Please fill in the blank with a three digit number... - LotusTalk - The Lotus Cars Community
post #1 of 14 (permalink) Old 02-12-2012, 01:12 PM Thread Starter
Gamera The Atomic Turtle
komiko's Avatar
Your sitting in traffic, summer, sunny, 90 degrees, top off, no AC, and you are waiting for a traffic delay to pass. You are moving, just crawling along (3mph) but not enough to cool anything. The water temp climbs it's at 205 degrees. If it continues to climb, my radiator fans should turn on at _____ degrees and cool me down.
Lotus Elise #134 - S O L D BOE REV400 street car built at BOE in KC. , Stock motor, low boost w/stock cat/mani, 292whp, (5.95 lbs/hp) passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, BOE Oil Cooler Relocation, BOE Surge Tank/750cc injectors, BOE Race Links, MWR Rear Lift Kit etc. 0-100 = you bet!
Build thread :
https://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline
post #2 of 14 (permalink) Old 02-12-2012, 01:24 PM
apk919's Avatar
The fans on my Exige usually turn on at 209...
apk919 is offline
post #3 of 14 (permalink) Old 02-12-2012, 01:32 PM
Michael Mann's Avatar
209 is what I have been told
05' Lotus Elise Touring/Sport, HT, BWR Supercharger, Turn Signals + Fins delete, 2bular Exhaust, Difflow 5 Diffuser, Nitron Quick Ratio Steering Rack, Sector111 Shifter Reinforcer + Stans DIY, BWR Sway Bar, Moroso oil pan, Twin Coolers, 55w 6k DDM HID's, Rota Torques/R888's, Exige Scoops, Exige Mesh Grills, ReVerie Front Lip, LED Angel Eyes, Braille, S111 Mirror, SS Brake Lines, Custom Stereo
Michael Mann is offline
post #4 of 14 (permalink) Old 02-12-2012, 05:59 PM
shay2nak
shay2nak's Avatar
i had mine set to turn on 195 low speed and 200 high speed, iirc
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #5 of 14 (permalink) Old 02-12-2012, 06:04 PM Thread Starter
komiko's Avatar
how do you tell it to do that? (Liking the idea) is that an ecu reflash or is it easier than that?
Build thread :
komiko is offline
post #6 of 14 (permalink) Old 02-16-2012, 09:27 AM Thread Starter
komiko's Avatar
thanks for the number.
Build thread :
komiko is offline
post #7 of 14 (permalink) Old 04-29-2012, 01:59 AM
Tested this today. 207F on my 07 Exige is when they turn on. When you turn on the AC, the fans come on at half speed; once the temps rise to 207F, they kick in to the mid-point. Im not sure at what temp, but there is a final temp setting where the fans kick in full blast.
I found with the A/C turned on/above 207F, temps will decrease faster when at idle than with it off.
slightly2ned is offline
post #8 of 14 (permalink) Old 04-29-2012, 07:41 AM
addertooth's Avatar
Like many people I was nervous about how high the temperature climbed before the fan turned on. However, with the recommended amount and type of coolant, boiling should not occur till 228 degrees F. The plastic end-caps on the factory radiator make me nervous. My girlfriend's miata radiator (which also has plastic endcaps), cracked and failed at our last autocross event; her car was nowhere near the boiling point when this occured. Plastic does not age well at elevated temperatures. *When* the radiator fails on the Elise, it will be replaced with an all aluminum radiator.
addertooth is offline
post #9 of 14 (permalink) Old 08-21-2012, 05:28 AM
glagola1's Avatar
The lotus shop manual says that the fans kick on low speed at 208.4F then they'll kick on full speed at 213 or something like that... I can't recall the 2nd temperature exactly right now.
glagola1 is offline
post #10 of 14 (permalink) Old 08-21-2012, 05:30 AM
www.theapexinn.com
kestrel74's Avatar
693...............Do I win ? ( I was never good at picking lottery numbers either )
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #11 of 14 (permalink) Old 08-21-2012, 06:41 AM
addertooth's Avatar
Actually Kestrel you were quite close, 371 (kelven).
post #12 of 14 (permalink) Old 08-28-2012, 05:07 PM
Westrock's Avatar
Man now I'm really worried 208.23 is my comfortable zone
Westrock is offline
post #13 of 14 (permalink) Old 08-28-2012, 06:58 PM
Wmangm's Avatar
You need to spend more quality time with your owners manual... from my 2005 elise manual.
Sent from my MB860 using AutoGuide.Com Free App
Wmangm is offline
post #14 of 14 (permalink) Old 08-28-2012, 10:44 PM
shay2nak
shay2nak's Avatar
yes a reflash.
WTC 2
shay2nak is offline
