AC Coolant Line Insulation - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 04-26-2019, 10:05 AM Thread Starter
henrymfisher's Avatar
Hi guys,
The front clam is off of my Exige.
I see there is rubber insulation (looks like factory OEM stuff) on several AC lines.
Are there pros/cons to putting more rubber insulation tubes on the other
exposed AC lines (see photo)?
Thanks for your input.
Henry
'07 Exige S
Henry
'05 Elise
henrymfisher is offline
post #2 of 5 (permalink) Old 04-26-2019, 10:18 AM
kfennell's Avatar
There is probably a small benefit to covering the line from the condenser to the evaporator, the other line from the compressor discharge to the condenser is a hot line so no.
kfennell is online now
post #3 of 5 (permalink) Old 04-26-2019, 11:10 AM Thread Starter
@kfennell - so the line that bends along the top of the rad gets covered?
Thanks,
Henry
Henry
'05 Elise
post #4 of 5 (permalink) Old 04-26-2019, 12:06 PM
kfennell's Avatar
Sure, if you wanted, I don't think they are from the factory though. I dont think mine was. To make the AC colder make sure the vent from the HVAC box to the car is well insulated and on well, consider a heater bypass, open up the footwell vents, and consider interior insulation and tinting.
post #5 of 5 (permalink) Old 04-26-2019, 09:19 PM
You want to reject heat through the condenser system. The vast majority of that heat rejection happens in the condenser itself as air passes over its fins.
The one place I can think of that I would really want to thoroughly insulate the high side lines would be in the sills to keep the aluminum chassis from being the high side heat sink, because the people are sitting inside it.
Once the refrigerant has passed through the evaporator (and boiled, cooling the air passing through the evaporator) you want to keep the refrigerant in the LP line going to the compressor as cold as possible - that's the line that really benefits from being well insulated, because it reduces the work the compressor has to do.
The factory insulated what I would have in the picture. The two uninsulated lines are the high pressure lines entering and leaving the condenser. They're hotter than ambient and we want them as cool as possible, so no insulation is a good thing. The big insulated line is the low pressure (suction) return line coming from the evaporator down below. More insulation on that LP line surely won't hurt anything.
steelypip is offline
Similar Threads
What to Use to Replace Insulation on AC Line? Mike Edmonds Lotus Elise 1 08-08-2016 09:55 PM
Blown Coolant Hose and Coolant Level Sensor GoFastTSI Lotus Esprit 9 01-21-2015 05:02 AM
Coolant system - coolant replacement PMcTighe Maintenance and Repairs. 7 04-19-2009 07:47 AM
How do you bleed the coolant system?/ Question about coolant tank xxxotic Maintenance and Repairs. 2 03-08-2008 11:32 AM
AC duct insulation hack arobot Maintenance and Repairs. 27 08-23-2005 04:40 PM
