-   A/C, Heating and Ventilation (https://www.lotustalk.com/forums/f313/)
-   -   AC/Heat Blower Dead (https://www.lotustalk.com/forums/f313/ac-heat-blower-dead-467430/)
Regan 03-27-2019 08:51 AM
AC/Heat Blower Dead
Hi all-- in the last year, only the third power setting (maximum) would turn on the air in the vehicle. This year, looks like even the third power setting finally went out.
I'm by no means a mechanic, but wanted to see where I could start looking for causes to fix. Fuse blown? Bad compressor?
steelypip 03-27-2019 10:34 AM
If your low speed settings have been gone for a while, it's probably corrosion damage on the blower resistor block. There are many threads on repair for it.
exigegus 03-27-2019 10:40 AM
Look up blower motor resistor
pretty common
Habious 03-27-2019 10:43 AM
Originally Posted by exigegus (Post 5934066)
pretty common
...Oh, and a complete nightmare to repair (from what I understand).
exigegus 03-27-2019 11:09 AM
Ehhh
Clam off, so there is that
If it has an OEM radiator it is a good idea to change that
There is a nice post with a camera and forceps that seems pretty elegant
TechnoHippie 03-30-2019 10:04 PM
Yep clam off. Has your car had the oil line recall done? If not ... you take it to a dealer and get that done because there is a chance they might have to remove the clam to do it :) If that's the case you save most of the labor costs. Either way I strongly suggest you upgrade radiator while the clam is off, which is what I did.
Sent from my SM-N950U using Tapatalk
