Oil Coolant Removal (not replacement) - LotusTalk - The Lotus Cars Community
post #1 of 9 (permalink) Old 07-12-2012, 02:43 PM Thread Starter
451
451's Avatar
Greetings all, I know there's threads about removing the stock oil cooler system and replacing it with better lines, relocating things as well as replacing it with different brand oil coolant systems altogether.
My question is, and I've seen this alluded to in other posts, could you (in practice or theory), just remove the oil coolant system altogether with a simple U-style pipe fitting at the sandwich plate?
Could/should/would the engine run normal? Is that an issue for everyday driving around town, highway, some stop n' go traffic in SoCal climate where it's usually sunny and between 50-90F most places, most of the year? Would I expect to throw engine codes doing that?
And if it's relatively safe, and the car isn't being tracked or raced, wouldn't it then be alright to snip the original coolant line fittings off and remove the whole shebang?
451 is offline
post #2 of 9 (permalink) Old 07-12-2012, 03:23 PM
Apex_in_sno's Avatar
The part from toyota to use an oil filter without the cooling sandwich is like 12 bucks, which will be way less money than sourcing those bastard sandwich fittings...
The consenus appears to be that non tracked cars will be fine without an oil cooler...
The ECU has no knowledge of the oil cooling system, also you will see an increase in usable oil pressure (there's quite a bit of overhead involved in pushing that oil up front and through the cooler(s)
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline
post #3 of 9 (permalink) Old 07-12-2012, 04:22 PM
khauger's Avatar
I was going to ask the same thing. Is anyone seeing any problems with removing the oil cooling system. Is it really only needed for tracked cars? How do you know if you are hurting anything without the coolers.
khauger is offline
post #4 of 9 (permalink) Old 07-12-2012, 04:31 PM Thread Starter
451
451's Avatar
Thanks man Do you know or maybe someone else might be kind enough to chime in on what the part number is for that Toyota bit? Or were you just meaning that you could run a different oil filter altogether that would eliminate the sandwich plate that way?
451 is offline
post #5 of 9 (permalink) Old 07-12-2012, 04:57 PM
The part number is already posted on another active thread, but here it is anyway.
Union: Toyota 90904-04002
This part will allow you to run the same filter you currently run without the sandwich plate.
Check the thread oil cooler delete, or sandwich delete, all the pics are there.
1864lbs, full tank
post #6 of 9 (permalink) Old 07-12-2012, 05:24 PM
robains's Avatar
Yes it's safe (and probably safer than Lotus setup)
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." - Carl Sagan
robains is offline
post #7 of 9 (permalink) Old 07-12-2012, 05:58 PM
For N/A or S/C or both?
slightly2ned is offline
post #8 of 9 (permalink) Old 07-13-2012, 07:42 AM
robains's Avatar
Both for street applications.
robains is offline
post #9 of 9 (permalink) Old 07-13-2012, 08:33 AM Thread Starter
451
451's Avatar
Thanks again guys for the help
451 is offline
