Wheel stud kit - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 05-10-2019, 12:43 AM Thread Starter
Wheel stud kit
What is a good source for a wheel stud kit?
I bought a Ti set through a group buy from a *source*. Parts looked great. I installed with studs and when I went to put my LSS wheels on I noticed some of the studs were less than straight, I thought it was possibly an optical illusion so I proceeded. Then I went to install the lugs. In my opinion the lug hex was too big. My non impact socket barely fit within the lug pocket on the wheels. This meant that since the studs are now confirmed not straight, the socket rubbed the crap out of the lug pocket.
One of the nuts even galled on the stud and seized, with an impact I was able to back it out taking the whole stud out of the hub, but the pair is junk.
Will Ti nuts/studs, do this? Gall after time? Better to go with steel? If not, who sells a quality set? If so, what is a good set that should not rust.
Thanks!
2010 Lotus Exige S240
2001 BMW M5
2017 Ford Raptor
2018 Jeep Grand Cherokee Trackhawk (wife-mobile)
REKIII is offline
post #2 of 3 (permalink) Old 05-10-2019, 05:52 AM
The Enforcer
oldmansan's Avatar
BWR is what I'm using. ARP fasteners. https://www.blackwatchracing.com/Lot...its-p/1066.htm
If you're going with titanium, you need to use TiPrep or a similar product to prevent galling.
San
oldmansan is offline
post #3 of 3 (permalink) Old 05-10-2019, 05:59 AM
kfennell's Avatar
I use all BMW stuff, you want these ones here in whatever length is appropriate for your use.
https://www.bimmerworld.com/Wheels-T...Stud-92MM.html
They have a flat shoulder so it is clear when they are tight in the hub, and they have the easy to use bullet nose.
You use this tool to install and remove them
And you use these nuts which work with a 17mm socket which easily fits in LSS wheels and all tuner wheels.
https://www.bimmerworld.com/Wheels-T...-M12-17mm.html
kfennell is offline
Similar Threads
Wheel Stud Kit Comparison monkeyboo Suspension (including wheels, tires, brakes) 31 10-16-2010 07:41 PM
FS: Blackwatch racing Wheel stud kit. NEW (incomplete) del105 Parts For Sale 0 02-27-2008 03:50 PM
FS Wheel stud kit + spacers Dark_helmet Parts For Sale 2 04-20-2007 12:54 PM
Help installing Blackwatch Wheel Stud Kit Bill Suspension (including wheels, tires, brakes) 31 03-01-2007 09:45 PM
Wheel Stud Kit lundgren Suspension (including wheels, tires, brakes) 10 11-28-2005 07:10 PM
