AC question - where to buy O rings - LotusTalk - The Lotus Cars Community
post #1 of 30 (permalink) Old 09-18-2014, 06:07 PM Thread Starter
Was everyone smarter than me and ordered their o-rings ahead of time online?
Getting ready to charge the AC system this weekend and can't find a few of the o-rings anywhere local. Napa has a few but couldn't even order me a 7.5mm o-ring. Guy pulls out a huge catalog and the closest thing he could find was 7mm. He's trying to convince me that stretching it .5 mm is fine and I'm not buying it. A few of the one's they sell are within .1 or .2 mm which seems ok but I'm still short the 17 and 7.5mm and can't seem to find them anywhere?
Where did you guys get yours?
mavster is offline
post #2 of 30 (permalink) Old 09-18-2014, 09:07 PM
azac's Avatar
Two questions:
Where does it go ?
What is the other dimension ?
How do you know your used o-ring is not distorted ? (third question)
196? Seven - long gone
2005 Storm Titanium Elise - sold
2008 blue 2-Eleven - track toy
2011 Carbon Grey Evora S
1959 Ford Anglia project
2008 white 2-Eleven - track toy too/two
azac is offline
post #3 of 30 (permalink) Old 09-18-2014, 10:29 PM
Niral_Xige06's Avatar
i got mine from a Car Quest. Some NAPAs and Autozone's have a kit in the back to match up. Also, check out Harbor freight if there's one nearby.
I'll try to find the part number tomorrow..i wrote it down somewhere.
2011 Mini Cooper S - ardent red body/monaco white roof
2006 Lotus Exige, Aspen White:
date purchased - March 2012
date married - Sept 15,2013
date wife found out about Lotus - Sept 14,2014
date wife sat in Lotus - Sept 2015
Mods:
'07+ MP62 Supercharger retrofit w/VF S2 tune + RLS IC/Tubes,Walbro 255 fuel pump,Stage 2 exhaust, '07 body,Odyssey battery,Gauge cluster refresh
Chuck Risen's audio/interior system + fully integrated British voice "Kate" giving the GPS directions
Niral_Xige06 is offline
post #4 of 30 (permalink) Old 09-19-2014, 03:02 AM
LotusCC's Avatar
http://www.deroure.com/diagrams.asp?...SMO=0&ST=&SC=0
05 Arctic Silver UK:
12 Wrangler JKU
LotusCC is offline
post #5 of 30 (permalink) Old 09-19-2014, 04:20 AM Thread Starter
Originally Posted by azac View Post
Two questions:
Where does it go ?
Well thats 3 questions
The 7.5s are for the drier, the smaller line into the expansion valve, and the condenser outlet
The 17 mm is for the larger expansion valve line and the bulkhead lines
I have to answer your third question with the same question back. How do you know if theyre deformed without something to compare them to?
My car is an 05 so theyve probably lost a little of their suppleness and distorted some. Im sure I overtorqued a few of the nuts a bit before I found the correct specs as well. But all of my torque wrenches are ratchet type anyway and you need an open-end on all of those fittings. I can use a crows-foot on a few I have the sizes for and get close, but the bulkhead fittings are pure seat of the pants.
mavster is offline
post #6 of 30 (permalink) Old 09-19-2014, 04:59 AM Thread Starter
Thanks. I bought the NAPA kit but it doesn't have anything close to the 7.5 or the 17mm. I think the same thing for the HF kit. I have the Lotus PN's from the service manual but when the NAPA guy looked them up they told him to order from Lotus Online which means I'm at least 2 weeks out from getting this wrapped up.
mavster is offline
post #7 of 30 (permalink) Old 09-19-2014, 06:06 AM
Jim-C's Avatar
.5mm is a pretty small stretch . 1/50 of an inch ???
Jim-C is offline
post #8 of 30 (permalink) Old 09-19-2014, 06:14 AM
I take it back. I actually got it from NAPA, however, it wasn't an off the shelf kit. They have an old kit from where they used to sell them individually and happened to have the one I needed.
Here is the part number for what I used (to be clear this is the o-ring that goes on to the a/c line into the condenser):
TEM 407009
NAPA AUTO PARTS
At the time I lined it up with the original one and it seemed identical.
Mods:
post #9 of 30 (permalink) Old 09-19-2014, 06:18 AM Thread Starter
I know what you're saying. The NAPA guy was making the same argument. The thing is it's under pressure, a lot of pressure on the high side and I don't know the effects coz I'm no expert.
Troubleshooting AC leaks is right up there with troubleshooting random electrical problems and root-canals on my list of things not to do on the weekend. Plus ripping the clam off again is not an enticing thought, which is why I want to replace all the o rings in the first place, so I don't have to do it again.
I think AZAC does AC repair for a living, want to see what he thinks about being .5mm off.
M
mavster is offline
post #10 of 30 (permalink) Old 09-19-2014, 06:30 AM Thread Starter
TEM 407009
NAPA AUTO PARTS
This is helpful, thanks. NAPA gave me a couple of part numbers but that doesn't match so it might be a better fit. There's two different size lines to the condenser. the outlet is the 7.5mm that I can't find which is also used on the drier fittings and one of the expansion valve fittings. Is that the one you're talking about?
