How to turn on radiator fan earlier? - LotusTalk - The Lotus Cars Community
post #1 of 9 (permalink) Old 08-13-2012, 06:56 AM Thread Starter
Is the radiator fan controlled by ECU? Or any switch?
The stock fan turned on too late making the track water temp running high. Is there a way to turn on the fan earlier?
dori_dori is offline
post #2 of 9 (permalink) Old 08-13-2012, 07:07 AM
407Driver's Avatar
The fans are controlled by the ECU and his buddy the Fan Controller. The book says the fans are off above their stall speed of 80 MPH. You might have a bit of air in the system there are bleed screws front and rear.
LZ LoLo survivor
407Driver is offline
post #3 of 9 (permalink) Old 08-13-2012, 07:18 AM
doug_porsche's Avatar
Does your car still have A/C?
Turn on the A/C on the warmup lap and/or in the pits on the way to the track. This will trip the pressure switch which will turn on the fans. Then you can turn off the A/C and the residual pressure will keep the fans on for a short time (2 min or so).
Apexes are a lot like relationships. So tough to get right, so easy to see where they went wrong.
The secret to a long life is ------- not dying.
doug_porsche is offline
post #4 of 9 (permalink) Old 08-13-2012, 07:29 AM Thread Starter
Great idea mate, turning on the A/C in warm-up lap sounds great helping the 1st hot lap. But the subsequent laps...hmm...
post #5 of 9 (permalink) Old 08-13-2012, 08:03 AM
A1 Automotive & Smog
Harix's Avatar
Electric fan only functional during stop and go traffic and AC on. If you run above 35 mph, you don't need the fan to turn on or it would be the same.
I think you need to replace the thermostat, because it might not fully open.
Harix is online now
post #6 of 9 (permalink) Old 08-13-2012, 08:36 AM
SirLotus's Avatar
It is possible to add a manual toggle switch for manual activation.
SirLotus is offline
post #7 of 9 (permalink) Old 08-13-2012, 06:03 PM Thread Starter
Thanks Michael, any guides showing the wiring job?
post #8 of 9 (permalink) Old 08-14-2012, 02:04 PM
Westrock's Avatar
It took me 30 minutes to check both bleeds, with no prior experience of the task on the car. Remove the front passanger wheel and the wheel well liner. You should see the bleed screw up at the top right next to the radiator. The second one is right next to the engine on the driver side.
Start the engine up and let it get up to normal temps (like 190 if you have stock thermostat in it). Then slowly twist open the bleeds until water comes out. Do that a couple times on both ends. Thats it.
Westrock is offline
post #9 of 9 (permalink) Old 08-14-2012, 02:26 PM
SirLotus's Avatar
It simply means grounding one or two ECU outputs, if you are interested I will go further.
SirLotus is offline
