Do I need to bleed? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 11-19-2011, 02:23 PM Thread Starter
FLKeith's Avatar
Do I need to bleed?
My coolant reservoir had a small leak so I am replacing it. It had coolant in it when I stopped the car but was dry when the engine cooled down. Do I need to bleed the system when I put in the new one and fill it up? If so, where is the bleed plug in the engine compartment? The service notes say "From within the engine bay, open the air bleed plug in the heater return hose at the left hand rear of the engine bay." I could not find this labeled in any diagrams. There is a coolant line at the rear of the engine that has a plastic segment in the middle with a plastic nut on it - is that the bleed plug?
Thanks
2006 Exige, solar yellow, track, touring, LSD, Fujita intake, 2bular 8x24
2007 MINI Cooper S, dark silver, sport suspension, LSD
FLKeith is offline
post #2 of 4 (permalink) Old 11-19-2011, 04:54 PM
SirLotus's Avatar
1st is front bleed valve
2nd is Engine bay bleed valve
SirLotus is offline
post #3 of 4 (permalink) Old 11-19-2011, 06:07 PM
glb
glb's Avatar
the front bleed valve is under the rh fender, accessed after the fender liner is removed. Some take the wheel off, some don't. I don't.
glb is offline
post #4 of 4 (permalink) Old 04-24-2019, 10:14 AM
philethier's Avatar
What about the white plastic wingnut on the top of the coolant reservoir? Is that also a useful bleed screw?
2005 USA Elise.
Phil Ethier Minnesota USA
2004 Suburban 8.1, Sport Red
2017 Ford Fusion (wife had to stop driving manual due to shoulder problem), Oxford White
2006 Gulf Stream Conquest Super C on Chev Kodiak chassis
http://www.mnautox.com
philethier is offline