M
mavster is offline
post #11 of 30 (permalink) Old 09-19-2014, 06:41 AM Thread Starter
TEM 407009
NAPA AUTO PARTS
Just called NAPA, she said she had stock but that part comes up as .364 in ID which equates to 9.2mm which doesn't match any of the sizes on the manual. Maybe it's time to break out the calipers and pull the o-rings.
mavster is offline
post #12 of 30 (permalink) Old 09-19-2014, 08:25 AM
I recall stacking the old and new one on top of each other and they seemed very close. However, it would still be good to confirm. I think that's the one I'm talking about, but you'll have to double check since I'm not 100% as it was earlier in the year-maybe we are talking about 2 different locations. I also replaced the drier with one that NAPA had, if you want the part # for that too. It's not exactly in size, but plug and play for practical purposes--the stock one had to be ordered; i needed it immediately and the NAPA one cost just a few dollars less. i dont remember having to buy extra o-rings on account of replacing the drier.
An alternate would be 407006 (which I wrote on the back of the receipt), but my receipt shows I only bought 1 of TEM 407009. I remember running around to a bunch of different stores to get this (as well as the o-rings for RC550 injectors which was even harder to get).
Mods:
post #13 of 30 (permalink) Old 09-19-2014, 08:49 AM Thread Starter
O-ring saga
Well there's some hope then and these part numbers may help. Also, I agree with you, the best thing to do is to pull them out and try to match them up physically. Wall thickness etc. can really change the shape and Lotus doesn't publish that info. I'm somewhat doubting the research skills of the NAPA associate I spoke with yesterday also. The right person can make all the difference. I did purchase the NAPA replacement drier already, but mine didn't come with o-rings so I moved the old one's over from the stock drier.
mavster is offline
post #14 of 30 (permalink) Old 09-19-2014, 10:16 AM
ahh.. yeah. i went to a few NAPA's as well. I notice how some of the older smaller stores can be more helpful than some of the newer megastores they have. good luck!
Mods:
post #15 of 30 (permalink) Old 09-19-2014, 11:08 AM
azac's Avatar
The ones that I have replaced are on the drier. Those are standard #6 O-rings. We use a line called SanTech, their part number is MT0237.
Our vendor for the expansion block shows very standard #'s 6, 8, 10, 12 O-rings for the different openings. Lotus did not reinvent the wheel here.
We literally have hundreds of different part numbers for O-rings, but these are the most basic sizes.
azac is offline
post #16 of 30 (permalink) Old 09-19-2014, 01:12 PM
bryanf650's Avatar
I just got them at the dealer...
bryanf650 is offline
post #17 of 30 (permalink) Old 09-21-2014, 08:12 AM Thread Starter
Thanks for all the help guys. My second trip to NAPA armed with correct part numbers (thanks Niral) and a more knowledgeable clerk proved fruitful. The correct part number for the 7.5mm is (TEM) 407006. Those are pretty much dead on: 7.56mm.
The other part number for the 17mm is (TEM) 407079. And those are exact 17mm replacements as well. He had to order those from another store so I won't have them until Monday but better than 2-3 weeks with DeRoure or other web/mail order.
AZAC - thanks for the response as well. For whatever reason, those out of the industry don't seem to understand #6,#8, etc. and Lotus doesn't publish based on those sizes either.
mavster is offline
post #18 of 30 (permalink) Old 09-21-2014, 12:13 PM
you're welcome! glad I was finally able to help someone for a change
Mods:
post #19 of 30 (permalink) Old 03-03-2016, 05:41 PM
zombie thread alert
So this is a total PITA
'standard' number 6 8 10 12 do not seem to mean anything, on top of the fact that there are also metric standard numbered o rings
regular ac kits do not have the same size o rings as on the car
does anyone have the actual dimensions for the o rings that belong on the car, measuring old crushed o rings is not that accurate, and what is the name of the scale the numbers 6 8 10 and 12 come from?
It probably refers to tube diameter in 1/8s, although I am not at the car to check, but oring standards are a completely different set of numbers so a #6 would be a 0012....maybe
aggravating that the simplest thing is virtually impossible
I am not inclined to make a 2 hour trip to overpay for o rings at the dealer, then drop one under the bench somewhere, when I could have a box of them at my door in a few days.......
exigegus is online now
post #20 of 30 (permalink) Old 04-17-2016, 05:00 PM
The [mostly] definitive answer
I like vintage air, they make nice stuff and they do not overcharge on replacement parts
#6 oring pack of 10 p/n 331016 price list says a buck
# 8" " 331008 same
#10" " 331010 same
I bought them summit
Vintage Air Rubber O-Rings for A/C Fittings - Free Shipping on Orders Over $99 at Summit Racing
use the part number I listed for 10 packs
VIntage does not use #12, so I had to break down and drive to the dealer, who does not charge much for the orings, but the drive is a pain, plus it is good to have a bunch extra for dropping, refitting yada yada
These guys will sell you a lifetime supply:
https://coldhose.com/specialty-fittings/orings.html
I have not bought from them tho
I bought the NAPA part numbers listed, and they are NOT the correct orings, the #12 in particular failed to seal.
Summit is faster shipping than Vintage themselves....
