Changing the coolant - Page 7 - LotusTalk - The Lotus Cars Community
post #121 of 129 (permalink) Old 11-04-2012, 08:59 AM
Originally Posted by tvacc View Post
I realize it has been two years since I posted I was going to do this, but I just did it tonight. I found the Peak Global at Tractor supply. Bought all 6 gal of the 50/50 (all they had in both quantity and kind). Everything went well. How we got it done was to use my pressure regulator to bring my hose pressure down to 5 pounds. Then I put a nozzle blower on the over fill line and it pushed the antifreeze right in. did it two or three times. Started the car two times and had to refill.
Will drive it tomorrow to see how it does.
Would be great if you can elaborate on how you did the coolant flush. Thanks.
2009 Elise SC
Surge is offline
post #123 of 129 (permalink) Old 11-04-2012, 10:18 AM
Lotusmotion's Avatar
I use a Gates Air-Lift, which does essentially the same thing and was about $100 two years ago.
It attaches to a compressor to create a vacuum in the coolant pipes and hoses. Works like a charm and takes all of the drama out of a coolant change.
There should be LT postings about it.
2006 Exige - Phantom Black
Lotusmotion is offline
post #124 of 129 (permalink) Old 01-12-2013, 11:28 AM
Originally Posted by TimMullen View Post
I managed to get some this morning at Walgreens here in Virginia. Then a bit later, I found some at K-Mart in Manassas. Both were the 50/50 premix. I couln't find the concentrate anywhere, and couldn't find Peak Global anyplace else (including NAPA and every other autoparts store).
After we got home, I found a place on the web that advertised the concentrate so I ordered that. Later got a notice from them that the Peak Global has been discontinued and they would be happy to send me "regular" Peak. Guess I have to use the Global 50/50 premix I picked up this morning.
From some research (i.e. at Bobstheoilguy.com and a few other places) I'm led to believe that both the "regular" Peak and the new Prestone "all makes and models" contains some of the same additive that's in Dex-Cool. That is a concern because it's been known to "eat" certain types of gaskets and plastics. The advantage of the Peak Global was that it didn't have the Dex-Cool additive (and was about the only type of coolant on the market that didn't). The big problem is that you can't get a definitive answer as to which coolant has what additives, and exactly what we're supposed to be avoiding in our cars (although I avoid Dex-Cool in all my cars - although that may be a problem in the future as even "regular" old green Prestone seems to have disappeared).
Hi Tim
I saw your write up about the coolant flush. I'm looking to do the same but I'd like to take it in to have it done. I live in the DC area and was wondering if you've found a shop where you go to have work done on your Lotus?
I have an 07 Elise.
Thanks in adavance
Robert
Bert_VT is offline
post #125 of 129 (permalink) Old 09-05-2017, 07:35 AM
https://www.grainger.com/product/48ZE71?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!50 916724677!!!!82665746037!&ef_id=WJENsAAAAcxWcBks:2 0170905153224:s&kwid=productads-adid^50916724677-device^c-plaid^82665746037-sku^48ZE71-adType^PLA
Is this the stuff that is recommend for our cars. Would like confirmation before purchasing, Thanks.
Israel J is offline
post #126 of 129 (permalink) Old 09-05-2017, 07:38 AM
tvacc's Avatar
Yes, that is the stuff. Just did 3 LOONYs Elises here a few weeks ago.
Tony V
Tony Vaccaro
2005 Elise Ardent Red, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus, Drive Fast Take Chances, 93 Caterham 7, 71 Elan, 70 Elan GTS, 1991 M100, 1999 Sport 190 Elise, 1974 Europa TC, 1973 Europa JPS #15 TwinCam.
tvacc is offline
post #127 of 129 (permalink) Old 09-05-2017, 08:57 AM
Awesome, should I order 3 or 4 gallons to be safe. Thanks.
Israel J is offline
post #128 of 129 (permalink) Old 11-15-2017, 07:20 PM
Robocop305's Avatar
I would order 4, that way you can always have left over in case you need to refill.
Robocop305 is offline
post #129 of 129 (permalink) Old 05-18-2018, 12:22 PM
elise311's Avatar
Quick question. Are these two bottles the same as each other just maybe a newer bottle and label?
elise311 is offline
