Car Overheating - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 25 (permalink) Old 11-13-2014, 01:14 PM
That must have been quite a bit of air in the system! If the problem just came about, it might be a good time to check for leaks.
Nessal is offline
post #22 of 25 (permalink) Old 11-13-2014, 02:06 PM
glb
glb's Avatar
Yes.
The cooling system is pressurized when warm.
Does that mean air got sucked in when it cooled?
Would air go in but no coolant out? I doubt it, given the pressure in system.
glb is offline
post #23 of 25 (permalink) Old 11-15-2014, 12:50 PM Thread Starter
Lotus Driving Academy
102ndcar's Avatar
Upon further inspection yesterday, I found fluid dripping front driver side rad fan, and a little underneath rad but it is catching on plate so I couldn't see it except through the grill at license plate bracket.. Back on duty until Monday so I cant inspect more yet.. I really hope this doesn't mean I need a new rad.
102ndcar is offline
post #24 of 25 (permalink) Old 11-15-2014, 02:10 PM
holmz's Avatar
You can hope it might only be a loose hose clamp...
It certainly sounds like you have found the reason the air is getting in.
holmz is offline
post #25 of 25 (permalink) Old 09-26-2016, 10:00 AM
sleepe's Avatar
Is there a recommended method for coolant bleeding?
I opened the rear bleeder and released fluid and removed a bit from the
tank (over filled after Radium install) but temps are still higher than
normal, but only by a few degrees.
2006 Elise ST (someone else has it now . . . )
2008 Exige S240 ST
sleepe is online now
