Aftermarket Radiator Thermostat Compatibility - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 10-01-2014, 12:55 PM Thread Starter
Akatedjonez's Avatar
Has anyone heard anything about aftermarket radiators on the Elise not being compatible with OEM thermostats? Any expert knowledge would be appreciated; have a friend who really needs to know. Thanks!
(and yes I tried searching the forum and google)
Akatedjonez is offline
post #2 of 4 (permalink) Old 10-01-2014, 01:15 PM
doug_porsche's Avatar
do you have more information on this?
The radiator is about 6 to 10 feet away from the thermostat, so its not a physical problem.
That would leave heat. I would hope any aftermarket radiator would hold up to the 250ish deg that our car can throw at it.
That aside; I have been running a Wizard radiator for over a year on the same 170deg thermostat that was in the car before the swap. (Yep, I swapped the failed 180deg factory tstat for the 170deg tstat probably close to 3 years ago.)
Apexes are a lot like relationships. So tough to get right, so easy to see where they went wrong.
The secret to a long life is ------- not dying.
doug_porsche is offline
post #3 of 4 (permalink) Old 10-01-2014, 03:44 PM
Motard's Avatar
doug_porsche,
What is the stasis temperature your cars is at with your setup ? I have a similar setup and I rest at 174F. Prior to all my modifications it would rest at 190F
I am honestly not certain if that is good or bad with these engines which shows how ignorant I am sometimes when I start modifying... It runs without a hickup just 16 degrees cooler on average. I assume that is good! I went to a awful amount of trouble getting it there! heh
L O T U S
Motard is offline
post #4 of 4 (permalink) Old 10-01-2014, 05:52 PM
yep, 172 - 174ish in normal cruise. 180ies when playing on back roads. I have to remind myself that 190 was normal, not hot.
