Pro Alloy Intercooler Temp Change? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 05-08-2019, 03:46 AM Thread Starter
Recently installed a ProAlloy Intercooler on my Exige S w/side air intakes and engine temp is now
averaging a bit hotter than before. Was running 186-190 pre install now running 190-195 depending
on traffic. My guess is the reduced air flow thru side intakes. During install changed coolant hoses,
thermostat, water pump, belt and tensioner, new Inugel coolant and bled system, lengthy process.
Anyone else had this situation?
BondoRobert is offline
post #2 of 4 (permalink) Old 05-08-2019, 05:28 AM
275 Turbo's Avatar
I would be surprised if the ducts being partially blocked by the pro alloy scoops caused the engine to heat up 10degs. Is the thermostat temp/model the same as before?
2005 Elise 111R, 2litre, 315hp, FF275 Turbo kit 6lbs. Soon to be 400+
275 Turbo is offline
post #3 of 4 (permalink) Old 05-08-2019, 05:45 AM
I would be more likely to guess the thermostat change
I will say I did a BOE tune with new intercooler and my car runs around 4 degrees warmer, but who knows......
exigegus is online now
post #4 of 4 (permalink) Old 05-08-2019, 05:55 AM
mrfunstuff's Avatar
Yeah I’d agree with above posters. I installed that intercooler with side ducts and had no change in temps. When I made changes to my cooling system, temps varied up a bit.
mrfunstuff is offline
Similar Threads
BNIB: Speedhut Oil PSI, Oil Temp, Water Temp, Diff Temp, Fuel PSI Gauges!!! Sammy Sandbag Parts For Sale 0 07-25-2013 04:31 PM
Any reviews of the Pro Alloy Radiator? Ghussey Engine Cooling 5 04-11-2010 09:48 PM
FS: Davtron 308FD Intercooler temp / differential temp gauge Frank Amoroso Parts For Sale 2 03-24-2010 06:37 AM
PRO ALLOY RADIATOR dmh Parts For Sale 6 07-06-2009 03:50 PM
Pro Alloy Install Gripp Intake and Exhausts 6 03-28-2009 06:11 PM
