recommended adhesive for soft top clip? - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 02-06-2019, 02:57 AM Thread Starter
dviolet8981's Avatar
Noticed the black plastic piece that the soft top plastic support rods sits in was loose while I was cleaning over the weekend and it came flying off yesterday. What’s the best way to stick it back on?
dviolet8981 is offline
post #2 of 7 (permalink) Old 02-06-2019, 04:11 AM
cyow5's Avatar
I'd buy some 3m automotive trim tape, cut it into slivers, and hold it on with those. You want something removable if the need ever arises.
It's funny though, mine are held on by giant globs of a rubbery glue on the backside, and they were a nightmare to remove.
cyow5 is online now
post #3 of 7 (permalink) Old 02-06-2019, 07:15 AM
David Craig's Avatar
I would use caulking if you have some handy.
David Craig is offline
post #4 of 7 (permalink) Old 02-06-2019, 07:26 AM
I'd use (Permatex) clear RTV glue/sealant. Clean both mating surfaces thoroughly, then apply a small bead in the crevice on the back side of the fitting, then stick it back in where it goes. Wipe the excess off with a paper towel. Put a top bow in on that side to apply compression to the fitting while the glue sets. Come back 12 hours later and it'll be stuck in there, and completely watertight into the bargain.
If the silicone didn't do the trick, probably the next step would be a urethane glue like 'gorilla glue.' Should stick well to both surfaces, and positively won't come off. I don't like it as well as the RTV silicone for this sort of use because it isn't as nice to things when it fails.
I wouldn't use the VHB tape because it doesn't fill gaps as well as a liquid.
steelypip is online now
post #5 of 7 (permalink) Old 02-06-2019, 06:40 PM
I used a pea-sized blob of black RTV years ago. It's strong enough to hold it in place, yet can be cut/pulled out if need be.
Pengineer91 is offline
post #6 of 7 (permalink) Old 02-07-2019, 03:14 AM Thread Starter
Appreciate the input thank you!
post #7 of 7 (permalink) Old 02-07-2019, 04:01 AM
I use Henry's 212 crystal clear sealant 10.1 oz cartridge available from big box stores. It remains flexible, drys clear and I find that it bonds stronger than clear silicon. I used it to keep condensate tube from flopping around and between rain showers if needed I can jump up on the roof and do repairs lol.
Catsailr27 is offline
Similar Threads
Anybody know the glue/adhesive used beween gasket and canvase on soft tops? ewalberg Interior/Exterior 0 12-18-2012 10:59 AM
FS: Exige Insulated Soft Top + Bows + Soft Top Bag + Hard Top Bag jsottile Parts For Sale 1 06-29-2011 06:54 AM
Recommended weathersripping adhesive? Rickster Maintenance and Repairs. 1 07-13-2010 07:00 PM
Hard/soft top mounting clip Rom Interior/Exterior 2 01-19-2009 04:02 PM
Need Help: Converting From Soft Long-Top to Soft Short Top Roof Shadow_iX Other Lotus Models 3 01-15-2009 11:30 PM
