-   A/C, Heating and Ventilation (https://www.lotustalk.com/forums/f313/)
-   -   [05 Elise] Rainstick-like noise from the dash when turning (https://www.lotustalk.com/forums/f313/05-elise-rainstick-like-noise-dash-when-turning-314889/)
highlow 07-12-2015 10:05 AM
When my AC is on and I make a right turn, a rainstick-like sound comes from under the dash. Googling the problem brings up a lot of similar issues with other cars, but nothing for the elise.
According to these guys on the Yaris forum (Air Conditioner Noise & Leak? - Toyota Yaris Forums - Ultimate Yaris Enthusiast Site), the issue is a plugged drain tube.
How would I access this tube on the elise?
Has anyone else experienced this and been able to fix it?
bri3d 07-12-2015 10:41 AM
It's a black piece of wire conduit (... because Lotus) on the passenger's side front of the car, exiting near the front suspension A-arm pickup.
https://www.lotustalk.com/forums/f101/whats-tube-28416/
To access the top of the tube (HVAC box) is a brutal job (search resistor pack replacement) but the drain end of the tube should be visible if you want to try to run a wire through it or something.
I would also double check that the HVAC compartment drain holes are drilled correctly: https://www.lotustalk.com/forums/1496844-post3.html
If the noise persists, I would suspect a piece of gravel in the chassis somewhere, although I guess if it's only happening with the A/C on your drain theory is probably accurate.
vaughn 07-12-2015 01:26 PM
Mine just started doing this. So funny someone else just started having the issue too. Only thing I have done in a while is change the dashboard out with a carbon fiber one. I am going to show this post to my shop, MC Customs, and hopefully they will be able to work it out. They always do!
highlow 07-13-2015 05:56 AM
I'll see what I can do about the drain plug. It seems to be working though, it drips a ton after a long drive in the florida heat with the ac on.
Were the drain holes a recall item or do all cars have them?
bri3d 07-13-2015 07:37 AM
They were a service bulletin item. If you're sure the noise only happens with the A/C on, I'm not sure how they could be the culprit - if there's water in there, it'll be in there all the time. But it's probably still a good idea to have them done anyway as you really don't want to deal with replacing the blower motor controller/resistors if they get wet.
highlow 07-13-2015 07:54 AM
Yeah, it's only when the AC is on.
Another interesting note, the noise is louder on higher ac settings. You can hear it at 1, but its louder at 3.
highlow 07-15-2015 09:44 AM
One more note. The noise immediately goes away when I turn the AC off.
surferpkt 07-15-2015 11:11 AM
Maybe you have leaves in your blower box??? The factory seal can be horrible. Mine was just awful and doing no good, so I had to redo the seal when the service bulletin was being done.
Yersinia08 07-15-2015 12:12 PM
I had this problem but it turned out to be birdseed that a mouse or something stored up there during the winter months when the car was in storage. When I takes turns now little seeds hit my shins.
highlow 07-15-2015 01:42 PM
Your problem was dependant on whether or not the AC was on?
Yersinia08 07-15-2015 04:25 PM
Sorry I didn't clarify. Happens all the time.
dma550 07-15-2015 05:26 PM
I had about 100 empty nuts in my dash on my last Elise. Found them doing the switch pack replacement.
vaughn 07-15-2015 06:11 PM
Mine only happens when my blower motor is on. Doesn't matter if I have the AC on or off. As long as its blowing out air, I get the noise.
jefrac 07-15-2015 06:28 PM
Possibly a trunk shaman.
highlow 07-15-2015 07:11 PM
I haven't tested this. I suspect it's the same for me but I'll try tomorrow.
vaughn 07-15-2015 07:29 PM
Yea just turn the AC part off but the blower fan still on.. it'll still happen.
vaughn 07-22-2015 07:21 PM
Any updates?
highlow 07-22-2015 08:24 PM
Originally Posted by vaughn (Post 4230722)
Any updates?
Nope. Haven't tried anything yet.
It's not a huge priority for me either, so no major push to get it done.
