@&$#% punk backed into my 05 Elise tonight!!! - LotusTalk - The Lotus Cars Community
 10Likes
  • 2 Post By 4380r
  • 1 Post By khamai
  • 2 Post By Roundabout
  • 4 Post By CMP
  • 1 Post By Roundabout
post #1 of 15 (permalink) Old 09-15-2019, 10:17 PM Thread Starter
e-Lise's Avatar
I was stopped at a traffic light around 9:30 tonight when some kid in a Toyota Corolla in front of me decides to put his car in reverse and back up. I leaned on the horn but he keep going and hit me. He claims he didn’t see me. Has anyone recovered from this much damage and what can I expect? Many thanks, all.
e-Lise is offline
post #2 of 15 (permalink) Old 09-16-2019, 01:51 AM
I can be fixed, might get pricey if the crash structure is damaged.
I would personally try to make it so they don't total it
Waht is it with people backing up in the street..........
exigegus is online now
post #3 of 15 (permalink) Old 09-16-2019, 02:44 AM
4380r's Avatar
Ouch. On the plus side, while the clam is off, you can install a better horn.
NumberSix and Jetblast like this.
Owned, loved, enjoyed, and now gone:
1969 Europa S2 Blue
1970 Europa S2 White
1974 Europa Twin Cam Blue
1984 Turbo Esprit Calypso Red
2005 Elise Starlight Black
2005 Elise Saffron Yellow
2005 Elise Ardent Red
2006 Exige Graphite Grey
2007 Exige Canyon Red
Other:
1970 MGB GT
1970 Datsun 510
1984 Honda CRX Si
1984 Pontiac Fiero
2004 Chrysler Crossfire
2009 Pontiac Solstice Coupe
4380r is offline
post #4 of 15 (permalink) Old 09-16-2019, 08:38 AM
glb
glb's Avatar
Whatever do you mean???
um.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f31...-u-tube-47232/
https://www.lotustalk.com/forums/f32...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f10...brakes-241138/
How to Search:
glb is online now
post #5 of 15 (permalink) Old 09-16-2019, 09:08 AM
Race & Pamper
Kubera's Avatar
Clam can be repaired by a proper fiberglass expert.
Will send you referral to the best shop around.
Kubera is offline
post #6 of 15 (permalink) Old 09-16-2019, 09:44 AM
and fix/improve the HVAC... I have no idea what the solution is for this level of idiocy, but it's obviously a problem. Just in the last year several elige owners have reported morons backing into their cars despite honking horns and flashing lights. Good luck with the insurance. And for the record, "I didn't see him" is an admission that he was not aware of his surroundings.
steelypip is offline
post #7 of 15 (permalink) Old 09-16-2019, 10:34 AM
Kevin Michael's Avatar
I wouldn't anticipate any issues with the other driver being at fault. May as well consider the radiator if it is stock. I'm planning to put in a pro alloy from BOE this winter.
1974 Europa Twin Cam (gone but not forgotten)
1971 Europa S2 (owned but two months; flipped to raise funds to fill gap in college tuition)
35 years of restraint (including an Odyssey with 13 cupholders)
2005 Elise (magnetic blue), starshield, chin guards, Penske nonajustable shocks (BWR), Mishimoto sandwich plate, AEM oil temp and pressure gauges, third brake light flasher, Larini Group B silencer, Sector 111 DSBrace
Kevin Michael is offline
post #8 of 15 (permalink) Old 09-16-2019, 11:59 AM
khamai's Avatar
I would add to the list of "DOs".
Avoid placing your Elise/Exige in a position where it can't be seen by the other driver(s). At stop lights ALWAYS make sure you can be seen by the other driver in their mirror(s). For example, don't pull up so close behind a pick-up truck that you can't see the driver's eyes in at least 2 of their mirrors. This may mean stopping further behind than usual and off to one side.
Kiyoshi
P.S. This is a clam replacement. Hopefully no damage to the crash structure (which would mean a write-off).
mattjk likes this.
Lotus events in California - www.gglotus.org
khamai is offline
post #9 of 15 (permalink) Old 09-16-2019, 12:33 PM
glb
glb's Avatar
Weirdly, I don't remember seeing anyone back up in traffic in my NJ/NY/PA area.
But, no one doesn't hear my horn.
(Khamai has great info in his post.)
Flashing lights: no value if person doesn't look or see you.
glb is online now
post #10 of 15 (permalink) Old 09-16-2019, 03:52 PM
David Craig's Avatar
In Toronto, I often see people back up at intersections. They pull into the intersection or across a crosswalk and then the light turns red and they back up.
David Craig is offline
post #11 of 15 (permalink) Old 09-16-2019, 04:46 PM
glb
glb's Avatar
As my "Notes" say, I drive with my finger on the horn buttons.
glb is online now
post #12 of 15 (permalink) Old 09-19-2019, 05:06 PM
Speedfreek's Avatar
So sorry to see this happen to you, I know the feeling
In 2009, my Lotus was hit by an airport shuttle driver, taking out my clam and crash structure. No fault of mine.
There was no chassis damage only the carbon fiber crash structure and fiberglass clam and radiator.
That said I took it to an authorized dealer repair facility, it took 6 weeks to repair (mostly due to the availability of a replacement clam and the crash structure from the factory) The total bill was $28K.
Since it's the other drivers fault (and I assume they have insurance) you'll likely get push back on their insurance, however they shouldn't total - and at least in the state of California, they are responsible for putting the car back into usable form or finding you a replacement. You or your repair facility will find this the biggest stumbling block these days as the factory doesn't build these in any regularity for the last 5 years or so. There are several sources for rebuilt/refurbished clams, not too sure on the crash structure... Text me if you need links for sources.
They may ask you not to use authorized repair facility, however I would recommend holding tough on this. If for some reason they balk at the repair cost through authorized repair, then make sure they suggest and guarantee the work for alternative.
I've only had one insurance company (in roughly 5 incidents) not work with me to get it repaired at the facility of my choice.
I wish you luck. You should consider putting an Aluminum radiator if you haven't already - to replace the lousy original equipment that tends to rust and crack.
Good luck feel free to reach out if you need any further advice.
2005 Lotus Elise, Sport & Tour
1964 Cadillac Eldorado Convertible
Speedfreek is offline
post #13 of 15 (permalink) Old 09-20-2019, 12:02 AM
Roundabout's Avatar
A young lady in a Camry somehow accidentally shifted her automatic into reverse and floored the throttle and hit the front of my car. There was a guy standing on the corner waving a sign that apparently got her excited. Thankfully I wasn't driving the Lotus. As is typical, she bolted when the light turned green and I followed her to work some non-threatening distance behind. When I got out of my car, she claimed that she was late for work and that's why she didn't stop. Then she explained that she was a massage therapist and offered me a free massage.
David Craig and CMP like this.
Roundabout is offline
post #14 of 15 (permalink) Old 09-21-2019, 05:21 AM
CMP
CMP's Avatar
so,... does this story have a happy ending?
glb, NumberSix, morrissey and 1 others like this.
Oh snap! I'm on fire!
CMP is offline
post #15 of 15 (permalink) Old 09-23-2019, 09:24 PM
Roundabout's Avatar
Yes, the story ended well. I didn't notice the cracked headlight until a month later, I felt it was a small price to pay for the overall experience; all things considered.
jhentr likes this.
