighter and stronger than poorer quality work - you can spot an amateur job because it will look lumpy/heavy on the backside, even if the front side looks OK.
There's nothing special I can name about Lotus FG panels versus the FG on my Casita camper, a fiberglass boat, or a Corvette. Repair/modification methods are the same in all cases.
Exige clams are laid-up fiberglass like the panels on an Elan, for example. Elise clams are actually die molded FRP. The same FG repair techniques work equally well for both.
steelypip is offline
post #8 of 16 (permalink) Old 07-15-2019, 08:28 AM
NoRawkus305's Avatar
If you really want one, I wouldnít let clamshell costs stop you. Thatís why we have insurance to alleviate majority of any repair costs. As others mentioned, it can be replaced or repaired on the extent of the damage. Although, with the age of the Elise/exige(fed lotus), any replacement clam will probably be a total loss. Rare case where only the clam was damaged and needs replacement without anything else needing repair. With the newer evoras, probably wonít be a total.
I have a $250 deductible so I donít worry too much and just try to enjoy. With that said, Iím still very careful and aware of my surroundings, where I park, or what location Iím going to, if there is a parking lot or not, etc. GLWS!
Gabe
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is offline
post #9 of 16 (permalink) Old 07-15-2019, 05:59 PM
smokin orange's Avatar
Drive one knocking on the door of 300hp, set up and not sure there is anything that will give you the same thrill for even a lot more money, speed yes, thrill, no.
Itís like. A raw piece of steak, yet a scalpel all in one.
2008 Exige S 240
2010 Toyota FJ TRD
2015 BMW M235 Convertible
2000 Jeep Wrangler Sahara
1978 Toyota FJ40
2008 Beneteau Oceanis 40 Sailboat
1973 Colombia 26 MK11 sailboat
smokin orange is offline
post #10 of 16 (permalink) Old 07-15-2019, 07:34 PM
mbrunner's Avatar
When I was shopping cars it crossed my mind, then I thought how silly it sounded to exclude a car from my list because of the possible cost of balling it up.
mbrunner is offline
post #11 of 16 (permalink) Old 07-16-2019, 09:45 AM
David Craig's Avatar
Damaging a clamshell is something I worry about too.
Luckily I've been able to avoid any damage in my 10 years of Elise ownership.
Main tips are:
1) Never parallel park the car.
2) Stay well back at intersections and have your hand ready on the horn.
3) Stay out of blind spots.
David Craig is offline
post #12 of 16 (permalink) Old 07-16-2019, 10:11 AM
the1tonton's Avatar
I bought a salvage one recently and was dreading the clam price, but i contacted a boat builder who repaired my clam easily. Once we peeled the clearbra off the damage was not too bad. Any low speed damage will not cost an arm and a leg if you shop around. Exige clams in particular are easier to repair than the Elise clams.
the1tonton is offline
post #13 of 16 (permalink) Old 07-16-2019, 10:34 AM
I find parallel parking not particularly daunting.
It like to park where the other cars do not have to slide in or out. Like a row of only 2 or 3 between driveways or fire hydrants etc
Be at the beginning or end[although the middle is best in a row of 3]
Don't squeeze in a tight place.
REgular parking lots are just as bad, I park in empty areas.
I tend not to pull too far in[makes the space look empty till they start to pull in]
I like to park at the end of the line[only one side exposed]
Its a car, it can be fixed.
post #14 of 16 (permalink) Old 07-20-2019, 12:29 PM Thread Starter
Thanks everyone! This really put my mind at ease. I definitely would love to have a Lotus. I'll just keep full insurance on it and be careful with it.
Jspecd is offline
post #15 of 16 (permalink) Old 07-20-2019, 04:07 PM
XHILR8N!'s Avatar
Can’t even imagine parallel parking any vehicle I care a lot about, I don’t even like to with my daily Honda Si.
Our Elise is on it’s fourth front clam. Two destroyed with big offs (just after being) on track. Did one track only race clam (no lights) and then yet another when returned to street duty. Took her out today!
So it can be done.
Insurance, including track insurance, is your friend.
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #16 of 16 (permalink) Old 07-22-2019, 07:07 PM
daz01's Avatar
Bit wierd post this. Pretty much any car can be expensive if something wrong happens. Fiberglass can be repaired in most cases and not that hard... can't see why that one factor is a worry.
daz01 is offline
