DIY radiator repair? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 04-20-2014, 08:50 PM Thread Starter
someguy582's Avatar
I have an aftermarket aluminum radiator from a previous owner on my Elise, I'm almost certain it is from wizard cooling based off measurements. Im still trying to figure out exactly where. but it has a small pin hole either on one of the cross pieces of the core, or where the cross section mounts up to the end caps. I'm wondering if I were to find it is there a decent DIY I could do, or if it has to be welded. Also if it has to be taken to a proffesional does the cost of the repair usually come out to about the same as just buying a new one?
someguy582 is offline
post #2 of 4 (permalink) Old 06-12-2014, 08:35 AM
You can epoxy it. Many radiator shops just use epoxy nowadays as well.
I have several thousand miles on an epoxied one in one of my cars with no issues.
Pat Wildfire
06 Elise
02 Triumph 955i
93 Mazda RX7 3 rotor
09 Mini Clubman
14 Mercedes GLK250
99 Mygale FC
pwildfire is offline
post #3 of 4 (permalink) Old 06-12-2014, 08:47 AM
glb
glb's Avatar
What kind of epoxy do you use?
Someguy, one trick to test (find leak in) radiator is to cut bicycle inner tube; clamp each end to radiator and fill with air.
Uh, don't forget the cap.
glb is online now
post #4 of 4 (permalink) Old 06-12-2014, 01:05 PM
I think there is a special epoxy for just that purpose, but I have used regular 5 minute epoxy twice with no issues.
Pat Wildfire
06 Elise
02 Triumph 955i
09 Mini Clubman
14 Mercedes GLK250
99 Mygale FC
