Coolant System Pressure - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 05-30-2015, 07:03 PM Thread Starter
For those of us who have the option, what coolant system cap pressure is ideal for the 2zz engine? BOE's swirl tank comes with a 30 psi. KISS and stick with that?
My particular setup includes: Laminova coolers for both oil and trans fluid, Wizard Cooling radiator located in the rear, all silicone 1 1/4" hoses (rated for 50 psi operating) and reinforced rubber hoses (rated for 300 psi operating) for the smaller diameter stuff, aluminum joiners, and constant torque hose clamps. My motor outputs somewhere above 200 WHP. Could be as high as 250 but I'm just guessing without a dyno. I run DI water with surfactant.
Rephrased, for a lower power application such as mine, is there any advantage or benefit of running a higher relief pressure than 30 psi?
I'd like to hear the community's thoughts.
Thanks in advance.
Jason
06' Fed Elise
My frame, rear subframe, steering rack, A-arms, front crash structure, suspension uprights, and fuel tank are stock.
jasondew is offline
post #2 of 7 (permalink) Old 06-03-2015, 03:38 PM Thread Starter
Visibility bump
Jason
06' Fed Elise
jasondew is offline
post #3 of 7 (permalink) Old 06-03-2015, 05:06 PM
TedR's Avatar
Contact Phil at BOE, I think he has posted about testing he has done at higher pressures and would probably know more about it than anyone else.
TedR is offline
post #4 of 7 (permalink) Old 06-04-2015, 05:30 AM
Exiged's Avatar
Are you having cooling issues??
DIY 2007 Exige S K20A2 C38 Rotrex
Www.onetonracing.com
Exiged is offline
post #5 of 7 (permalink) Old 06-04-2015, 08:17 AM
Plug Whisperer
turbophil's Avatar
Thanks in advance.
At that hp, there is going to be an advantage, yes, but will you realize that advantage--- hard to say! Perhaps not :/
That said, the higher the pressure the more efficient the cooling system is going to be at getting heat away from the cylinder walls and head, and into the radiator. Even if the car is not over heating, more pressure will still pull more heat from the motor and reduce air pockets and hot spots in the head... but again, with 200hp, those benefits probably would not show on the dyno or track... In a true spec environment, where the cooling system is "open", a high pressure system may be that little edge required to eek out a win... You'll find games like that in NASCAR, etc, where cooling system pressure is a really big deal.
ALL THAT SAID, our system comes with a 30 psi cap and a schrader valve that allows you to add pressure to the system, creating an air spring (if you will). With the ability to add pressure, you can get the system all the way to 30 psi and beyond if you choose. We've seen benefits for sure in the higher hp cars... but again, can't really say on the NA cars where the cooling demands are much less...
Hope that helps,
Phil
turbophil is offline
post #6 of 7 (permalink) Old 06-04-2015, 09:08 AM
Plug Whisperer
turbophil's Avatar
...just to add, there is a subjective quality to using a pressurized tank like ours... It's looks cool and cleans up the plumbing in the engine bay
post #7 of 7 (permalink) Old 06-04-2015, 09:10 AM Thread Starter
Hope that helps,
Phil
Thanks Phil. I was thinking that a higher pressure system would help with cooling--not on the gauge but in the motor. Glad to hear that I wasn't telling myself a story to justify purchasing one more 'performance' part. I am only asking because the rest of my cooling system components are sufficient to take the pressure and I can use the 30psi cap or simply swap in a Stant 40psi without concern for the integrity of the rest of the system.
Please anxiously await my order.
Jason
06' Fed Elise
jasondew is offline
